B118-2X4-4K-A
B118-2X4-4K-A
    TRIPPLITE
    HDMI Switch/Splitter Ultra-HD Video, Audio
B118-2X4-4K-A 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4x2 HDMI Matrix Switch/Splitter with Audio Extractor - 4K 60 Hz, IR Control, HDCP 2.2, 4:4:4 MODEL NUMBER: B118-2X4-4K-A Highlights ● Display the same video on both monitors or rotate up to 4 videos on each monitor ● Supports UHD resolutions up to 4K @ 60 Hz (4:4:4) for crystalclear video ● Built-in audio extractor produces digital and analog audio up to 7.1-channel surround ● IR remote control allows you to switch video sources from the comfort of your couch ● Plug-and-play operation with no software required for easy, immediate installation Applications Shares 4K video and 7.1-channel surround sound from as many as 4 different HDMI sources between 2 separate HDMI displays. ● Duplicate audio/video content across 2 displays or show different content on both screens in your home, classroom, retail location, conference room or trade show ● Keep your video sources in a secure location, with displays located elsewhere for viewing by the intended audience ● Rotate up to 4 different sporting events on 2 TVs in your bar or restaurant ● Create an easily updatable video board communicating dynamic information, such as a restaurant menu or a theater schedule ● Display arrivals, departures and up-to-the-minute information in an airport or train station Features HDMI Matrix Switch for Digital Signage or Other Applications with Multiple Video DisplaysThis matrix switch/splitter features four HDMI inputs and two HDMI outputs. This allows you to connect as many as four high-definition video sources, such as Blu-ray players, video game systems, Roku boxes, laptops, media servers or cable/satellite boxes, and transmit them to two high-definition televisions, projectors or monitors. The B118-2X4-4K-A is recommended for home theaters (transmit to HDTVs located in different rooms) or digital signage applications in classrooms, bars, restaurants, conference rooms, lecture halls and trade shows. Enjoy Great Flexibility in Transmitting Video to Different Displays or Even Different RoomsSend the same video image to both displays or transmit different videos and rotate among them. You can use the buttons built into the front of the unit to switch between the connected sources displayed on the two monitors. The B118-2X4-4K-A also includes an IR remote that lets you not only choose between the connected video sources, but also mute the sound and power on/off the unit. System Requirements Transmits Crystal-Clear 4K HDMI Video with 4:4:4 ColorThe B118-2X4-4K-A supports Ultra HD video resolutions up to 4K x 2K at 60 Hz, as specified in HDMI 2.0, with 36-bit Deep Color. It’s capable of carrying HDR (high dynamic range) signals, which provides a wide range of vibrant colors with richer contrast, brighter whites and deeper blacks. HDCP 2.2 compliance allows you to stream iTunes and Netflix content with no complications. This switch also supports 4:4:4 chroma subsampling for top-level PC gaming or using your HDTV as a PC monitor. Built-In Audio Extractor Lets You Control Sound, as Well as PictureTOSLINK/coaxial and RCA right/left audio ports allow you to connect an amplifier, receiver or soundbar for optical, digital or analog sound. The B118-2X4-4K-A supports 7.1-channel LPCM, DTS-HD Master Audio and Dolby TrueHD. Plug-and-Play Operation for Quick Setup and Immediate UseThe B118-2X4-4K-A works right out of the box with no software required. Use HDMI cabling (such as P569-Series high-speed cables, sold separately) to connect up to four sources and two displays. The included power supply comes with four international plug adapters (North America, Europe, United Kingdom, Australia). 1/4 ● Source devices with HDMI output (media server, Blu-ray player, satellite/cable box) ● Display devices with HDMI input (HDTV, projector, monitor) Package Includes ● B118-2X4-4K-A 2x4 HDMI Matrix Switch/Splitter ● IR remote control with battery ● External power supply (Input: 100–240V @ 50/60 Hz, 0.3A; Output: 5V 1A) ● (4) International plug adapters (North America, Europe, U.K., 1000 Eaton Boulevard Cleveland, OH 44122 United States Australia) ● Mounting Hardware ● Owner’s Manual Specifications OVERVIEW UPC Code 037332250605 Technology HDMI; IR; Toslink/SPDIF VIDEO Max Supported Video Resolution 4096 x 2160 (4K @ 60Hz) Max Supported Color Depth 36-bit Deep Color HDR Support Yes Chroma Sub Sampling 4:2:0; 4:2:2; 4:4:4 AUDIO Audio Specification 7.1/5.1/2 LPCM Channel Surround Sound INPUT AC Power Adapter Plug(s) AS/NZS 3112 Australia; BS 1363 UK; CEE 7/16 Schuko; NEMA 1-15P North America AC Power Adapter Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.3A AC Power Adapter Output Specs (V / A) 5V / 1A AC Power Adapter Cord Length (ft.) 5 AC Power Adapter Cord Length (m) 1.5 Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Bus Powered Yes Product Length (ft.) 8.46 Product Length (m) 0.71 POWER Power Source Type AC Adapter AC Adapter Input: 100-240V, 50/60Hz, 0.3A; Output: 5V, 1A, 5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 10mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States LED Indicators Red (Power), (x8) Green (Connection) PHYSICAL Color Black Material of Construction Steel Rackmountable Yes Shipping Dimensions (hwd / in.) 2.36 x 10.04 x 9.25 Shipping Dimensions (hwd / cm) 5.99 x 25.50 x 23.50 Shipping Weight (lbs.) 0.88 Shipping Weight (kg) 0.40 Unit Dimensions (hwd / in.) 0.830 x 8.460 x 2.950 Unit Packaging Type Box Unit Weight (lbs.) 0.82 Unit Weight (kg) 0.37 ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range 14° to 176°F (-10° to 80°C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing COMMUNICATIONS Port Control Push Buttons EDID Compatible No IR Remote Extension Support Yes CONNECTIONS Number of Ports 4 Side A - Connector 1 (4) HDMI (FEMALE) Side A - Connector 2 MICRO-USB B (FEMALE) Side B - Connector 1 (2) HDMI (FEMALE) Side B - Connector 2 STEREO RCA (2xRCA) (RW) Input x Output 2x4 FEATURES & SPECIFICATIONS Integrated/Removable Cable No MST Support No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Mounting Accessory Included No Multi-Resolution Support No Port Selection Pushbutton; Remote Selector HDCP Specification 2.2 Driver Required No DIN Mountable No STANDARDS & COMPLIANCE External Power Supply Certifications CE; GS; TUV; UL; cUL Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B118-2X4-4K-A 价格&库存
很抱歉,暂时无法提供与“B118-2X4-4K-A”相匹配的价格&库存,您可以联系我们找货
