SDC-MSD40NBT
SDC-MSD40NBT
    LAIRD(莱尔德)
    SMD60
    802.11A/B/G/N MINI SDIO MODULE
SDC-MSD40NBT 数据手册
A Datasheet SDC-MSD40NBT Version 5.6 MSD40NBT Datasheet REVISION HISTORY Version 1.0 1.1 1.2 1.3 Rev. Date 08/01/11 08/08/11 08/26/11 10/05/11 1.4 1.5 10/27/11 12/01/11 1.6 12/02/11 1.7 1.8 1.9 1.10 12/23/11 01/03/12 02/08/12 02/13/12 1.11 02/16/12 2.0 2.1 2.2 2.3 3.0 6/29/12 7/5/12 7/11/12 8/15/12 10/15/12 3.1 12/4/12 4.0 4.1 4.2 4.3 1/29/12 1/30/13 17 May 2013 11 July 2013 4.4 4.5 4.6 4.7 20 Sept 2013 11 Oct 2013 26 Feb 2014 19 Mar 2014 4.8 4.9 5.0 5.1 5.2 5.3 5.4 5.5 5.6 20 Oct 2014 19 Oct 2015 12 Aug 2016 16 Sept 2016 21 Feb 2017 09 May 2017 05 June 2017 07 June 2017 20 June 2017 Change Description Initial Release Updated I/O information for select pins in the Pin table Added PCM Timing information Added BT/antenna note, MSD30AG/MSD40NBT Pin Comparison table, MSD40NBT/T-Board image, MSD40NBT schematic Added PCM defaults General edits including: revisions to PIN table, finalized specifications data, added Integration Consideration section Updated the MSD40NBT schematic and current Consumption numbers in the Specifications table; Added series resistors information to the “Integration Considerations” section and added product image Added revised mechanical drawing Updated Specifications table Added pin note and power notes Updated mechanical drawing with new side view measurement New product photo and new T-Board photo with Rev. 6 device Updated mechanical drawings spacer image and transmit power numbers in the Specs table Updated BT Transmit Power Updated Receiver Sensitivity values Updated notes regarding CMD pull-ups Updated Operating Temperature Updated format (converted to Laird) and Mounting section with revised spacer information; Added AS/NZS (Australia, New Zealand) certifications; Changed pin name of Pin 12 and updated AS/NZS links Made corrections to “Recommended Operating Conditions and DC Electrical Characteristics” table Updated Receive Sensitivity Data Updated 5GHz frequency and channel data Added BT Priority Important note to the Block Diagram. Fixed ICC certification error (changed IC ID: 6616A-SDCSSD40L to IC ID: 6616A-SDCMSD40NBT) Updated Operating and Storage Temperature Removed references to summitdata.com. Added BT SIG certification section Added note regarding the following pins: CHIP_PWD_L, SYS_RST_L, BT_RST_L, VDDIO_DR Updated Hardware Schematic. Added Approved By column; updated or removed links Changed Hardware Integration Guide to Datasheet. Added the EU Declaration of Conformity Updated FCC data to 24 non-overlapping channels Updated CE/EU Declaration of Conformity section Updated CE DoC with new RED standards Fixed errors in the DoC Approved By Changed EN 301 893 v2.1.0 (2017-03) to EN 301 893 v2.1.1 (2017-05) Tom Smith Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 2 © Copyright 2017 Laird. All Rights Reserved Dale Chapman Sue White Jonathan Kaye Andrew Chen Andrew Chen Sue White Sue White Sue White Jay White Maggie Teng Tom Smith Maggie Teng Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 MSD40NBT Datasheet CONTENTS 1 Scope ..................................................................................................................................................................4 2 Operational Description .....................................................................................................................................4 3 Block Diagram .....................................................................................................................................................5 4 Specifications ......................................................................................................................................................5 5 Recommended Operating Conditions and DC Electrical Characteristics ........................................................ 10 6 5.1.1 SDIO Timing Requirements.............................................................................................................. 11 5.1.2 UART Timing Requirements............................................................................................................. 12 5.1.3 PCM Interface Timing ...................................................................................................................... 12 5.1.4 PCM Defaults ................................................................................................................................... 14 Pin Definitions ................................................................................................................................................. 18 6.1.1 Control Signal Timing Diagrams....................................................................................................... 21 6.2 MSD30AG and MSD40NBT Pin Comparison Table .................................................................................. 22 6.3 Integration Considerations ...................................................................................................................... 23 7 Mechanical Specifications ............................................................................................................................... 24 7.1 Connector Overview ................................................................................................................................ 24 7.1.1 7.2 MSD40NBT Attached to T-Board ..................................................................................................... 24 Mounting ................................................................................................................................................. 25 8 RF Layout Design Guidelines ........................................................................................................................... 25 9 Regulatory ....................................................................................................................................................... 25 9.1 Certified Antennas ................................................................................................................................... 25 9.2 Documentation Requirements ................................................................................................................ 26 9.2.1 FCC ................................................................................................................................................... 26 9.2.2 Industry Canada ............................................................................................................................... 27 9.2.3 European Union ............................................................................................................................... 29 10 Bluetooth SIG Approvals.............................................................................................................................. 33 10.1 Subsystem Combinations ........................................................................................................................ 33 10.2 Assumptions ............................................................................................................................................ 33 11 Additional Assistance................................................................................................................................... 34 12 Appendix A: Schematic ................................................................................................................................ 35 Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 3 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 MSD40NBT Datasheet 1 SCOPE This document describes key hardware aspects of the SDC-MSD40NBT radio module. This document is intended to assist device manufacturers and related parties with the integration of this radio into their host devices. Data in this document is drawn from a number of sources and includes information found in the Broadcom BCM4329 data sheet issued in June of 2009. Contact Laird or visit the MSD40NBT page of the Laird website for the newest version of this document. 2 OPERATIONAL DESCRIPTION This device is an SDC-MSD40NBT radio module which supports IEEE 802.11a/b/g/n standards via an SDIO (Secure Digital Input/Output) interface and Bluetooth version 2.1 via a serial UART (Universal Asynchronous Receiver/Transmitter) interface. The radio operates in unlicensed portions of the 2.4 GHz and 5 GHz radio frequency spectrum. The device is compliant with IEEE 802.11a, 802.11b, 802.11g, and 802.11n standards using Direct Sequence Spread Spectrum (DSSS) and Orthogonal Frequency Division Multiplexing (OFDM), and supports Bluetooth 2.1 using Frequency Hopping Spread Spectrum (FHSS). The device supports all 802.11a, 802.11b, 802.11g, 802.11n, and Bluetooth data rates and automatically adjusts data rates and operational modes based on various environmental factors. When operating on channels in the UNII-2 and UNII-2 Extended bands that are in the 5GHz portion of the frequency spectrum and are subject to Dynamic Frequency Selection requirements, the SDC-MSD40NBT fully conforms to applicable regulatory requirements. In the event that specified types of radar are detected by the network infrastructure, the SDC-MSD40NBT fully conforms to commands from the infrastructure for radar avoidance. The SDC-MSD40NBT interfaces to host devices via a 60-pin connector. The device is based on the Broadcom BCM4329chip which is an integrated device providing a Media Access Controller (MAC), a Physical Layer Controller (PHY or baseband processor), and fully integrated dual-band radio transceiver. To maximize operational range, the SDC-MSD40NBT incorporates a 5 GHz power amplifier (PA) to increase transmit power. The frequency stability for both 2.4 GHz (802.11b and 802.11g) and 5 GHz (802.11a) operation is +/- 20 ppm. The SDC-MSD40NBT has its own RF shielding and does not require shielding provided by the host device into which it is installed in order to maintain compliance with applicable regulatory standards. As such, the device may be tested in a standalone configuration via an extender card. The device buffers all data inputs so that it will comply with all applicable regulations even in the presence of over-modulated input from the host device. Similarly, the SDC-SSD40NBT incorporates power regulation to comply with all applicable regulations even when receiving excess power from the host device. The SDC-MSD40NBTprovides two unique U.FL type antenna connectors to support dual band transmit and receive diversity. Supported host device antenna types include dipole and monopole antennas. Regulatory operational requirements are included with this document and may be incorporated into the operating manual of any device into which the SDC-MSD40NBT is installed. The SDC-MSD40NBT is designed for installation into mobile devices such as vehicle mount data terminals (which typically operate at distances greater than 20 cm from the human body) and portable devices such as handheld data terminals (which typically Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 4 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 MSD40NBT Datasheet operate at distances less than 20 cm from the human body). See “Documentation Requirements” for more information. 3 BLOCK DIAGRAM Note: Transmitter frequencies for Wi-Fi are 2412-2462 MHz and 5180-5805 MHz. Transmitter frequencies for BT are 2402-2480 MHz. Note: BT functions on the AUX port and not on the Main port. For Wi-Fi and BT single-antenna implementations, the AUX port must be used. IMPORTANT: When BT is transmitting high priority traffic (such as during a scan and/or when sending audio traffic) Wi-Fi receive is sent to the main antenna port (even when set to AUX only). When high priority transmission ends, Wi-Fi receive functionality returns to the AUX port (when set to AUX only). For optimal Wi-Fi performance, we recommend that you populate both the Main and the AUX ports with an antenna. 4 SPECIFICATIONS Table 1: Specifications Feature Physical Interface Wi-Fi Interface Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless Description Molex 54722-0607 60-pin connector (mates to Molex 55560-0607 60-pin connector) 1-bit or 4-bit Secure Digital I/O 5 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 MSD40NBT Datasheet Feature Bluetooth Interface Antenna Interface Main Chip Description Host Controller Interface (HCI) using High Speed UART 2 Hirose U.FL connectors for dual-band antenna diversity IMPORTANT: When using a single antenna, it MUST be connected to the Auxiliary (AUX) port. BT functions on the AUX port and not the Main port. For WiFi/BT single-antenna implementations, the AUX port must be used. Broadcom BCM4329 Input Voltage Requirements I/O Signaling Voltage 3.3 VDC ± 10% (core) 3.3 VDC ± 10% Average Current Consumption, VDDIO = 3.3 volts (At maximum transmit power setting) 802.11a (with BT in standby) Transmit: 282 mA (931 mW) Receive: 92 mA (304 mW) Standby: TBD 802.11b (with BT in standby) Transmit: 314 mA (1036 mW) Receive: 92 mA (304 mW) Standby: TBD 802.11g (with BT in standby) Transmit: 288 mA (950 mW) Receive: 92 mA (304 mW) Standby: TBD 802.11n (2.4 GHz) (with BT in standby) Transmit: 292 mA (964 mW) Receive: 92 mA (304 mW) Standby: TBD 802.11n (5 GHz) (with BT in standby) Transmit: 270 mA (891 mW) Receive: 92 mA (304 mW) Standby: TBD Bluetooth (with Wi-Fi in standby) Transmit: TBD mA (TBD mW) Receive: TBD mA (TBD mW) Note: Standby refers to the radio operating in PM1 powersave mode. Operating Temperature Operating Humidity Storage Temperature Storage Humidity Maximum Electrostatic Discharge Length Width Thickness Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless -30° to 80°C (-22° to 176°F) 10 to 90% (non-condensing) -30° to 85°C (-22° to 185°F) 10 to 90% (non-condensing) 8 kV 32 mm (1.26 in.) 22 mm (0.87 in.) 5.05mm (0.17 in.) 6 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 MSD40NBT Datasheet Feature Weight Mounting Wi-Fi Media Bluetooth Media Wi-Fi Media Access Protocol Network Architecture Types Wi-Fi Standards Bluetooth Standards Wi-Fi Data Rates Supported Wi-Fi Modulation 802.11n Spatial Streams Supported Bluetooth Data Rates Bluetooth Modulation Supported Regulatory Domains Wi-Fi and Bluetooth 2.4 GHz Frequency Bands Description 3.0 g (0.11 oz.) 60-pin connector, mounting holes (M2 screws) Direct Sequence-Spread Spectrum (DSSS) Complementary Code Keying (CCK) Orthogonal Frequency Divisional Multiplexing (OFDM) Frequency Hopping Spread Spectrum (FSSS) Carrier sense multiple access with collision avoidance (CSMA/CA) Infrastructure and ad hoc IEEE 802.11a, 802.11b, 802.11d, 802.11e, 802.11g, 802.11h, 802.11i, 802.11n Bluetooth version 2.1 with Enhanced Data Rate 802.11a (OFDM) 6, 9, 12, 18, 24, 36, 48, 54 Mbps 802.11b (DSSS, CCK) 1, 2, 5.5, 11 Mbps 802.11g (OFDM) 6, 9, 12, 18, 24, 36, 48, 54 Mbps 802.11n (OFDM, MCS 0-7) 6.5, 7.2, 13.0, 14.4, 19.5, 21.7, 26.0, 28.9, 39.0, 43.3, 52.0, 57.8, 58.5, 65.0, 72.2 Mbps BPSK @ 1, 6, 6.5, 7.2 and 9 Mbps QPSK @ 2, 5.5, 11, 12, 13, 14.4,18, 19.5 and 21.7 Mbps 16-QAM @ 24, 26, 28.9, 36, 39 and 43.3 Mbps 64-QAM @ 48, 52, 54, 57.8, 58.5, 65, and 72.2 Mbps 1 (Single Input, Single Output) 1, 2, 3 Mbps GFSK@ 1 Mbps π/4-DQPSK@ 2 Mbps 8-DPSK@ 3 Mbps FCC (Americas, Parts of Asia, and Middle East) ETSI (Europe, Middle East, Africa, and Parts of Asia) MIC (Japan) (formerly TELEC) KC (Korea) (formerly KCC) ETSI: 2.4 GHz to 2.483 GHz FCC: 2.4 GHz to 2.483 GHz MIC (Japan): 2.4 GHz to 2.495 GHz KC: 2.4 GHz to 2.483 GHz Wi-Fi 2.4 GHz Operating Channels ETSI:13 (3 non-overlapping) FCC:11 (3 non-overlapping) 5 GHz Frequency Bands ETSI 5.15 GHz to 5.35 GHz 5.47 GHz to 5.725 GHz FCC 5.15 GHz to 5.35 GHz 5.47 GHz to 5.725 GHz 5.725 GHz to 5.82 GHz Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless MIC (Japan):14 (4 non-overlapping) KCC:13 (3 non-overlapping) 7 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 MSD40NBT Datasheet Feature 5 GHz Operating Channels Transmit Power Note: Transmit power varies according to individual country regulations. All values nominal, +/-2 dBm. Note: Summit 40 series radios support a single spatial stream and 20 MHz channels only. Typical Receiver Sensitivity Note: All values nominal, +/-3 dBm. Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless Description MIC (Japan) 5.15 GHz to 5.35 GHz KC 5.15 GHz to 5.35 GHz 5.725 GHz to 5.82 GHz ETSI: 19 non-overlapping FCC: 24 non-overlapping MIC (Japan): 8 non-overlapping KC: 12 non-overlapping 802.11a 6 Mbps 16 dBm (40 mW) 54 Mbps 14 dBm (25 mW) 802.11b 1 Mbps 17 dBm (50 mW) 11 Mbps 16 dBm (40 mW) 802.11g 6 Mbps 15 dBm (32 mW) 54 Mbps 13 dBm (20 mW) 802.11n (2.4 GHz) 6.5 Mbps (MCS0) 15 dBm (32 mW) 65 Mbps (MCS7) 11 dBm (13 mW) 802.11n (5 GHz) 6.5 Mbps (MCS0) 16 dBm (40 mW) 65 Mbps (MCS7) 13 dBm (20 mW) Bluetooth 1 Mbps -0.5 dBm (1.1 mW) 2 Mbps -0.5 dBm (1.1 mW) 3 Mbps -0.5 dBm (1.1 mW) 802.11a: 6 Mbps -90 dBm 24 Mbps -84 dBm 54 Mbps -75 dBm (PER
SDC-MSD40NBT 价格&库存
很抱歉,暂时无法提供与“SDC-MSD40NBT”相匹配的价格&库存,您可以联系我们找货
