B127-002-D2H
B127-002-D2H
    TRIPPLITE
    HDMI Extender/Splitter Cat6
B127-002-D2H 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Highlights Important Note ● This product supports 4K 60 Hz 4:4:4 subsampling for HDR televisions. To ensure optimal performance, check the factory default settings on your TV: Frequency (Hz) should be set to 60 Hz. HDR feature should be enabled. HDMI input settings should be set to 2.0. UHD Deep Color should be set to ON. Supports UHD resolutions up to 4K @ 60 Hz (4:4:4) for crystalclear video ● Power over Cable (PoC) technology provides power to the receivers via Cat6 cable ● Supports DTS-HD, Dolby AC-3 and 8-channel LPCM digital audio ● Plug-and-play operation with no software required for easy, immediate installation ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases 2-Port DisplayPort to HDMI over Cat6 Splitter/Extender Kit, Transmitter/Dual Receivers, 4K 60 Hz, PoC, 125 ft., TAA MODEL NUMBER: B127-002-D2H Applications ● Connect a media server, cable/satellite box, gaming system or other home theater component to multiple largescreen 4K televisions or projectors ● Upgrade the video quality of your trade show presentation or digital signage installation in a commercial or educational setting to 4K x 2K System Requirements Splitter/receiver kit extends a 4K DisplayPort signal via Cat6 cable to 2 HDMI projectors, monitors or HDTVs up to 125 ft. away. ● Source device with DisplayPort output (media server, laptop) ● Display devices with HDMI input (HDTV, projector, monitor) Features DP to HDMI Splitter for Digital Signage or Extending Video in Schools or Trade Show BoothsThis complete 2-port transmitter and receiver system is recommended for video presentations in conference rooms, schools, trade shows, meeting facilities, houses of worship, retail settings and digital signage applications where the source and display are farther apart than conventional A/V cables allow. The B127002-D2H extends 4K video and stereo audio signals from a DisplayPort (DP) source device to two HDMI displays up to 125 feet (38.1 meters) away via user-supplied Cat6 cabling. Transmits Crystal-Clear 4K HDMI Video with Multi-Channel Audio and 4:4:4 ColorThe B127-002D2H supports Ultra HD video resolutions up to 4K x 2K (3840 x 2160) at 60 Hz, as specified in HDMI 2.0, with full, rich uncompressed DTS-HD, Dolby AC-3 and 8-channel LPCM digital audio. Built-in equalization automatically fine-tunes the image quality at the remote displays with no time-consuming manual fiddling needed. It also supports 4:4:4 chroma subsampling for top-level PC gaming or using your HDTV as a PC monitor. Built-In PoC Technology Provides Receiver Power to Avoid Bulky External Power BricksBuilt-in Power over Cable (PoC) technology powers the low-profile receivers over Cat6 cable. Green and orange LEDs on the transmitter and receivers will light up to indicate the system is receiving power and a signal is being transmitted. Plug-and-Play Operation for Quick Setup and Immediate UseThe included transmitter and receiver units work right out of the box with no software required. Mounting hardware is included for installing the units on walls, poles or 19-inch racks. Connect the transmitter to the source with a DisplayPort cable (P580-Series) and the receivers to their displays with HDMI cable (such as P568- or P569-Series). Connect the transmitter to the two receivers using Cat6 patch cable (N202-Series). 1/5 Package Includes ● Transmitter unit ● (2) Receiver units ● External power supply (Input: 100–240V) ● (4) International plug adapters (North America, Europe, U.K. and Australia) ● Mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States TAA-Compliant for GSA Schedule PurchasesThe B127-002-D2H is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. Specifications OVERVIEW UPC Code 037332239020 Product Type Extender Kit Technology DisplayPort; HDMI; Cat5/5e; Cat6; POC VIDEO Video Input DISPLAYPORT (FEMALE) Video Output HDMI (FEMALE) Max Supported Video Resolution 3840 x 2160 (4K @ 60Hz) Max 1280 x 720 (720p) Range (ft) 200 Max 1920 x 1080 (1080p) Range (ft) 200 Max 1920 x 1200 Range (ft) 150 Max 2560 x 1600 Range (ft) 150 Max 3840 x 2160 (4K@30Hz) Range (ft) 150 Max 3840 x 2160 (4K@60Hz) Range (ft) 125 Transmitter Video Input DisplayPort Transmitter - Number of Video Outputs 2 Receiver/Transceiver Video Output HDMI Receiver - Number of Video Outputs 1 Recommended Cabling Solid Wire Cat6 Cables (Tripp Lite's N202-Series) Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 Maximum Signal Range (ft) 125 Maximum Signal Range (m) 38 AUDIO Audio Input Displayport 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Audio Output HDMI Audio Specification 7.1 Channel Surround Sound, DTS-HD and Dolby TrueHD INPUT AC Power Adapter Plug(s) AS/NZS 3112 Australia; BS 1363 UK; CEE 7/16 Schuko; NEMA 1-15P North America AC Power Adapter Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.6A AC Power Adapter Output Specs (V / A) 24V / 1A AC Power Adapter Cord Length (ft.) 4.5 AC Power Adapter Cord Length (m) 1.38 Bus Powered No POWER Power Source Type AC Adapter AC Plug Type NEMA 1-15P; BS1363; CEE 7/16 Schuko; AS/NZS 3112 Power Source Transmitter end only (Included) Power Over Cable (PoC) Support Yes USER INTERFACE, ALERTS & CONTROLS LED Indicators Tx: x1 Green (Power), x2 Orange (Output 1, Output 2); Tx RJ45 port: x2 Green (Connected), x2 Orange (Activity) (x2) Rx: x1 Green (Power); Rx RJ45 port: Green (Connected), Orange (Activity) PHYSICAL Color Black Material of Construction Metal Included Mounting Accessories Wallmount Number of Displays 2 Form Factor/Mounting Options Box; Wall-mount Rackmountable Yes Receiver Unit Dimensions (hwd / in.) 1.06 x 4.53 x 2.46 Receiver Unit Weight (lbs.) 0.45 Shipping Dimensions (hwd / in.) 2.17 x 13.86 x 6.46 Shipping Dimensions (hwd / cm) 5.51 x 35.20 x 16.41 Shipping Weight (lbs.) 2.36 Shipping Weight (kg) 1.07 Transmitter Unit Dimensions (hwd / in.) 1.06 x 4.53 x 2.46 Transmitter Unit Weight (lbs.) 0.45 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Packaging Type Box Housing Metal ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0% to 85% RH, Non-Condensing COMMUNICATIONS Signal Range (ft.) 125 Signal Range (m) 38 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 2 Side A - Connector 1 (2) RJ45 (FEMALE) Side A - Connector 2 DISPLAYPORT (FEMALE) Side B - Connector 1 HDMI (FEMALE) Side B - Connector 2 RJ45 (FEMALE) Daisy-chainable / Cascadable No FEATURES & SPECIFICATIONS 10/100 Ethernet Extension Support No Built-In Equalizer Yes Displayport Specification 1.2a HDCP Specification 2.2 Driver Required No Recommended Category Cable Solid Wire Cat6 Cables (Tripp Lite's N202-Series) STANDARDS & COMPLIANCE External Power Supply Certifications CCC; CE; FCC; GS; PSE; TUV; UL; cUL Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B127-002-D2H 价格&库存
很抱歉,暂时无法提供与“B127-002-D2H”相匹配的价格&库存,您可以联系我们找货
