430553-502
430553-502
    LAIRD(莱尔德)
    ET20,65,F2A,1312,11,W2.25
430553-502 数据手册
A The HiTemp ET Series of Thermoelectric Modules (TEMs) are designed to operate in high temperature environments. This product line is available in multiple configurations and is ideal for applications that operate in temperatures above 80°C. Assembled with Bismuth Telluride semiconductor material, thermally conductive Aluminum Oxide ceramics, and high-temperature solder construction, the ET Series is designed for higher current and larger heat-pumping applications. ▪ ▪ ▪ ▪ ▪ Hot Side Temperature (°C) Qmax (W) Delta Tmax (°C) Imax (Amps) Vmax (Volts) Module Resistance (Ohms) 11 RTV Epoxy Automotive cooling Telecom cooling Outdoor environments Medical heating/cooling 85 10.6 87 2.0 9.6 4.46 0.096” ± 0.002” RT EP ▪ ▪ ▪ ▪ High-temperature operation Reliable solid state No sound or vibration Environmentally-friendly RoHS-compliant Clear Black 0.002”/0.002” -60 to +204 °C -55 to +150 °C 110 10.8 94 2.0 10.4 4.94 Lapped Lapped 2.25” Non-corrosive, silicone adhesive Low density syntactic foam epoxy encapsulant PERFORMANCE CURVES AT Th = 85° C MECHANICAL DRAWING ▪ Maximum Operating Temperature: 150°C ▪ Do not exceed Imax or Vmax when operating module ▪ Reference assembly guidelines for recommended installation
430553-502 价格&库存
很抱歉,暂时无法提供与“430553-502”相匹配的价格&库存,您可以联系我们找货
