157005297
157005297
    LAIRD(莱尔德)
    ET25,12,F2,6262,TA,RT,W4.5
157005297 数据手册
A The HiTemp ET Series of Thermoelectric Modules (TEMs) are designed to operate in high temperature environments. This product line is available in multiple configurations and is ideal for applications that operate in temperatures above 80°C. Assembled with Bismuth Telluride semiconductor material, thermally conductive Aluminum Oxide ceramics, and high-temperature solder construction, the ET Series is designed for higher current and larger heat-pumping applications. ▪ ▪ ▪ ▪ ▪ Hot Side Temperature (°C) Qmax (W) Delta Tmax (°C) Imax (Amps) Vmax (Volts) Module Resistance (Ohms) TA TB RTV Epoxy Automotive cooling Telecom cooling Outdoor environments Medical heating/cooling 85 258 87 25 18.6 0.70 0.161” ±0.010” 0.161” ±0.0005” RT EP ▪ ▪ ▪ ▪ High-temperature operation Reliable solid state No sound or vibration Environmentally-friendly RoHS-compliant Clear Black 0.001”/0.001” 0.0005”/0.0005” -60 to +204 °C -55 to +150 °C 110 265 94 25 20.3 0.77 Lapped Lapped Lapped Lapped 4.5” 4.5” Non-corrosive, silicone adhesive Low density syntactic foam epoxy encapsulant PERFORMANCE CURVES AT Th = 85° C MECHANICAL DRAWING ▪ Maximum Operating Temperature: 150°C ▪ Do not exceed Imax or Vmax when operating module ▪ Reference assembly guidelines for recommended installation
157005297 价格&库存
很抱歉,暂时无法提供与“157005297”相匹配的价格&库存,您可以联系我们找货
