B110-SP-POE
B110-SP-POE
    TRIPPLITE
    IN-LINE POE SURGE PROTECTOR FOR
B110-SP-POE 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States In-Line PoE Surge Protector - 1 Gbps, Cat5e/6, Metal Case, IEC Compliant, TAA MODEL NUMBER: B110-SP-POE Highlights ● Easy to connect between PoE source and device using standard Cat5/5e/6 cabling ● Rapid reaction time under 1 ns helps prevent damage from power surges ● Supports 802.3af/802.3at IEEE standards and data transmission speeds up to 1 Gbps ● Plug-and-play operation with no software required for easy, immediate installation ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Applications Protect a Power over Ethernet (PoE) device’s inputs and outputs against damage from electrostatic discharge or power surge Use in your digital signage network to protect Power over Ethernet (PoE) equipment from surges, ESD and cable discharge events. Package Includes ● B110-SP-POE In-Line 1G PoE Surge Protector ● Grounding wire, 1 ft. ● (4) Mounting screws ● (4) Screw anchors ● Grounding wire screw ● Quick Start Guide Features In-Line Surge Protector Keeps Your Power Over Ethernet (PoE) Equipment Safe Ideal for home/corporate security systems, home theaters, trade shows and other digital signage applications, the B110-SP-POE protects connected equipment from damage caused by electrostatic discharge (ESD) and cable discharge events. Just connect it between your source and network equipment using Cat5/5e/6 cables, such as N001-Series snagless patch cables (sold separately). Note: two B110SP-POE surge protectors are required to protect both source and device. Your Last Defense Against Intruding Voltage Spikes Solid-state silicon-avalanche diode technology features low clamping voltage, providing superior protection against ESD and super-fast response time under one nanosecond. Both mid-span and endspan PoE are supported. The B110-SP-POE meets the following IEC/EN regulations: IEC 61000-4-2 / IEC 61000-4-5 (ESD) 30kV (Air, Contact) and EN 61000-4-5 5kA (8/20s) / 4kV (10/700s). Ready to Use Right from the Package, So You Can Plug and Play Immediately This PoE in-line surge protector meets 802.3af and 802.3at IEEE standards, while supporting data transmission speeds up to 1 Gbps. No software, drivers or external power supply is required. The compact metal housing is designed to endure in applications where static discharge is likely to occur. Mounting hardware is included for convenient installation where needed. Be sure the distance between the B110-SP-POE and the equipment it is protecting is no more than 300 feet. TAA-Compliant for GSA Schedule Purchases The B110-SP-POE is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. Specifications OVERVIEW UPC Code 037332217875 Product Type Surge Protector 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology Cat5/5e; Cat6; PoE INPUT Input Cord Length (ft.) 0 Right-Angle Plug No Input Cord Length (m) 0.00 OUTPUT Output Receptacles Network Right-Angle Outlets No POWER Power Over Cable (PoC) Support Yes USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) No SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 0 Automatic Shut-Off No DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection Yes Telephone/DSL Protection No PHYSICAL Material of Construction Aluminium Housing Color Black Rackmountable No Shipping Dimensions (hwd / in.) 1.54 x 4.53 x 4.25 Shipping Dimensions (hwd / cm) 3.91 x 11.51 x 10.80 Shipping Weight (lbs.) 0.37 Shipping Weight (kg) 0.17 Unit Dimensions (hwd / in.) 2.630 x 3.430 x 1.060 Unit Dimensions (hwd / cm) 67 x 87 x 27 Unit Packaging Type Box Unit Weight (lbs.) 0.28 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Weight (kg) 0.13 ENVIRONMENTAL Operating Temperature Range 14° to 167°F (10° to 75°C) Storage Temperature Range -40° to 194°F (-40° to 90°C) Relative Humidity 0% to 95% RH, Non-Condensing ESD Protection 30kV (Air, Contact) Lightning Protection 5kA (8/20s), 4kV (10/700s) COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3af; 802.3at CONNECTIONS Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 RJ45 (FEMALE) FEATURES & SPECIFICATIONS Rotatable Outlets No Antimicrobial No Driver Required No Recommended Category Cable Cat5e, Cat6 Cables STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
B110-SP-POE 价格&库存
很抱歉,暂时无法提供与“B110-SP-POE”相匹配的价格&库存,您可以联系我们找货
