B002A-DP2A2
B002A-DP2A2
    TRIPPLITE
    2-PORT DUAL-MONITOR SECURE KVM S
B002A-DP2A2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Highlights Management Software Administrative management is accomplished through the Administration and Security Management 1.2 utility. This free download (see Support tab above) provides management of user credentials, logs, EDID locking and restoring factory defaults. The Admin and Security Management 1.2 utility is available for Windows only. For managing Mac computers connected to the KVM, settings must be applied through a Windows PC. Secure KVM Switch, 2-Port, Dual-Monitor, DisplayPort, 4K, NIAP PP3.0, Audio, TAA ● Safely and securely switches between 2 isolated computers with different security levels ● Certified to NIAP/Common Criteria Protection Profile for Peripheral Sharing Switches V3.0 ● Dual-monitor support enables convenient multitasking and increased productivity ● Supports UHD resolutions up to 4K @ 30 Hz for crystal-clear video ● Complies with Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B002A-DP2A2 Applications ● Control up to 2 computers with different security levels from a single monitor/keyboard/mouse ● Protect private information, such as medical or military intelligence data, from cyberattacks System Requirements ● DisplayPort monitors ● Wired USB mouse/keyboard with no internal hub or composite device functions (wireless mouse/keyboard not supported) ● Computer with DisplayPort and USB ports ● Computer and speakers with 3.5 mm stereo audio port (optional) ● Windows, Mac, Linux or any other major operating system NIAP-certified KVM switch lets you switch between 2 computers with government- and military-level security and data protection. Features 2-Port DisplayPort KVM Switch Is Ideal for Applications That Demand Secure Networks This two-port KVM switch is recommended for any government, military, financial or healthcare environment where tight security of sensitive data is of utmost importance in a world of constantly changing cyberthreats. Each KVM port is an electronically isolated channel, making it impossible for data to be transferred between connected computers through the KVM. The dual-monitor switch supports crystal-clear Ultra HD video resolutions up to 3840 x 2160 (4K x 2K) at 30 Hz. NIAP PP3.0 Certified to Meet Today’s Top Information Assurance Standards This KVM switch is certified by NIAP (National Information Assurance Partnership), which is operated by the National Security Agency (NSA), to the latest Common Criteria Protection Profile for Peripheral Sharing Switches Version 3.0. Discrete processing paths to each connected system prevent data leakage, transfer and crosstalk between adjacent ports. Peripheral isolation enables data to flow from device to host only. Top-of-the-Line Security Features Keep Your Data Safe Special protection prevents re-programming of firmware, so the switch’s KVM logic remains unaltered. The keyboard buffer clears automatically after data transmission, ensuring no information is left stored. Plus, you can only access connected computers via buttons on the switch’s panel. Other port-switching methods, such as On-Screen Display (OSD) and Hotkey Commands, have been excluded to further ensure data integrity. Anti-Tampering Protection Prevents Physical Breeches If the housing is opened, internal anti-tamper switches will disable the unit, causing it to become inoperable and the front-panel LEDs to flash repeatedly. Seals on the enclosure will provide visual 1/4 Package Includes ● B002A-DP2A2 2-Port NIAP PP3.0-Certified DisplayPort KVM Switch ● External power supply w/NEMA 1-15P plug & 5 ft. cord (Input: 100–240V, 50/60 Hz, 0.8A; Output: 12V 2A) ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States evidence of tampering. Maintains Constant Keyboard and Mouse Emulation for Smooth No-Delay Switching Full USB device filtering ensures support for keyboard and mouse only. This KVM switch also supports secure video emulation and EDID learning, which prevents unwanted data from transmitting through the DDC lines. Both keyboard/mouse and video emulation controllers restrict discovery of newly connected peripherals or monitors during switching operations, shielding your computers from potential vulnerabilities. Accessory Cable Kits - P783-006-DP and P783-010-DP Designed specifically for the B002A-DP2A2, P783-006-DP and P783-010-DP KVM cable kits (sold separately) help eliminate unnecessary clutter and save you money by combining cables into one convenient kit. These cables comply with HDCP 2.2 and DisplayPort 1.2 standards and support USB 2.0 speeds up to 480 Mbps. TAA-Compliant for GSA Schedule Purchases The B002A-DP2A2 is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. Specifications OVERVIEW UPC Code 037332261526 Technology DisplayPort VIDEO Max Supported Video Resolution 3840 x 2160 @ 30Hz Max Supported Color Depth 36-bit Deep Color Chroma Sub Sampling 4:4:4 INPUT AC Power Adapter Plug(s) NEMA 1-15P North America AC Power Adapter Input Specs (V / Hz / A) 100-240V / 50/60Hz / 1.3A AC Power Adapter Output Specs (V / A) 12V / 3A AC Power Adapter Cord Length (ft.) 5 AC Power Adapter Cord Length (m) 1.5 Voltage Compatibility (VAC) 100; 110; 125; 127; 200; 208; 220; 230; 240 Input Frequency 50/60Hz Redundancy - Dual Power Inputs No Bus Powered No POWER Power Source Type AC Adapter 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators (x2) GREEN / PORT SELECTION, (x2) BLUE / EDID (PUSH-BUTTON), (x2) GREEN / VIDEO CONSOLE PHYSICAL Color Black Material of Construction Metal Rackmountable No Unit Dimensions (hwd / in.) 8.800 x 2.630 x 6.690 Unit Packaging Type Box Unit Weight (lbs.) 3.85 Unit Weight (kg) 1.75 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 4° to 140°F (-20° to 60°C) Relative Humidity 0% to 80%, Non-Condensing COMMUNICATIONS IP Remote Access No CONNECTIONS Number of Ports 2 PC/Server Connections DisplayPort; USB Side A - Connector 1 3.5MM (FEMALE) Side A - Connector 2 (2) DISPLAYPORT (FEMALE) Side A - Connector 3 (2) USB A (FEMALE) Side B - Connector 1 (2) 3.5MM (FEMALE) Side B - Connector 2 (4) DISPLAYPORT (FEMALE) Side B - Connector 3 (2) USB B (FEMALE) Computer Keyboard and Mouse Interface USB Computer Monitor Interface Displayport Console Keyboard and Mouse Interface USB Console Monitor Interface Displayport FEATURES & SPECIFICATIONS 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States USB Specification USB 1.1 (up to 12 Mbps) NIAP-Certified Secure Yes Number of Users 1 On-Screen Display (OSD) No Port Selection Pushbutton Displayport Specification 1.2 Driver Required No Common Access Card (CAC) Support No REMOTE ACCESS Modem Port No STANDARDS & COMPLIANCE External Power Supply Certifications CE; FCC; UL; cUL Product Compliance NIAP PP3.0; RoHS; Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B002A-DP2A2 价格&库存
很抱歉,暂时无法提供与“B002A-DP2A2”相匹配的价格&库存,您可以联系我们找货
