QPK-NRF5X-01
QPK-NRF5X-01
    LAIRD(莱尔德)
    PROGRAMMING KIT RM1XX & BL6XX
QPK-NRF5X-01 数据手册
A Programming BL6xx and RM1xx Modules with the QPK-NRF5x-01 Application Note v1.0 INTRODUCTION This document provides a step-by-step guide for upgrading the Laird BL6XX and RM1xx modules using the QPKNRF5x-01 programming board and the ARM mbed drag-and-drop method. When the QPK-NRF5x-01 is plugged into a desktop PC, it appears as a flash drive labelled MBEDv###, where ### are three decimal digits. Saving a file in that flash drive loads the firmware into the target module. You can expedite the process by either dropping the file in a graphical user interface (such as Windows Explorer) or by using the copy command in a console terminal. This guide has been tested on a Window 7 PC. REQUIREMENTS The following are required for this process:      Laird QPK-NRF5x-01 programing board 1X USB-A to USB-Micro cables (included with QPK-NRF5x-01) UwTerminalX – Available from Laird from the following URL: https://github.com/LairdCP/UwTerminalX/releases Applicable firmware package (including a .hex file) – Available from the Laird Software Download tabs: – Bluetooth modules – RM1xx modules A 10-pin flexi cable (included with QPK-NRF5x-01) OVERVIEW This guide uses the Laird RM186 to demonstrate the firmware upgrade process, but the same steps are applicable for programing any of the Laird BL6xx or RM1xx modules containing a Nordic Semiconductor nRF51 or nRF52832 microcontroller. To upgrade the module, you need a Laird DVK board or your own equivalent implementation to provide JTAG/SWD access to the module. If you are working with your own board, please refer to Table 1 for mapping JP1 on the programmer board (QPK-NRF5X) to your module pinout. Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 1 © Copyright 2015 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 Programming BL6xx and RM1xx Modules with the QPK-NRF5x-01 Application Note Initial Setup Using a DVK-RM186Development Kit To perform the initial set-up, follow these steps: 1. Configure the RM186 development kit to the following settings:  DC/USB power source switch (SW4) – USB  VCC_1V8/VCC_3V3 switch (SW5) – VCC_3V3 2. Connect USB1 of the DVK-RM186 to your PC via the included USB-A to USB Micro cable. Figure 1: RM186 development board 3. 4. 5. 6. Install the FTDI USB to Serial driver (http://www.ftdichip.com/FTDrivers.htm). Ensure that the Windows Device Manager displays a new virtual COM port for the USB to Serial adapter. Launch UwTerminalX (https://github.com/LairdCP/UwTerminalX/releases). From the Update tab in UwTerminalX, click Check for Updates to ensure you’re using the latest version of UwTerminalX with support for the RM186. 7. From the Config tab in the Device drop-down menu, select RM186/RM191 to populate the baud, parity, stop bits, data bits, and handshaking settings. If RM186/RM191 is not a selectable device because you have an older version of UwTerminalX, set the following:  Baudrate: 115200  Parity: None  Stop Bits: 1  Data Bits: 8  Handshaking: CTS/RTS Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/bluetooth 2 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0600 Programming BL6xx and RM1xx Modules with the QPK-NRF5x-01 Application Note 8. In the Port drop-down menu, select the COM port associated with your DVK-RM186. 9. At the top of the screen, click OK. CHECKING FIRMWARE VERSION Once the module has been connected, type AT I 0 to confirm you are connected to an RM186. Type AT I 3 to display the firmware version (Figure 2). If your development board is pre-programmed with an autorun application, you must manually place the RM186 module into interactive mode. To do this, follow these steps: 1. 2. 3. 4. Ensure that on J12 jumper is not fitted on pins 1-2. Ensure that jumper J10 is closed. Ensure that the DTR checkbox on the terminal tab is unchecked. Press the reset button on the module (or on UwTerminalX, check and uncheck the BREAK checkbox which results in a reset of the module). Your module should now be in interactive mode. You can confirm this by typing AT and hitting Enter. The 00 response should display. Figure 2: AT I 3 command returning the firmware version number WARNING! Upgrading the firmware clears any programs, configuration keys, or data stored on the module. Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/bluetooth 3 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0600 Programming BL6xx and RM1xx Modules with the QPK-NRF5x-01 Application Note Connecting QPK-NRF5X to DVK-RM186 To connect the QPK-NRF5X to the RM186 development kit, follow these steps: 1. Configure the QPK-NRF5X (the programmer board) as shown in Figure 3. Figure 3: QPK-NRF5X programming board 2. Using the supplied ribbon cable, connect the QPK-NRF5X (the programmer board) to the DVK-RM186 development board as shown in Figure 4. Figure 4: Connecting the programmer board to an RM186 development board Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/bluetooth 4 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0600 Programming BL6xx and RM1xx Modules with the QPK-NRF5x-01 Application Note 3. Connect USB2 of the QPK programmer board to your PC via the included USB-A to USB Micro cable. Note: There are two USB ports on the QPK board; ensure you connect to USB2. The programmer board now appears as a flash drive on your PC (labeled as MBEDvXXX); XXX is the QPKNRF5X firmware version number (Figure 5). Figure 5: The programmer board displays as a flash drive 4. Download the firmware from Laird website and extract it to your PC (Figure 6). Figure 6: Download and extract the firmware on to your PC Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/bluetooth 5 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0600 Programming BL6xx and RM1xx Modules with the QPK-NRF5x-01 Application Note Firmware Upgrade Procedure To upgrade the firmware, select the firmware .hex file and drag-and-drop it onto the new flash drive. Once the firmware upgrade is completed, the new firmware version can be verified in UwTerminalX by issuing the AT I 3 command (Figure 7). Figure 7: Verifying the new firmware version with AT I 3 command Using the QPK-NRF5X to Program the Target Board To upgrade the firmware of your module, you must bring out the following signals from the Laird RM1XX or BL6XX module:    SWDCLK nRESET/SWDIO GND Table 1 shows how to map the JP1 on the programmer board (QPK-NRF5X) to your module pinout. Table 1: Mapping the JP1 to your module pinout JP1 on QPK-NRF5X 1 2 3 Signal Name BL600/ BL620 BL652 RM186/RM191 VCC_IO nRESET/SWDIO GND NC 22 28 * NC 5 1* NC 22 21 * Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/bluetooth 6 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0600 Programming BL6xx and RM1xx Modules with the QPK-NRF5x-01 Application Note JP1 on QPK-NRF5X 4 5 6 7 8 9 10 Signal Name BL600/ BL620 BL652 RM186/RM191 SWDCLK GND NC NC NC GND NC 23 NC NC NC NC NC NC 6 NC NC NC NC NC NC 23 NC NC NC NC NC NC * Any GDN signal on the module. Note: We only tested the programing interface over a 15 cm cable. Try to keep the wiring of these signals at 15 cm or less. LOCATING THE CORRECT FIRMWARE FOR BLXX To locate the correct firmware for drag and drop upgrade, follow the following steps: 1. Go to the product page on our website. 2. Under the Software Downloads tab, select the applicable firmware version. Figure 8: Software Download tab 3. Extract the .zip file in to a folder. 4. Locate the .hex file. This is the file you need to drag and drop. Figure 9: BL652 firmware release pack with the required HEX file highlighted Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/bluetooth 7 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0600 Programming BL6xx and RM1xx Modules with the QPK-NRF5x-01 Application Note FURTHER INFORMATION Further information relating to the BL6xx or RM1xx modules that are supported by the QPK-NRF5xx programming board are available from the Laird website product pages: https://www.lairdtech.com/products/rm1xx-lora-modules https://www.lairdtech.com/products/bl600-series https://www.lairdtech.com/products/bl652-ble-module REVISION HISTORY Version 1.0 Date 27 Mar 2017 Notes Initial Release Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/bluetooth Approver Jonathan Kaye 8 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0600
QPK-NRF5X-01 价格&库存
很抱歉,暂时无法提供与“QPK-NRF5X-01”相匹配的价格&库存,您可以联系我们找货
