B119-4X1-MV
B119-4X1-MV
    TRIPPLITE
    HDMI Switch Audio, HD Video
B119-4X1-MV 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4x1 HDMI Multi-viewer with Remote Control 1080p @ 60 Hz (HDMI 4xF/1xF) MODEL NUMBER: B119-4X1-MV Highlights ● Can display video from one, two or all four HDMI sources at the same time ● Included remote control allows you to toggle between display modes with ease ● Transmits HD picture quality at 1080p video resolutions @ 60 Hz ● Audio switches independently, so you can watch one video source and hear another ● Plug-and-play operation with no software required for easy, immediate installation Applications HDMI multi-viewer connects 4 HDMI audio/video sources and displays them simultaneously on a single HDMI TV, monitor or projector. Features HDMI Quad-Screen Multi-Viewer Connects 4 Audio/Video Sources to One HDMI Display This 4-input HDMI multi-viewer allows you to connect four separate HDMI audio/video sources to one HDMI television, projector or monitor, and then display the video feeds from all four at the same time. For instance, connect a media server, Blu-ray player, security camera and Xbox to your HDTV, and watch the video transmission from all four simultaneously with built-in IR control. Recommended for Home Theaters, Digital Signage and Other Audio/Video Applications This HDMI quad multi-viewer is ideal for home theater, digital signage, broadcasting, video conferencing and security monitoring, just to name a few applications. Plus, it helps you avoid the cost of buying additional displays for your source devices and save space by combining four monitors into one. Choose from Quad, Dual or Full-Screen Mode at the Click of a Button Use the push-button on the unit or the included remote control to select which mode to use. In addition to displaying all four video feeds simultaneously in Quad Mode, you can watch video from two source devices using Dual Mode or just one in Full-Screen Mode. Pressing another button on the unit lets you switch the audio feeds independently of the video, so you can watch video from one HDMI source and hear audio from another. The unit comes with 12 different preset display configurations. Transmits Crystal-Clear Video up to 1080p for High-Definition Presentations This HDMI multi-viewer ensures HD performance with video resolutions up to 1080p at 60 Hz (1920 x 1080). Ready to Use Right from the Package, So You Can Plug and Play Immediately The compact plug-and-play switch requires no software or drivers to download and install. Connect your devices to the HDMI ports with user-supplied HDMI cables (such as P568-Series), and plug the included external power supply (with four international plug adapters to ensure use all over the world) into an AC power source to get started. A red LED indicates the unit is receiving power, and blue LEDs indicate connected HDMI inputs. 1/4 ● Watch video from your cable box, Blu-ray player, video game console and Roku simultaneously ● Connect multiple desktop computers and laptops to one monitor to save desk space ● Monitor the premises with as many 4 security cameras connected to a single display ● Observe shots from multiple cameras during a live video broadcast ● Video conferencing with business colleagues in 4 different locations System Requirements ● Source device(s) with HDMI output ● Display device with HDMI input Package Includes ● B119-4X1-MV HDMI Quad Multi-Viewer Switch ● External power supply with 4 ft. cord (Input: 100–240V, 50/60 Hz, 0.6A; Output: 12V 2A) ● (4) International plug adapters (North America, Europe, U.K., Australia) ● Mounting hardware ● Remote control ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332213990 Product Type Splitter Device Compatibility Monitor/HDTV Technology HDMI VIDEO Max Supported Video Resolution 1920 x 1080 (1080p @ 60Hz) HDR Support Yes 3D Video Supported No AUDIO Audio Specification PCM INPUT AC Power Adapter Plug(s) AS/NZS 3112 Australia; BS 1363 UK; CEE 7/16 Schuko; NEMA 1-15P North America AC Power Adapter Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.6A AC Power Adapter Output Specs (V / A) 12V / 2A AC Power Adapter Cord Length (ft.) 4 AC Power Adapter Cord Length (m) 1.2 Voltage Compatibility (VAC) 100; 110; 120; 125; 200; 208; 220; 230; 240 POWER Power Source Type AC Adapter DC Barrel Plug OD: 5.5 x 2.1 x 10mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 10 USER INTERFACE, ALERTS & CONTROLS LED Indicators (x1) Power (Red), (x4) HDMI Input (Blue) PHYSICAL Color Black Material of Construction Steel Alloy Cable Length (ft.) 0 Cable Length (m) 0.00 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Rackmountable No Shipping Dimensions (hwd / in.) 3.15 x 7.83 x 5.83 Shipping Dimensions (hwd / cm) 8.00 x 19.89 x 14.81 Shipping Weight (lbs.) 1.50 Shipping Weight (kg) 0.68 Unit Dimensions (hwd / in.) 5.850 x 4.070 x 0.840 Unit Dimensions (hwd / cm) 14.86 x 10.34 x 2.13 Unit Dimensions (hwd / mm) 148.5 x 103.4 x 21.3 Unit Packaging Type Box Unit Weight (lbs.) 0.75 Unit Weight (kg) 0.34 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Relative Humidity 20% to 90% RH, Non-Condensing BTUs 34.12 BTU/Hr COMMUNICATIONS EDID Compatible Yes IR Remote Extension Support Yes CONNECTIONS Number of Ports 4 Side A - Connector 1 HDMI (FEMALE) Side B - Connector 1 (4) HDMI (FEMALE) Input x Output 4x1 Daisy-chainable / Cascadable No FEATURES & SPECIFICATIONS MST Support No Port Selection Pushbutton; Remote Selector HDCP Specification 1.2 Driver Required No CUSTOM Batteries included with Remote Control Yes 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE External Power Supply Certifications CE; UL; cUL Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B119-4X1-MV 价格&库存
很抱歉,暂时无法提供与“B119-4X1-MV”相匹配的价格&库存,您可以联系我们找货
B119-4X1-MV
    库存:19
