BC600-SA
BC600-SA
    LAIRD(莱尔德)
    BREAKOUT BOARD FOR BL600-SA INCL
BC600-SA 数据手册
A Bx600 Breakout Boards and BL600 DVK BLE Development Options for Any Hardware Budget BLUETOOTH DESIGN THAT SCALES TO YOU. Designing Laird’s BL600 into your system has never been easier. Laird now introduces the Bx600 breakout board series, joining alongside the DVK-BL600 development kit. All allow you to connect to and program the BL600 from Windows, OSX, or Linux via UwTerminalX software. The Bx600 breakout boards provide a streamlined approach for simplified BL600 prototyping in as little as a tenth of the cost. They come in three packages: basic breakout board, board with coin cell attachment, and board with coin cell attachment and USB-to-UART adapter. The DVK-BL600 contains a wider variety of hardware components such as interfaces, sensors, LEDs, and power options. THE RIGHT HARDWARE FOR YOUR DESIGN REQUIREMENT CROSS-PLATFORM SOFTWARE LETS YOU DEVELOP YOUR WAY PERSONAL SUPPORT FROM DESIGN TO MANUFACTURE Whether you need a simple prototype option or lots of sensors and interfaces for testing, Laird’s development options have you in mind. The Bx600 breakout boards are a cost-effective and direct: The BB600 has through holes for breadboarding; The BC600 includes a mounted coin cell power adapter for designing low-power solutions directly on the board; The BA600 bundles the coin cell adapter with a USB to UART adapter for power flexibility and PC testing with applications like vSP. The DVK-BL600 offers extensive onboard equipment to help you design for any application. Laird’s new UwTerminalX software takes UwTerminal to the next level, bringing smartBASIC to all desktop environments. UwTerminalX (Windows / Linux / OSX) lets you control the BL600 in command mode and compile, load, and run smartBASIC scripts on the device. Companion apps for UwTerminalX include MultiDeviceLoader, which lets you deploy a script to as many as ten devices at once, and TermNotify, which enables connection alerts and status info from the OS system tray. All of this is hosted on GitHub, so you can modify the project to meet your needs. Laird’s support team is always standing by to provide integration support, analysis, and troubleshooting for all currently supported hardware. Working in the same offices as Laird engineering, Embedded Wireless Support is your personal bridge to all of Laird’s software, experience, and expertise. Laird guarantees a fast response and is dedicated to seeing your product through design to manufacturing. And our online support center serves as an archive of many common questions, as well as hundreds of support documents and software files. Features at a Glance Use Cases BB600: Basic breakout board and pin-based power supply. Access to I/O via through-holes. Most cost-efficient access to the full BL600 Prototyping, easily add BL600 to existing design BC600: Breakout board with coin cell holder attached. Allows flexibility of power and mobile deployment for prototyping low-power solutions. Developing low-power designs (i.e. Beacons) BA600: Breakout board with coin cell holder and USB-to-UART adapter. More flexible development with a PC, especially applications like vSP. Easy PC connection for vSP / serial testing DVK-BL600: Full development board with array of sensors, LEDs, through-holes, current measurement circuit, power connectors and interfaces. Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 1 Full access to module for complete design / test Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 Bx600 Series Breakout Boards and DVK-BL600 Datasheet EXTENDED FEATURES BA600 Designed For Module Options BB600 BC600 Smaller, streamlined access to the module and easy connection into a breadboard or a header on your host device. Convenient for simply adding the BL600 into any design, enabling a faster time to market. BL600-SA Antenna Options Integrated BLE Role Power Options Peripheral only (BL600) BB600: Power Pin BC600: Coin Cell Adapter BA600: Coin Cell Adapter, USB Additional Hardware BB600: None BC600: Configuration Jumpers BA600: USB Cable, USB-to-UART Adapter, Jumpers Access to all I/O via through-hole plates, USBto-UART adapter (BA600) 1-Year Warranty Connection Interfaces Warranty DVK-BL600 Fully-featured board with sensors and interfaces for a complete development solution. Evaluate the BL600 outside of your host system with a high degree of measurability, testing, and insight. BL600-SA, BL600-SC, BL600-ST BL620-SA, BL620-SC, BL620-ST (via firmware upgrade) Integrated (-SA Modules) IPEX MHF4 (-SC Modules) Trace Pin (-ST Modules) Central (BL620) or Peripheral (BL600) DC Jack (4.5 – 5.5 V), 3xAAA batteries, or USB B cable, CR2032 Coin Cell (powers module only) Temperature sensor, voltage measurement circuit, programmable LED array and push button switches UART, JTAG, USB-to-UART Adapter, Access to all I/O via through-hole plates 1-Year Warranty PART NUMBERS BA600-0x BB600-0x BC600-0x DVK-BL600-SA/ST/SC-0x Breakout board with mounted BL600-SA module, coin cell attachment and UART-to-USB adapter Breakout board with mounted BL600-SA module Breakout board with mounted BL600-SA module and coin cell attachment Development kit for BL600 and BL620 modules Note: Update firmware on DVK-BL600 for BL620 operation. Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/bluetooth 2 V. Date Description Approved By: 1.0 23 August 2015 Initial Release Jonathan Kaye
BC600-SA 价格&库存
很抱歉,暂时无法提供与“BC600-SA”相匹配的价格&库存,您可以联系我们找货
