SDC-SSD40NBT
SDC-SSD40NBT
    LAIRD(莱尔德)
    SMD56
    802.11A/B/G/N SDIO MODULE
SDC-SSD40NBT 数据手册
A Datasheet SSD40NBT Version 4.13 SSD40NBT Datasheet REVISION HISTORY Version Date 1.0 07/29/11 1.1 1.2 1.3 08/03/11 08/05/11 08/28/11 1.4 10/06/11 1.5 10/27/11 1.6 12/01/11 1.7 12/02/11 1.8 1.9 1.10 01/03/12 02/08/12 02/17/12 2.0 4/17/12 2.2 2.3 2.4 6/29/12 7/11/12 8/15/12 3.0 4.0 1/29/13 4.1 1/30/13 4.2 17 May 2013 4.3 11 Oct 2013 4.4 26 Feb 2014 4.5 25 Mar 2014 4.6 4.7 4.8 4.9 4.10 4.11 4.12 4.13 20 Oct 2015 11 Aug 2016 21 Feb 2017 29 Mar 2017 09 May 2017 05 June 2017 07 June 2017 20 June 2017 Notes Initial Release Version Finalized mechanical drawings. Revisions to pin table (I/O) Corrected Control Signal Timing diagram and text Changed Power Type column of Pin Definitions table Added PCM Timing information Added Wi-Fi/BT power consumption numbers Added note regarding the need for an external clock (pin 47) Updated antenna port information; Added Appendix A: Schematic Added SSD30AG/SSD40NBT Pin Comparison table Added BT/AUX antenna port note Added PCM defaults. General edits including: Revisions to pin table; Finalized Specifications data Added “Integration Considerations” section Updated the MSD40NBT schematic. Updated Current Consumption numbers in the Specifications table. Added series resistors information to the “Integration Considerations” section; Added product image Updated Specification table Add pin note and power notes Updated Transmit Power numbers in the Specs table Add AS/NZS (Australia, New Zealand) certifications Changed the name of Pin 20; Updated AS/NZS links Updated BT Transmit Power Updated schematic, Certifications, Typical Receiver Sensitivity Updated Operating Temperature Updated format (converted to Laird) Added “Note” with Figure 3 Updated Receive Sensitivity data Re-added MIC frequency band and operating channel information. Updated 5Ghz channel data and frequency data Updated Operating Temperature data Added BT Priority Important note to the Block Diagram. Removed references to summitdata.com Update mechanical drawing Added BT SIG certification section Added note regarding the following pins: CHIP_PWD_L, SYS_RST_L, BT_RST_L, VDDIO_DR Fixed internal links; added Approved By column to Rev History table Changed from Hardware Integration Guide to Datasheet. Updated FCC data to 24 non-overlapping channels Updated block diagram Updated CE/EU Declaration of Conformity section Updated CE DoC with new RED standards Fixed errors in the DoC Changed EN 301 893 v2.1.0 (2017-03) to EN 301 893 v2.1.1 (2017-05) Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 2 © Copyright 2017 Laird. All Rights Reserved Approver Andrew Chen Andrew Chen Andrew Chen Andrew Chen Andrew Chen Andrew Chen Andrew Chen Andrew Chen Andrew Chen Andrew Chen Andrew Chen Andrew Chen Andrew Chen Andrew Chen Andrew Chen Sue White Andrew Chen Andrew Chen Andrew Chen Andrew Chen Jonathan Kaye Andrew Chen Sue White Sue White Jay White Andrew Chen Maggie Teng Tom Smith Maggie Teng Tom Smith Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 SSD40NBT Datasheet CONTENTS 1 Scope ..................................................................................................................................................................5 2 Operational Description .....................................................................................................................................5 3 Block Diagram .....................................................................................................................................................6 4 Specifications ......................................................................................................................................................7 5 Recommended Operating Conditions and DC Electrical Characteristics ........................................................ 12 5.1 SDIO Timing Requirements...................................................................................................................... 13 5.1.1 5.2 PCM Interface Timing .............................................................................................................................. 14 5.2.1 PCM Defaults ................................................................................................................................... 14 5.2.2 Frame Sync, Master Mode .............................................................................................................. 15 5.2.3 Short Frame Sync, Slave Mode ........................................................................................................ 16 5.2.4 Long Frame Sync, Master Mode ...................................................................................................... 17 5.2.5 Long Frame Sync, Slave Mode ......................................................................................................... 18 5.3 6 UART Timing Requirements............................................................................................................. 14 Control Signal Timing Requirements ....................................................................................................... 19 Pin Definitions ................................................................................................................................................. 20 6.1 SSD30AG and SSD40NBT Pin Comparison Table ..................................................................................... 23 6.2 Electrical Considerations ......................................................................................................................... 23 6.3 Integration Considerations ...................................................................................................................... 24 7 6.3.1 Wi-Fi................................................................................................................................................. 24 6.3.2 Bluetooth ......................................................................................................................................... 25 Mechanical Specifications ............................................................................................................................... 26 7.1 Mounting ................................................................................................................................................. 27 7.1.1 Recommendations:.......................................................................................................................... 28 8 RF Layout Design Guidelines ........................................................................................................................... 29 9 Regulatory ....................................................................................................................................................... 30 9.1 Certified Antennas ................................................................................................................................... 30 9.2 Documentation Requirements ................................................................................................................ 31 9.2.1 FCC ................................................................................................................................................... 31 9.2.2 Industry Canada ............................................................................................................................... 32 9.2.3 European Union ............................................................................................................................... 33 10 10.1 Bluetooth SIG Approvals.............................................................................................................................. 37 Subsystem Combinations ........................................................................................................................ 37 Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 3 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 SSD40NBT Datasheet 10.2 Assumptions ............................................................................................................................................ 37 10.3 Additional Assistance............................................................................................................................... 38 11 Appendix A: Schematic ................................................................................................................................ 39 Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 4 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 SSD40NBT Datasheet 1 SCOPE This document describes key hardware aspects of the Laird SSD40NBT radio module. This document is intended to assist device manufacturers and related parties with the integration of this radio into their host devices. Data in this document are drawn from a number of sources and include information found in the Broadcom BCM4329data sheet issued in June of 2009. Please contact Laird or visit the Laird to obtain the most recent version of this document: http://www.lairdtech.com/Products/SSD40NBT/ 2 OPERATIONAL DESCRIPTION This device is an SDC-SSD40NBT radio module which supports IEEE 802.11a/b/g/n standards via an SDIO (Secure Digital Input/Output) interface and Bluetooth version 2.1 via a serial UART (Universal Asynchronous Receiver/Transmitter) interface. The radio operates in unlicensed portions of the 2.4 GHz and 5 GHz radio frequency spectrum. The device is compliant with IEEE 802.11a, 802.11b,802.11g, and 802.11n standards using Direct Sequence Spread Spectrum (DSSS), Orthogonal Frequency Division Multiplexing (OFDM), and supports Bluetooth 2.1 using Frequency Hopping Spread Spectrum (FHSS). The device supports all 802.11a, 802.11b, 802.11g, 802.11n, and Bluetooth data rates and automatically adjusts data rates and operational modes based on various environmental factors. When operating on channels in the UNII-2 and UNII-2 Extended bands that are in the 5GHz portion of the frequency spectrum and are subject to Dynamic Frequency Selection requirements, the SDC-SSD40NBT fully conforms to applicable regulatory requirements. In the event that specified types of radar are detected by the network infrastructure, the SDC-SSD40NBT fully conforms to commands from the infrastructure for radar avoidance. The SDC-SSD40NBTis a System in Package (SiP) Quad Flat pack, No leads (QFN) module and interfaces to host devices via a 56-padedge connector. The device is based on the Broadcom BCM4329chip which is an integrated device providing a Media Access Controller (MAC), a Physical Layer Controller (PHY or baseband processor), and fully integrated dual-band radio transceiver. To maximize operational range, the SDC-SSD40NBT incorporates a 5 GHz power amplifier (PA) to increase transmit power. The frequency stability for both 2.4 GHz (802.11b and 802.11g) and 5 GHz (802.11a) operation is +/- 20 ppm. The SSD40NBT has its own RF shielding and does not require shielding provided by the host device into which it is installed in order to maintain compliance with applicable regulatory standards. As such, the device may be tested in a standalone configuration via an extender card. The device buffers all data inputs so that it will comply with all applicable regulations even in the presence of over-modulated input from the host device. Similarly, the SDC-SSD40NBT incorporates power regulation to comply with all applicable regulations even when receiving excess power from the host device. The SDC-SSD40NBT provides two diplexed antenna interfaces to support dual band transmit and receive diversity. Supported host device antenna types include dipole and monopole antennas. Note: When using a single antenna, it must be connected to the AUX port. BT does not function on the Main port alone. Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 5 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 SSD40NBT Datasheet Regulatory operational requirements are included with this document and may be incorporated into the operating manual of any device into which the SDC-SSD40NBT is installed. The SDC-SSD40NBT is designed for installation into mobile devices such as vehicle mount data terminals (which typically operate at distances greater than 20 cm from the human body) and portable devices such as handheld data terminals (which typically operate at distances less than 20 cm from the human body). See “Documentation Requirements” for more information. 3 BLOCK DIAGRAM Figure 1: Block Diagram Note: Transmitter frequencies for Wi-Fi are 2412-2462 MHz and 5180-5805 MHz. Transmitter frequencies for BT are 2402-2480 MHz. Note: BT functions on the AUX port and not on the Main port. For Wi-Fi and BT single-antenna implementations, the AUX port must be used. IMPORTANT: When BT is transmitting high priority traffic (such as during a scan and/or when sending audio traffic) Wi-Fi receive is sent to the main antenna port (even when set to AUX only). When high priority transmission ends, Wi-Fi receive functionality returns to the AUX port (when set to AUX only). For optimal Wi-Fi performance, we recommend that you populate both the Main and the AUX ports with an antenna. Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 6 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 SSD40NBT Datasheet 4 SPECIFICATIONS Table 1: Specifications Feature Physical Interface Wi-Fi Interface Bluetooth Interface Main Chip Input Voltage Requirements I/O Signaling Voltage Average Current Consumption, VDDIO = 3.3 volts (At maximum transmit power setting) Note: Standby refers to the radio operating in PM1 powersave mode. Operating Temperature Operating Humidity Storage Temperature Storage Humidity Maximum Electrostatic Discharge Length Width Thickness Weight Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless Description 0.4mm pitch QFN (Quad Flat Pack, No Leads) 1-bit or 4-bit Secure Digital I/O Host Controller Interface (HCI) using High Speed UART Broadcom BCM4329 3.3 VDC ± 10% (core) 1.8 to 3.3 VDC ± 10% 802.11a (with BT in standby) Transmit: 282 mA (931 mW) Receive: 92 mA (304 mW) Standby: TBD 802.11b (with BT in standby) Transmit: 314 mA (1036 mW) Receive: 92 mA (304 mW) Standby: TBD 802.11g (with BT in standby) Transmit: 288 mA (950 mW) Receive: 92 mA (304 mW) Standby: TBD 802.11n (2.4 GHz) (with BT in standby) Transmit: 292 mA (964 mW) Receive: 92 mA (304 mW) Standby: TBD 802.11n (5 GHz) (with BT in standby) Transmit: 270 mA (891 mW) Receive: 92 mA (304 mW) Standby: TBD Bluetooth (with Wi-Fi in standby) Transmit: TBD Receive: TBD -30° to 80°C (-22° to 176°F) 10 to 90% (non-condensing) -30° to 85°C (-22° to 185°F) 10 to 90% (non-condensing) 8 kV 15.0 mm (0.59”) 15.0 mm (0.59”) 2.50 mm (0.1”) 1.0 g (0.04 oz.) 7 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 SSD40NBT Datasheet Mounting Wi-Fi Media See the “Mounting” section for more information. Direct Sequence-Spread Spectrum (DSSS) Complementary Code Keying (CCK) Orthogonal Frequency Divisional Multiplexing (OFDM) Bluetooth Media Frequency Hopping Spread Spectrum (FSSS) Carrier sense multiple access with collision avoidance (CSMA/CA) Infrastructure and ad hoc IEEE 802.11a, 802.11b, 802.11d, 802.11e, 802.11g, 802.11h, 802.11i, 802.11n Wi-Fi Media Access Protocol Network Architecture Types Wi-Fi Standards Bluetooth Standards Wi-Fi Data Rates Supported Modulation 802.11n Spatial Streams Bluetooth Data Rates Supported Bluetooth Modulation Regulatory Domain Support 2.4 GHz Frequency Bands 2.4 GHz Operating Channels 5 GHz Frequency Bands Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless Bluetooth version 2.1 with Enhanced Data Rate 802.11a (OFDM) 6, 9, 12, 18, 24, 36, 48, 54 Mbps 802.11b (DSSS, CCK) 1, 2, 5.5, 11 Mbps 802.11g (OFDM) 6, 9, 12, 18, 24, 36, 48, 54 Mbps 802.11n (OFDM, MCS 0-7) 6.5, 7.2, 13.0, 14.4, 19.5, 21.7, 26.0, 28.9, 39.0, 43.3, 52.0, 57.8, 58.5, 65.0, 72.2 Mbps BPSK @ 1, 6, 6.5, 7.2 and 9 Mbps QPSK @ 2, 12, 13, 14.4,18, 19.5 and 21.7 Mbps CCK @ 5.5 and 11 Mbps 16-QAM @ 24, 26, 28.9, 36, 39 and 43.3 Mbps 64-QAM @ 48, 52, 54, 57.8, 58.5, 65, and 72.2 Mbps 1 (Single Input, Single Output) 1, 2, 3 Mbps GFSK@ 1 Mbps Pi/4-DQPSK@ 2 Mbps 8-DPSK@ 3 Mbps FCC (Americas, Parts of Asia, and Middle East) ETSI (Europe, Middle East, Africa, and Parts of Asia) MIC (Japan) (formerly TELEC) KC (Korea) (formerly KCC) ETSI 2.4 GHz to 2.483 GHz FCC 2.4 GHz to 2.473 GHz MIC 2.4 GHz to 2.495 GHz KCC 2.4 GHz to 2.483 GHz ETSI: 13 (3 non-overlapping) FCC: 11 (3 non-overlapping) MIC 14 (4 non-overlapping) KCC: 13 (3 non-overlapping) ETSI 8 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 SSD40NBT Datasheet 5 GHz Operating Channels Transmit Power Note: Transmit power varies according to individual country regulations. All values nominal, +/-2 dBm. Note: Laird 40 series radios support a single spatial stream and 20 MHz channels only. Typical Receiver Sensitivity Note: All values nominal, +/-3 dBm. Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 5.15 GHz to 5.35 GHz 5.47 GHz to 5.725 GHz FCC 5.15 GHz to 5.35 GHz 5.47 GHz to 5.725 GHz 5.725 GHz to 5.82 GHz MIC (Japan) 5.15 GHz to 5.35 GHz KC 5.15 GHz to 5.35 GHz 5.725 GHz to 5.82 GHz ETSI: 19 non-overlapping FCC: 24 non-overlapping MIC (Japan): 8 non-overlapping KC: 12 non-overlapping 802.11a 6 Mbps 16 dBm (40 mW) 54 Mbps 14 dBm (25 mW) 802.11b 1 Mbps 17 dBm (50 mW) 11 Mbps 16 dBm (40 mW) 802.11g 6 Mbps 15 dBm (32 mW) 54 Mbps 13 dBm (20mW) 802.11n (2.4 GHz) 6.5 Mbps (MCS0) 15 dBm (32 mW) 65 Mbps (MCS7) 11 dBm (13 mW) 802.11n (5 GHz) 6.5 Mbps (MCS0) 16 dBm (40 mW) 65 Mbps (MCS7) 13 dBm (20 mW) Bluetooth 1 Mbps 0 dBm (1mW) 2 Mbps 0 dBm (1mW) 3 Mbps 0 dBm (1mW) 802.11a: 6 Mbps -90 dBm 24 Mbps -84 dBm 54 Mbps -75 dBm (PER
SDC-SSD40NBT 价格&库存
很抱歉,暂时无法提供与“SDC-SSD40NBT”相匹配的价格&库存,您可以联系我们找货
