387001741
387001741
    LAIRD(莱尔德)
    ET2.5,12,F1,3030,TA,RT,W4.5
387001741 数据手册
A The HiTemp ET Series of Thermoelectric Modules (TEMs) are designed to operate in high temperature environments. This product line is available in multiple configurations and is ideal for applications that operate in temperatures above 80°C. Assembled with Bismuth Telluride semiconductor material, thermally conductive Aluminum Oxide ceramics, and high-temperature solder construction, the ET Series is designed for higher current and larger heat-pumping applications. ▪ High-temperature operation ▪ Automotive cooling ▪ Reliable solid state ▪ Telecom cooling ▪ No sound or vibration ▪ Outdoor environments ▪ Environmentally-friendly ▪ Medical heating/cooling ▪ RoHS-compliant Hot Side Temperature (°C) 85 110 25.4 26 Delta Tmax (°C) 87 94 Imax (Amps) 2.5 2.5 Vmax (Volts) 18.6 20.3 Module Resistance (Ohms) 7.11 7.87 Qmax (W) TA 0.157” ±0.010” 0.001”/0.001” Lapped Lapped 4.5” TB 0.157” ±0.0005” 0.0005”/0.0005” Lapped Lapped 4.5” RT RTV Clear -60 to +204 °C Non-corrosive, silicone adhesive EP Epoxy Black -55 to +150 °C Low density syntactic foam epoxy encapsulant PERFORMANCE CURVES AT Th = 85° C MECHANICAL DRAWING ▪ ▪ ▪ Maximum Operating Temperature: 150°C Do not exceed Imax or Vmax when operating module Reference assembly guidelines for recommended installation
387001741 价格&库存
很抱歉,暂时无法提供与“387001741”相匹配的价格&库存,您可以联系我们找货
