B030-DP16-17DIP
B030-DP16-17DIP
    TRIPPLITE
    NETDIRECTOR 16-PORT DISPLAYPORT
B030-DP16-17DIP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States NetDirector 16-Port DisplayPort KVM Switch Console with 17 in. LCD, IP Remote Access, Dual Rail, 1U Rack-Mount Highlights ● Allows remote access of computers from anywhere 24/7 via LAN, WAN or Internet ● 17 in. LCD with wide display supports HD video resolutions up to 1920 x 1080 @ 60 Hz ● Dual-rail design allows LCD to stay open while keyboard/touchpad slides into the rack ● Multiple levels of password protection prevent unauthorized access to servers ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B030-DP16-17DIP Applications Access and control, either locally or remotely, up to 16 computers and servers with DisplayPort video ports DisplayPort KVM switch allows complete remote access and control of 16 DisplayPort computers or servers using one monitor, keyboard and mouse. System Requirements ● Resolution settings of all connected displays must not exceed 1920 x 1080 @ 60 Hz ● DisplayPort graphics card ● USB keyboard/mouse ports ● Windows, macOS, Linux, UNIX or Novell operating system ● DisplayPort monitor and USB keyboard/mouse (optional external console) Features Connects 16 DisplayPort Computers or Servers to a Single Monitor, Keyboard and Mouse This NetDirector® DisplayPort KVM switch combines a rack-mountable keyboard, 17-inch LCD, touchpad, built-in IP remote access and 16 DisplayPort inputs into a compact housing that occupies only 1U of rack space. Control, boot and reboot up to 16 DisplayPort computers or servers at the same time remotely 24/7. No adapters are needed for connecting DisplayPort-enabled equipment. Offers Both Local and Remote Control Options From across the room, down the street or halfway around the globe, you can access and control up to 16 connected computers or servers from any computer via LAN, WAN or Internet. Easy to install and use, the B030-DP16-17DIP lets you handle complex problems without needing to be on-site, which saves money and time. It supports IPv4, IPv6, Link Local IPv6 Address and IPv6 Stateless Auto configuration protocols. You may set the IP address manually or have it automatically assigned via DHCP server (the default method). AP Windows- and Java non-browser client applications allow the KVM switch to be remotely accessed via the network without a browser. Saves Valuable Space and Keeps Your Operating Costs Low All connected DisplayPort computers or servers share a single monitor, keyboard and mouse, which saves space in your rack or workspace. DDC emulation allows each computer’s settings to adjust automatically for optimal screen output. Eliminating the cost of buying monitors, adapters, keyboards and mice for all 16 connected devices keeps your TCO (total cost of ownership) low. 17 in. LCD Supports Crystal-Clear 1080p Video The dual-rail B030-DP16-17DIP supports high-definition video resolutions up to 1920 x 1080 (1080p) at 60 Hz. The wide display flips up to provide access to connected computers, making multitasking easier and more convenient, and folds down to prevent the console from blocking adjacent rack equipment when not in use. The LCD and the keyboard/touchpad are on separate rails, so the LCD can remain open while the keyboard/touchpad is stored out of the way, keeping the rack aisle clear. Switching Between Computers Is Fast and Easy Use the on-console push buttons, keyboard hotkey commands or multi-lingual local console On-Screen Display (OSD) to quickly toggle between connected computers. You can also use the Auto Scan feature 1/5 Package Includes ● B030-DP16-17DIP 16-Port DisplayPort KVM Switch Console ● (2) DisplayPort cables, 6 ft. ● (2) USB 2.0 A/B cables, 6 ft. ● RJ11 firmware upgrade cable ● C13 to NEMA 5-15P power cord ● Grounding wire ● CD with owner’s manual ● Quick Start Guide 1000 Eaton Boulevard Cleveland, OH 44122 United States to scan all connected computers in five-second intervals automatically. Orange LEDs indicate which computer is currently selected. Computers or servers can be quickly added or removed without having to power down the KVM switch. Also features a USB 1.1 hub port on the front of the console for the connection of a USB peripheral device such as a flash drive or external mouse. Multi-Level Password Security Keeps Your Private Data Private The B030-DP16-17DIP offers three levels of password protection (super administrator, administrator and user) to prevent unauthorized persons from gaining access to connected servers/computers. Up to 64 users can be authorized and 32 remote users logged on concurrently. Remote authentication support is provided via RADIUS, LDAP, LDAPS and MS Active Directory. The B030-DP16-17DIP also incorporates advanced encryption technologies: 56-bit DES, 168-bit 3DES, 256-bit AES, 128-bit RC4, 128-bit SSL and 1024-bit RSA. Long-Lasting Reliability and Compatibility This DisplayPort KVM switch mounts easily into 1U of space in an EIA-standard 19-inch rack with the included brackets (optional B019-000 – sold separately – allows mounting in a 2-post rack). The B030DP16-17DIP is compatible with all major operating systems, including Windows and macOS, for simple integration into your existing structure. Mac/Sun keyboard emulation also is supported. The RJ11 port allows you to upgrade the KVM switch’s firmware using the included cable. TAA-Compliant for GSA Schedule Purchases The B030-DP16-17DIP is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. Specifications OVERVIEW UPC Code 037332258717 Max CPU 16 Technology DisplayPort VIDEO Number of Monitors Supported 1 Max Supported Video Resolution 1920 x 1080 (including 1080p) @60Hz Both Local & Remote Max Number of Ports (Entire Chain) 16 Extended Mode No Mirror Mode No INPUT AC Power Adapter Plug(s) NEMA 1-15P North America AC Power Adapter Input Specs (V / Hz / A) 100-240V / 50/60Hz / 1A AC Power Adapter Cord Length (ft.) 6 AC Power Adapter Cord Length (m) 1.8 Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Input Frequency 50/60Hz 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Input Current 1A Power Input Receptacle IEC-320-C14 Redundancy - Dual Power Inputs No USER INTERFACE, ALERTS & CONTROLS LED Indicators (x16) On Line, (x16) Selected, (x1) Power, (x3) Caps/Num/Scroll Lock, (1) LCD Monitor Power Off, RJ45 Port: (x1) Link, (x1) Data Transfer PHYSICAL Color Black Material of Construction Metal; Plastic LCD Monitor (in.) 17 Rackmountable Yes Shipping Dimensions (hwd / in.) 32.68 x 26.38 x 5.51 Shipping Dimensions (hwd / cm) 83.01 x 67.01 x 14.00 Shipping Weight (lbs.) 44.10 Shipping Weight (kg) 20.00 Unit Dimensions (hwd / in.) 1.730 x 18.900 x 26.770 Unit Packaging Type Box Unit Weight (lbs.) 31 Unit Weight (kg) 14.06 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Relative Humidity 0% to 80% RH, Non-Condensing Operating Temperature 32° to 104°F (0° to 40°C) COMMUNICATIONS Hotkey Yes Port Control Push Buttons, Hotkeys, OSD, Remote Toolbar IP Remote Access Yes Network Compatibility 1000 Mbps CONNECTIONS Number of Ports 16 Daisy-Chain Port No Firmware Upgrade Port No 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States PC/Server Connections DisplayPort; USB Side A - Connector 1 (16) DISPLAYPORT (FEMALE) Side A - Connector 2 (16) USB B (FEMALE) Side B - Connector 1 DISPLAYPORT (FEMALE) Side B - Connector 2 (2) USB A (FEMALE) Side B - Connector 3 RJ45 (FEMALE) Side B - Connector 4 USB A (FEMALE) Computer Keyboard and Mouse Interface USB Computer Monitor Interface Displayport Console Keyboard and Mouse Interface USB Console Monitor Interface Displayport FEATURES & SPECIFICATIONS USB Hub Ports Yes Number of USB Hub Ports 1 USB Specification USB 1.1 (up to 12 Mbps) NIAP-Certified Secure No Number of Users 1 Autoscan (Y,N) Y On-Screen Display (OSD) Yes Port Selection GUI; Hotkey; OSD; Pushbutton Displayport Specification 1.1 HDCP Specification 1.4 Authentication Supported LDAP; LDAPS; MS Active Directory; RADIUS Autoscan Duration 1-255 seconds; User-definable (default 5 seconds) Recommended Category Cable Cat5e/6 BUILT-IN CONSOLE Console Screen Size (inches) 17 REMOTE ACCESS Modem Port No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH; Trade Agreements Act (TAA) 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B030-DP16-17DIP
1. 物料型号:B030-DP16-17DIP 2. 器件简介: - 该KVM切换器允许通过一个显示器、键盘和鼠标来访问和控制最多16台带有DisplayPort视频端口的计算机或服务器。 - 系统要求所有连接的显示设备的分辨率不得超过1920 x 1080 @ 60 Hz。 3. 引脚分配: - 包括16个DisplayPort输入端口和2个USB A端口,以及1个RJ45端口和1个USB B端口。 - 计算机键盘和鼠标接口为USB,计算机显示器接口为DisplayPort。 4. 参数特性: - 支持高达1920 x 1080 (1080p) @ 60 Hz的高清晰度视频分辨率。 - 具有本地和远程控制选项,支持通过LAN、WAN或互联网进行远程访问。 - 支持DDC仿真,自动调整计算机设置以获得最佳屏幕输出。 - 提供多级密码保护,防止未经授权的访问。 5. 功能详解: - 可以通过控制台的按钮、键盘快捷键命令或多语言本地控制台OSD在连接的计算机之间快速切换。 - 具有自动扫描功能,可以自动扫描所有连接的计算机。 - 支持远程身份验证,提供通过RADIUS、LDAP、LDAPS和MS Active Directory的远程身份验证支持。 6. 应用信息: - 适用于需要远程访问和控制多台计算机或服务器的环境,可以节省空间并降低运营成本。 7. 封装信息: - 该设备采用双轨设计,LCD显示器可以在键盘/触摸板滑入机架时保持打开状态。 - 兼容所有主要操作系统,包括Windows和macOS。
B030-DP16-17DIP 价格&库存
很抱歉,暂时无法提供与“B030-DP16-17DIP”相匹配的价格&库存,您可以联系我们找货
