KT-MT0009
KT-MT0009
    LULZBOT
    步进电机 配用
KT-MT0009 数据手册
Hybrid Stepper Motor Step Angle 1.8 Resistance Accuracy +/-10% Inductance Accuracy +/-20% Temperature Rise 80DegreeC MAX. Ambient Temperature -20 ~ +50 DegreeC Shaft Radial Play 0.02MAX @ 450g-load Shaft Axial Play 0.08MAX @ 450g-load MAX Radial Force 28N @ 20mm from the flange MAX Axial Force Dielectric Strength 10N 500VAC for one minute Insulation Resistance MIN 100Mohms, 500VDC 42 mm Series (NEMA 17 size) 1.8Degree High Torque Type (+/-5%@ full step, no load) Model Rated Current Resistance Inductance Holding Leads Rotor Approx. Detent Body Voltage /Phase /Phase /Phase Torque Number Inertia Weight Torque Length Single Shaft Double Shaft LDO-42STH*** V A ohms mH Kg.cm ***25-0404A ***25-0404B 9.6 0.4 24 36 1.7 4 ***33-0956A ***33-0956B 4 0.95 4.2 2.5 1.6 6 ***33-0406A ***33-0406B 9.6 0.4 24 15 1.6 6 ***33-0316A ***33-0316B 12 0.31 38.5 21 1.6 6 ***33-1334A ***33-1334B 2.8 1.33 2.1 2.5 2.2 4 ***38-1206A ***38-1206B 4 1.2 3.3 3.2 2.6 6 ***38-0806A ***38-0806B 6 0.8 7.5 6.7 2.6 6 ***38-0406A ***38-0406B 12 0.4 30 30 2.6 6 ***38-1684A ***38-1684B 2.8 1.68 1.65 3.2 3.6 4 ***47-1206A ***47-1206B 4 1.2 3.3 2.8 3.17 6 ***47-0806A ***47-0806B 6 0.8 7.5 6.3 3.17 6 ***47-0406A ***47-0406B 12 0.4 30 25 3.17 6 ***47-1684A ***47-1684B 2.8 1.68 1.65 2.8 4.4 4 ***60-1206A ***60-1206B 7.2 1.2 6 7 6.5 6 g.cm 2 Kg g.cm mm 20 0.15 75 25 35 0.22 120 34 54 0.28 150 40 68 0.35 200 48 102 0.5 280 60 (Model format: LDO-42STH60-1206A) Note: NEMA8,11,14,15,17,23,34,43 size are available for stepper motors, and 0.9Degree Stepper is also available. URL:www.LDOmotors.com Email: marketing@LDOmotors.com Reference design, customizations available on request.
KT-MT0009 价格&库存
很抱歉,暂时无法提供与“KT-MT0009”相匹配的价格&库存,您可以联系我们找货
