1000 Eaton Boulevard
Cleveland, OH 44122
United States
Highlights
Management Software
Administrative management is accomplished through the Administration and Security Management 1.2
utility. This free download (see Support tab above) provides management of user credentials, logs, EDID
locking and restoring factory defaults. The Admin and Security Management 1.2 utility is available for
Windows only. For managing Mac computers connected to the KVM, settings must be applied through a
Windows PC.
Secure KVM Switch, 2-Port, Dual Head,
DisplayPort to DisplayPort, 4K, NIAP PP4.0,
Audio, TAA
MODEL NUMBER: B002-DP2A2-N4
Safely and securely switches
between 2 isolated computers
with different security levels
Ideal for applications where tight
security of sensitive data is
vitally important
Certified to NIAP/Common
Criteria Protection Profile for
Peripheral Sharing Switches
v4.0
Supports UHD resolutions up to
4K @ 30 Hz for crystal-clear
video
Complies with Federal Trade
Agreements Act (TAA) for GSA
Schedule purchases
System Requirements
NIAP-certified KVM lets you access multiple computers from a single console while protecting data from
accidental or unauthorized transfer between them.
Features
2-Port DisplayPort KVM Switch Is Ideal for Applications That Demand Secure Networks
This KVM switch is recommended for any government, military, finance, education or healthcare
environment where tight security of sensitive data is of utmost importance in a world of constantly
changing cyberthreats. Each KVM port is an electronically isolated channel, making it impossible for data
to be transferred between connected computers through the KVM, even when the computers are of
different security levels. The dual-monitor switch supports crystal-clear Ultra HD video resolutions up to
3840 x 2160 (4K x 2K) at 30 Hz.
NIAP PP4.0 Certified to Meet Today’s Top Information Assurance Standards
This KVM switch is certified by NIAP (National Information Assurance Partnership), which is operated by
the National Security Agency (NSA), to the latest Common Criteria Protection Profile for Peripheral
Sharing Switches Version 4.0. Discrete processing paths to each connected system prevent data leakage,
transfer and crosstalk between adjacent ports. Peripheral isolation enables data to flow from device to
host only.
Top-of-the-Line Security Features Keep Your Data Safe
Special protection prevents re-programming of firmware, so the switch’s KVM logic remains unaltered.
The keyboard buffer clears automatically after data transmission, ensuring no information is left stored.
Plus, you can only access connected computers via buttons on the switch’s panel. Other port-switching
methods, such as on-screen display (OSD) and hotkey commands, have been excluded to further ensure
data integrity.
1/4
DisplayPort monitors
Wired USB mouse/keyboard
with no internal hub or
composite device functions
(wireless mouse/keyboard not
supported)
Computer with DisplayPort and
USB ports
Computer and speakers with 3.5
mm stereo audio port (optional)
Any major operating system
Package Includes
B002-DP2A2-N4 2-Port DualMonitor NIAP PP4.0-Certified
External power supply w/ NEMA
1-15P plug (Input: 100–240V,
50/60 Hz, 1.3A; Output: 12V
3A). Includes 4 interchangeable
power supply heads (US, UK,
EU & Australia)
Owner’s manual
Cleveland, OH 44122
United States
Anti-Tampering Protection Prevents Physical Breeches
If the housing is opened, internal anti-tamper switches will disable the unit, causing it to become
inoperable and the front-panel LEDs to flash repeatedly. Seals on the enclosure will provide visual
evidence of tampering.
Maintains Constant Keyboard and Mouse Emulation for Smooth No-Delay Switching
Full USB device filtering ensures support for keyboard and mouse only — no flash drives allowed. This
KVM switch also supports secure video emulation and EDID learning, which prevents unwanted data from
transmitting through the DDC lines. Both keyboard/mouse and video emulation controllers restrict
discovery of newly connected peripherals or monitors during switching operations, shielding your
computers from potential vulnerabilities.
Accessory Cable Kits - P783-006-DP and P783-010-DP
P783-006-DP and P783-010-DP KVM cable kits (sold separately) help eliminate unnecessary clutter and
save you money by combining cables into one convenient kit. These cables comply with HDCP 2.2 and
DisplayPort 1.2 standards and support USB 2.0 speeds up to 480 Mbps.
TAA-Compliant for GSA Schedule Purchases
The B002-DP2A2-N4 is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible
for GSA (General Services Administration) Schedule and other federal procurement contracts.
Specifications
OVERVIEW
UPC Code
037332274267
Technology
DisplayPort
VIDEO
Max Supported Video Resolution
3840 x 2160 @ 30Hz
Max Supported Color Depth
36-bit Deep Color
Chroma Sub Sampling
4:4:4
AUDIO
Audio Specification
Input: (2) Connector stereo 3.5 mm female Output: (1) Connector stereo 3.5 mm female
INPUT
AC Power Adapter Plug(s)
AS/NZS 3112 Australia; BS 1363 UK; CEE 7/7 Schuko; NEMA 1-15P North America
AC Power Adapter Input Specs (V /
Hz / A)
100-240V / 50/60Hz / 1.3A
AC Power Adapter Output Specs (V
/ A)
12V / 3A
AC Power Adapter Cord Length (ft.)
5
AC Power Adapter Cord Length (m)
1.5
Voltage Compatibility (VAC)
100; 110; 125; 127; 200; 208; 220; 230; 240
Input Frequency
50/60Hz
2/4
Cleveland, OH 44122
United States
Redundancy - Dual Power Inputs
No
Bus Powered
No
POWER
Power Source Type
AC Adapter
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
(x2) GREEN / PORT SELECTION/ EDID (PUSH-BUTTON), (x2) GREEN / VIDEO CONSOLE
PHYSICAL
Color
Black
Material of Construction
Metal
Rackmountable
No
Shipping Dimensions (hwd / in.)
3.90 x 9.30 x 12.00
Shipping Dimensions (hwd / cm)
9.91 x 23.62 x 30.48
Shipping Weight (lbs.)
4.41
Shipping Weight (kg)
2.00
Unit Dimensions (hwd / cm)
22.3 x 6.6 x 16.9
Unit Packaging Type
Box
Unit Weight (lbs.)
3.85
Unit Weight (kg)
1.75
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
4° to 140°F (-20° to 60°C)
Relative Humidity
0% to 80%, Non-Condensing
COMMUNICATIONS
IP Remote Access
No
CONNECTIONS
Number of Ports
2
PC/Server Connections
DisplayPort; USB
Side A - Connector 1
3.5MM (FEMALE)
Side A - Connector 2
(2) DISPLAYPORT (FEMALE)
Side A - Connector 3
(2) USB A (FEMALE)
Side B - Connector 1
(2) 3.5MM (FEMALE)
3/4
Cleveland, OH 44122
United States
Side B - Connector 2
(4) DISPLAYPORT (FEMALE)
Side B - Connector 3
(2) USB B (FEMALE)
Computer Keyboard and Mouse
Interface
USB
Computer Monitor Interface
Displayport
Console Keyboard and Mouse
Interface
USB
Console Monitor Interface
Displayport
FEATURES & SPECIFICATIONS
USB Specification
USB 1.1 (up to 12 Mbps)
NIAP-Certified Secure
Yes
Number of Users
1
On-Screen Display (OSD)
No
Port Selection
Pushbutton
Displayport Specification
1.2
HDCP Specification
2.2
Driver Required
No
Common Access Card (CAC)
Support
No
REMOTE ACCESS
Modem Port
No
STANDARDS & COMPLIANCE
External Power Supply Certifications
CE; UKCA; cUL
Product Certifications
NOM (Mexico)
Product Compliance
NIAP PP4.0; RoHS; CE (Europe); UKCA; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“B002-DP2A2-N4”相匹配的价格&库存,您可以联系我们找货
