B024-HU16
B024-HU16
    TRIPPLITE
    16-PORT HDMI/USB KVM SWITCH WITH
B024-HU16 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 16-Port HDMI/USB KVM Switch with Audio/Video and USB Peripheral Sharing, 1U Rack-Mount MODEL NUMBER: B024-HU16 Highlights ● Supports HD resolutions up to 1920 x 1200 (@ 60 Hz) for crystal-clear 1080p video ● Cascade up to 2 levels to control as many as 256 computers from a single console ● Built-in 2-port USB 2.0 hub lets you share USB peripherals among connected computers ● Pushbuttons, hotkeys or onscreen display allow easy toggling between computers ● Widely compatible KVM switch works with Windows, Mac and Linux operating systems Applications Controls up to 16 HDMI-enabled laptop or notebook computers using one centralized HDMI monitor and USB keyboard/mouse. ● Share the keyboard, mouse and HDMI display of a laptop or notebook computer with multiple computers ● Connect up to 16 gaming consoles, media centers and other A/V devices for a home theater system with 1080p resolution ● Save money and space by sharing USB peripherals, such as a printer and external hard drive, among all connected computers ● Control up to 256 computers by cascading 2 levels of KVM switches Features Connects 16 HDMI-Enabled Devices to a Single HDMI Monitor, Keyboard and MouseThis rackmount KVM switch lets you access, control, boot and reboot up to 16 computers or other devices with HDMI ports at the same time. In addition to desktop and notebook computers, the switch also connects up to 16 media centers, gaming systems, Blu-ray and DVD players, cable and satellite boxes, DVRs and other HDMI-enabled devices. All 16 computers share one HDMI monitor, USB keyboard and USB mouse, which saves space on your desk or workspace. Connect up to 256 Computers to One Original ConsoleYou can also cascade up to two levels of B024HU16 KVM switches, allowing centralized access to as many as 256 computers using a single monitor, keyboard and mouse. Switching Between Computers Is Fast and EasyUse the front-panel pushbuttons, hotkey commands or multi-lingual On-Screen Display (OSD) with text-based interface for quick and easy toggling between computers. Or you can use Auto Scan mode to scan all connected computers in five-second intervals automatically. Orange LEDs indicate which computer is currently selected. Cables Are Included for Fast and Simple SetupConnect your HDMI monitor, keyboard, mouse, and speakers to the switch’s console ports. Then, use the included HDMI and USB cables to connect your computers to the KVM switch. The plug-and-play B024-HU16 requires no drivers, so you can connect and use it immediately. It works with all major operating systems, including Windows, Mac and Linux. USB Hub Lets You Share Peripherals between ComputersThe built-in two-port USB 2.0 hub allows you to share USB peripherals, such as printers, hard drives, scanners, webcams and flash drives, between all connected computers. Because the USB ports operate independently, you can print documents from one computer while working on a different computer. The hub is backward compatible with USB 1.1 devices. Green LEDs indicate which computer is using the connected USB device. Transmits Crystal-Clear 1080p Video and Digital AudioThe B024-HU16 supports high-definition video resolutions up to 1920 x 1200 (including 1080p) at 60 Hz, 2.1-channel surround sound audio and USB 2.0 data transfer rates up to 480 Mbps. With independent audio switching, you can listen to music or other audio from one computer while working on a different computer. The front-panel audio jacks have priority over the rear-panel jacks. 1/5 System Requirements ● Console with HDMI monitor, USB keyboard/mouse and (optional) speakers with 3.5 mm connectors ● Computer with HDMI port, USBA port and (optional) 3.5 mm audio jack ● Windows, Mac, Sun or Linux operating system Package Includes ● B024-HU16 16-Port HDMI/USB KVM Switch, 1U ● (2) HDMI/USB KVM cable kits, 6 ft. ● Firmware upgrade cable, 6 ft. ● External power supply with C13 to NEMA 5-15P power cord (Input: 100–240V, 50/60 Hz, 1000 Eaton Boulevard Cleveland, OH 44122 United States Stack Units to Expand Your Workstation and Enhance Your ProductivityStack as many as eight B024-HU16 KVM switches to take advantage of multi-display mode. Depending on the number of stages in your stack, your installation may offer dual-display, triple-display, quad-display or multi-display scenarios, up to eight stages. Designed for Convenient Mounting with Included HardwareThe heavy-duty metal housing comes with mounting hardware for 1U installation in an EIA-standard 19-inch rack. It also allows desktop deployment on included rubber feet that help prevent the unit from sliding. The included power supply connects to any standard AC power source. TAA-Compliant for GSA Schedule PurchasesThe B024-HU16 is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. Specifications OVERVIEW UPC Code 037332251916 Max CPU 16 Technology HDMI; Stereo Audio; USB 2.0 (High Speed) VIDEO Number of Monitors Supported 1 Max Supported Video Resolution 1920 x 1200 @60Hz Max. Distance (Between any 2 Units) 15-FT Max Number of Ports (Entire Chain) 256 Extended Mode No Mirror Mode No AUDIO Audio Specification 2.1 channel surround sound INPUT AC Power Adapter Plug(s) NEMA 5-15P North America AC Power Adapter Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.7A AC Power Adapter Output Specs (V / A) 5V / 4A AC Power Adapter Cord Length (ft.) 5 AC Power Adapter Cord Length (m) 1.5 Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Input Frequency 50/60Hz 2/5 0.7A; Output: 5V 4A) ● (4) Rubber feet ● Rack-mounting hardware ● Quick Start Guide 1000 Eaton Boulevard Cleveland, OH 44122 United States Input Current 0.7A Power Input Receptacle IEC-320-C14 Redundancy - Dual Power Inputs No Bus Powered No POWER Power Source Type AC Adapter with detachable power cord USER INTERFACE, ALERTS & CONTROLS LED Indicators (x16) Connection (Dim Orange), KVM and Audio Focus (Bright Orange), Reset, Auto Scan or Firmware Upgrade Mode (Flash); (x16) USB Hub Focus (Green); (x1) Power (Dark Green) PHYSICAL Color Black Material of Construction Steel (Steel Electrodeposition Cold Common) Rackmountable Yes Shipping Dimensions (hwd / in.) 19.65 x 5.24 x 12.76 Shipping Dimensions (hwd / cm) 49.91 x 13.31 x 32.41 Shipping Weight (lbs.) 14.77 Shipping Weight (kg) 6.70 Unit Dimensions (hwd / in.) 17.020 x 10.100 x 1.720 Unit Packaging Type Box Unit Weight (lbs.) 8.8 Unit Weight (kg) 3.99 ENVIRONMENTAL Operating Temperature Range 32° to 122°F (0° to 50°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Relative Humidity 0% to 80% RH, Non-Condensing Operating Temperature 32° to 122°F (0° to 50°C) COMMUNICATIONS Hotkey Yes Port Control Push Buttons, Hotkeys, OSD IP Remote Access No CONNECTIONS Number of Ports 16 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Daisy-Chain Port No Firmware Upgrade Port No PC/Server Connections HDMI; USB Side A - Connector 1 (16) HDMI (FEMALE) Side A - Connector 2 (16) USB B (FEMALE) Side A - Connector 3 (16) 3.5MM (FEMALE) Side B - Connector 1 (1) HDMI (FEMALE) Side B - Connector 2 (4) USB A (FEMALE) Side B - Connector 3 (2) 3.5MM (FEMALE) Side B - Connector 4 (1) RJ11 (FEMALE) Computer Keyboard and Mouse Interface USB Computer Monitor Interface HDMI Console Keyboard and Mouse Interface USB Console Monitor Interface HDMI PORT EXPANSION Daisy-chainable or Cascadable Cascadable FEATURES & SPECIFICATIONS USB Hub Ports Yes Number of USB Hub Ports 2 USB Specification USB 2.0 (up to 480 Mbps) NIAP-Certified Secure No Number of Users 4 On-Screen Display (OSD) Yes Port Selection Pushbutton; Hotkey; OSD HDCP Specification 1.4 STANDARDS & COMPLIANCE Product Compliance RoHS; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B024-HU16 价格&库存
很抱歉,暂时无法提供与“B024-HU16”相匹配的价格&库存,您可以联系我们找货
