1000 Eaton Boulevard
Cleveland, OH 44122
United States
DIN Rail-Mounting Bracket for Digital Signage,
Version 2 - 65 mm Mounting Distance
MODEL NUMBER: B110-DIN-02
Highlights
Durable U bracket and rail clip
mount firmly to any standard 35
mm DIN rail
Holds digital signage device
securely in place to prevent
unwanted movement
Easy to mount in just a few
minutes, so you can get your
system up and running quickly
Fits digital signage components
with mounting holes spaced 65
mm apart
Includes all necessary mounting
hardware for immediate DIN rail
installation
Applications
DIN rail bracket securely mounts select Tripp Lite extenders and other digital signage devices to a
standard 35 mm DIN rail.
System Requirements
Features
DIN Mounting Bracket Ideal for Attaching Your Digital Signage Components to a DIN RailThis black
aluminum DIN bracket is designed for securely mounting splitters, extenders and other select digital
signage devices to any standard 35 mm DIN rail. Consisting of a durable U bracket and rail clip, the B110DIN-02 firmly attaches to both lips of the DIN rail to prevent your mounted equipment from being jostled
and connected cables from coming loose. It’s an ideal accessory for setting up a digital signage system in
restaurants, offices, banks, hotels, schools, doctor’s offices and a wide range of retail establishments.
Simple Mounting Process Takes Just a Few MinutesJust use the included screws to attach the
aluminum U bracket to the compatible device. Attach the aluminum rail clip to the bracket, and securely
mount the unit on a 35 mm DIN rail, making sure the spring goes over the rail’s top lip.
Compatible with a Wide Range of Digital Signage DevicesThis DIN rail-mounting bracket attaches to
units with mounting holes spaced 65 millimeters apart. Select equipment includes the B126-Series, B130Series, B132-Series and BHDBT-Series of transmitters, receivers and extenders.
Lifetime WarrantyThe B110-DIN-02 is backed by a lifetime warranty, ensuring reliability and
performance.
Specifications
OVERVIEW
UPC Code
037332213914
Product Type
Mounting Bracket
Accessory Type
Mounting Bracket
Technology
A/V over IP
1/2
Mount a Tripp Lite transmitter,
receiver or extender to a 35 mm
DIN rail in a digital signage
system
Select digital signage device,
including B126-, B130-, B132and BHDBT-Series
Package Includes
U bracket
DIN rail clip
(2) DIN rail screws
(2) M3 x 5 mm mounting screws
Installation guide
Cleveland, OH 44122
United States
Accessory Class
Audio Video Accessories
PHYSICAL
Color
Black
Material of Construction
Aluminum
Rackmountable
No
Shipping Dimensions (hwd / in.)
4.72 x 3.14 x 0.98
Shipping Dimensions (hwd / cm)
12.00 x 8.00 x 2.50
Shipping Weight (lbs.)
0.16
Shipping Weight (kg)
0.07
Unit Packaging Type
Box
FEATURES & SPECIFICATIONS
IP68 Rated
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“B110-DIN-02”相匹配的价格&库存,您可以联系我们找货
