B093-004-2E4U
B093-004-2E4U
    TRIPPLITE
    4-PORT CONSOLE SERVER WITH DUAL
B093-004-2E4U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port Console Server with Dual GB NIC, 4Gb Flash and 4 USB Ports Highlights ● Manage routers, UPS systems and other serial-based equipment from anywhere at any time 24/7 ● Validated to meet FIPS 140-2 standards to ensure utmost protection of private data ● Dual Gigabit Ethernet ports for primary network connection and automatic failover ● Designed for standard Cat5e/6 patch cable when connecting to Cisco devices ● Easy installation on desktop or 19 in. racks using included mounting hardware MODEL NUMBER: B093-004-2E4U Applications Remotely monitor, access and control serial-based networking equipment from anywhere through one highly secure gateway. Features Access All Your Serial and Network Devices from Anywhere in the WorldThe B093-004-2E4U serial console server provides secure in-band (primary network) and out-of-band (alternate channel) remote access to serial- and network-connected routers, network switches, firewalls, PBX systems, UPS systems, PDUs and other devices. It offers reliable network connectivity with dual Gigabit primary and failover Ethernet ports. You can use it in a wide variety of applications, including wiring closets, branch offices, point-of-sale and other remote sites where quick resolution of network issues is imperative. Simple and Flexible AccessibilityFour serial RS-232 console ports are configured to use standard Cat5e/6 patch cable when connecting to Cisco devices. They integrate with industry-standard directory servers using TACACS+, RADIUS, LDAP and Kerberos authentication. Provides 4 Gb of internal NAND flash memory. Connect an External Modem for Out-of-Band AccessConnect one of the four USB ports to an external Multitech MT9234MU-CDC-XT or US Robotics USR5637 USB modem (sold separately) to receive out-ofband (alternate channel) access when remote sites experience a network outage. Router/GatewayEach gateway can port forward to an unlimited number of locally networked hosts (computers, routers). This serial console switch also includes a built-in stateful firewall and embedded DHCP server to host a separate management LAN for critical traffic. The Utmost in Security to Keep Your Sensitive Data PrivateThe B093-004-2E4U supports the following security features and standards: PCI DSS 3.2, FIPS 140-2, SSL and SSH, stateful firewall, OpenVPN and IPSec VPN support. The embedded FIPS 140-2 OpenSSL cryptographic module is validated to meet FIPS 140-2 standards and has received Certificate #2473. PowerMan PDU and UPS SupportThis serial console server uses PowerMan for PDU and RPC management and Network UPS Tools for UPS system monitoring and management. It provides support for power products, so you can remotely manage power to your connected equipment. USB Console and Digital I/O (DIO) PortsFour USB 2.0 console ports allow connection to newer devices with USB console ports, such as a wide variety of PDUs and UPS systems with WEBCARDLX and LX Platform remote management cards. Two DIO ports are included for connecting compatible devices, such 1/4 ● Securely access and control routers, switches, firewalls and other serial-connected devices in your data center 24/7 ● Manage diverse server and device platforms using a network connection ● Oversee IT infrastructure remotely via network ● Troubleshoot equipment issues without spending time/money traveling to remote locations Package Includes ● B093-004-2E4U 4-Port Console Server with Dual GB NIC, 4Gb Flash and 4 USB Ports ● Terminal block ● DB9F to RJ45 crossover serial adapter ● External power supply w/4 ft. cord (Input: 100–240V, 50/60 Hz, 0.4A; Output: 12V 1.25A) ● (4) International plug adapters (North America, Europe, U.K., Australia) ● Rack-mounting hardware ● (4) Rubber feet ● Quick Start Guide 1000 Eaton Boulevard Cleveland, OH 44122 United States as drive relays and alarms. Compact Design for Convenient MountingThe heavy-duty steel housing comes with mounting brackets for easy installation in an EIA-standard 19-inch rack. Its fanless form factor also allows desktop deployment on four included rubber feet that help prevent the unit from sliding. TAA-Compliant for GSA Schedule PurchasesThis serial console server is compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. 4-Year Warranty and Environmentally Responsible DesignThe B093-004-2E4U comes with a 4-year warranty. It’s manufactured in compliance with strict RoHS specifications. Specifications OVERVIEW UPC Code 037332209290 Multi-User Yes INPUT AC Power Adapter Plug(s) NEMA 1-15P North America; CEE 7/16 Schuko; BS 1363 UK; AS/NZS 3112 Australia AC Power Adapter Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.4A AC Power Adapter Output Specs (V / A) 12V / 1.25A AC Power Adapter Cord Length (ft.) 4.0 AC Power Adapter Cord Length (m) 1.2 Maximum Input Amps 0.3 Voltage Compatibility (VAC) 100; 110; 120; 127; 200; 208; 220; 230; 240 Redundancy - Dual Power Inputs No Bus Powered No POWER Power Source Type AC Adapter Power Consumption (Watts) 11.5 USER INTERFACE, ALERTS & CONTROLS LED Indicators 7 LED's for Power, Heartbeat-Firmware Running, Serial Connectivity and Network Ports PHYSICAL Color Black Material of Construction Metal Rackmountable Yes 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 4.10 x 7.30 x 9.30 Shipping Dimensions (hwd / cm) 10.41 x 18.54 x 23.62 Shipping Weight (lbs.) 2.40 Shipping Weight (kg) 1.09 Unit Dimensions (hwd / in.) 1.400 x 5.100 x 4.700 Unit Dimensions (hwd / cm) 3.556 x 16.51 x 10.16 Unit Packaging Type Box Unit Weight (lbs.) 1.3 Unit Weight (kg) 0.59 ENVIRONMENTAL Operating Temperature Range -13° to 140°F (-25° to 60°C) Storage Temperature Range -40° to 167°F (-40° to 75°C) Relative Humidity 5% to 90% RH, Non-Condensing BTUs 39.2 BTU/Hr COMMUNICATIONS IP Remote Access Yes Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3; 802.3ab; 802.3ad CONNECTIONS Number of Ports 4 Side A - Connector 1 (2) RJ45 (FEMALE) Side B - Connector 1 RJ45 (FEMALE); USB A (FEMALE) FEATURES & SPECIFICATIONS USB Specification USB 2.0 (up to 480 Mbps) IP68 Rated No IP20 Rated No On-Screen Display (OSD) No Port Selection GUI Driver Required No Authentication Supported RADIUS; LDAP; TACACS Common Access Card (CAC) Support No REMOTE ACCESS 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Modem Port No STANDARDS & COMPLIANCE External Power Supply Certifications CE; FCC; UL; cUL; TUV; PSE; C-Tick; GS; RoHS; CB Product Certifications C-Tick (Australia); UL Listed Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 4-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B093-004-2E4U 价格&库存
很抱歉,暂时无法提供与“B093-004-2E4U”相匹配的价格&库存,您可以联系我们找货
