B127A-002-BH
B127A-002-BH
    TRIPPLITE
    2-PORT HDMI OVER CAT6 SPLITTER -
B127A-002-BH 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2-Port HDMI over Cat6 Splitter - 4K 60 Hz, HDR, 4:4:4, PoC, HDCP 2.2, 230 ft. (70.1 m), TAA MODEL NUMBER: B127A-002-BH Highlights Requires connection to B127ASeries remote receivers (sold separately)Supports 4K @ 60 Hz video resolutions (4:4:4) as specified in HDMI 2.0 Carries High Dynamic Range (HDR) signals for rich contrast and expanded color accuracyPower over Cable (PoC) technology provides power to receivers via Cat6 cableCompliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Applications Works with Tripp Lite B127A-Series receivers to extend a 4K audio/video signal 230 ft. via Cat6 cable to 2 HDMI displays. ● Extend video signals from one room to another using Cat6 cable, which can pass through conduit to meet building codes ● Gain flexibility in where the receivers are placed, with the freedom to move and relocate them away from an AC outlet ● Improve the line of sight for digital signage in a hotel, restaurant, theater, house of worship, trade show or other location Features HDMI Dual-Output Splitter Ideal for Digital Signage in Schools and Workplaces This 4K transmitter/splitter is recommended for video presentations in conference rooms, schools, trade shows, meeting facilities, houses of worship, retail settings, hotels and other digital signage applications where the source and display are farther apart than conventional A/V cables allow. Extends a 4K A/V Transmission up to 230 ft… or Even Farther The B127A-002-BH connects to B127A-Series receivers to extend 4K signals from an HDMI source to two HDMI displays up to 230 feet (70.1 meters) away via user-supplied Cat6 cabling. By adding B127A-010-H signal repeaters or B127A-110-BH transceivers (each sold separately) to the application, you can extend the signal to each connected display up to 400 feet (121.9 meters) or 460 feet (140.2 meters), respectively. Transmits Crystal-Clear 4K Video with Multi-Channel Audio, HDR and 4:4:4 Color The B127A-002-BH supports Ultra HD resolutions up to 3840 x 2160 (4K x 2K) at 60 Hz with true uncompressed 7.1-channel digital audio and Dolby TrueHD. High Dynamic Range (HDR) provides a wide range of vibrant colors with richer contrast, brighter whites and deeper blacks that pop on your 4K display. HDCP 2.2 compliance allows you to stream 4K Amazon and Netflix content with no complications. This splitter also supports 4:4:4 chroma subsampling for top-level PC gaming or using your HDTV as a PC monitor. Multi-Resolution Support Allows Mixing and Matching of Displays of Different Resolutions Say you have a brand new 4K/60 Hz HDTV in one room, but want to also connect your Blu-ray player or satellite box to an older 1080p TV in another room. The B127A-002-BH is backward compatible with 4K/30 Hz and 1080p resolutions via automatic switching, allowing each connected monitor to display video at its maximum resolution. Built-In PoC Technology Provides Receiver Power to Avoid Bulky External Power Bricks Power over Cable (PoC) technology powers the connected receivers over Cat6 cable. LEDs indicate when the system is receiving power and a signal is being transmitted. PoC lets you avoid the hassle of a bulky power brick and gives you the freedom to place the receivers where needed without worrying about finding a nearby AC outlet. 1/6 System Requirements ● Source device with HDMI output (Blu-ray player, cable box, laptop) ● Display device(s) with HDMI input (HDTV, projector, monitor) ● B127A-Series receivers, such as B127A-1A0-FH, B127A-2A0FH, B127A-1P0-PH and/or B127A-1A0-BH Package Includes ● B127A-002-BH 2-Port HDMI over Cat6 Splitter ● External power supply (Input: 100–240V, 50/60 Hz, 0.6A; Output: 24V 1A) ● (4) International plug adapters (North America, U.K., Europe, Australia) ● Mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Plug-and-Play Operation for Quick Setup and Immediate Use The splitter works right out of the package with no software required. Mounting hardware is included for installing it on a wall, pole or 19-inch rack. Connect the splitter to an HDMI source device with a usersupplied HDMI cable (such as P568- or P569-Series). Then, connect the splitter to B127A-Series remote receivers with user-supplied Cat6 cable (such as N202-Series). TAA-Compliant for GSA Schedule Purchases The B127A-002-BH is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. Specifications OVERVIEW UPC Code 037332263704 Product Type Splitter Technology Cat6; HDMI; POC Host Connector HDMI (FEMALE) VIDEO Video Input HDMI (FEMALE) Video Output HDMI (FEMALE) Number of Monitors Supported 2 Video Ports (2) RJ45 (FEMALE) Video Ports Details HDMI 2.0; HDCP 1.4; HDCP 2.2 Resolutions Supported 3840 x 2160 (4K x 2K) @ 60 Hz Max Supported Video Resolution 3840 x 2160 (4K x 2K) @ 60Hz Max. Distance (Between any 2 Units) 230 ft. (70.1 m) Max 720P Range (ft) 230 Max 1080P Range (ft) 230 Max 1920 x 1080 (1080p) Range (ft) 230 Max 2560 x 1600 Range (ft) 230 Max 3840 x 2160 (4K) Range (ft) 230 Max 3840 x 2160 (4K@30Hz) Range (ft) 230 Max 3840 x 2160 (4K@60Hz) Range (ft) 230 Maximum Distance with Booster 400 Transmitter Video Input HDMI Transmitter - Number of Video Outputs 2 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Receiver - Number of Video Outputs 2 Signal Range (ft) 230 Signal Range (m) 70 Range Extension using other Tripp Lite product 230 or 400 ft. Extended Mode Yes Extended Mode Details x2 RJ45 Ports (4K/60 Hz). When using a laptop/Macbook only the first display will be extended. The remaining display will be mirrored. Mirror Mode Yes Mirror Mode Details x2 RJ45 Ports (4K/60 Hz)When using a laptop/Macbook only the first display will be extended. The remaining display will be mirrored.When using a DVR/DVD/Blu-Ray player both displays will be mirrored. Other Tripp Lite product used to extend range B127A-010-H or B127A-110-BH Max Supported Color Depth 36-bit Deep Color HDR Support Yes 3D Video Supported Yes Chroma Sub Sampling 4:4:4 Maximum Signal Range (ft) 230 Maximum Signal Range (m) 70 AUDIO Audio Ports (2) RJ45 (FEMALE) Audio Ports Details Outputs support passthrough audio formats including LPCM2.0/5.1/7.1 Audio Input HDMI Audio Output HDMI Audio Specification True uncompressed 7.1 Channel digital audio INPUT AC Power Adapter Plug(s) AS/NZS 3112 Australia; BS 1363 UK; CEE 7/16 Schuko; NEMA 1-15P North America AC Power Adapter Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.6A AC Power Adapter Output Specs (V / A) 24V / 1A AC Power Adapter Cord Length (ft.) 4.53 AC Power Adapter Cord Length (m) 1.38 Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Bus Powered No POWER 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Power Source Type AC Adapter Power Source Transmitter end only (Included) Power Over Cable (PoC) Support Yes Receiver Power Source Power Over Cable USER INTERFACE, ALERTS & CONTROLS LED Indicators Power (1x Green) = Splitter unit is receiving power from external power supply; RJ45 Ports (x2 Green) = Port is connected to a receiver and powering the receiver unit, (x2 Orange) = Port is transmitting video to connected receiver PHYSICAL Color Black Material of Construction Metal Cable Length (ft.) 0 Cable Length (m) 0.00 Included Mounting Accessories (2) Brackets, (4) Screws Number of Displays 2 Form Factor/Mounting Options Box Rackmountable Yes Shipping Dimensions (hwd / in.) 2.17 x 10.24 x 6.46 Shipping Dimensions (hwd / cm) 5.51 x 26.01 x 16.41 Shipping Weight (lbs.) 1.23 Shipping Weight (kg) 0.56 Transmitter Unit Dimensions (hwd / cm.) 2.7 x 11.5 x 6.24 Transmitter Unit Dimensions (hwd / in.) 1.063 x 4.528 x 2.457 Transmitter Unit Weight (lbs.) 0.55 Unit Dimensions (hwd / in.) 1.063 x 4.528 x 2.457 Unit Dimensions (hwd / cm) 2.7 x 11.5 x 6.24 Unit Packaging Type Box Unit Weight (lbs.) 0.55 Unit Weight (kg) 0.25 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 85% RH, Non Condensing 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States COMMUNICATIONS Max 1024 x 768 Range (ft) 230 Signal Range (ft.) 230 Signal Range (m) 70 Max 480P Range (ft) 230 Transmission Distance 230 ft. Max 1440 x 900 Range (ft) 230 Max 1080i Range (ft) 230 Max 4K UHD Range (ft) 230 Max 480i Range (ft) 230 Max 640 x 480 Range (ft) 230 Max 800 x 600 Range (ft) 230 Max 1600 x 1200 Range (ft) 230 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported No Latency Zero Latency CONNECTIONS Number of Ports 2 Side A - Connector 1 HDMI (FEMALE) Side B - Connector 1 (2) RJ45 (FEMALE) Input x Output 1x2 Daisy-chainable / Cascadable No FEATURES & SPECIFICATIONS All-in-One Kit No 10/100 Ethernet Extension Support No Integrated/Removable Cable No MST Support No Mounting Accessory Included Yes Multi-Resolution Support Yes Built-In Equalizer Yes HDCP Specification 1.4; 2.2 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Driver Required No Recommended Category Cable 24AWG Cat6 DIN Mountable No STANDARDS & COMPLIANCE External Power Supply Certifications CCC; CE; FCC; GS; TUV; UL; cUL Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA); UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
B127A-002-BH 价格&库存
很抱歉,暂时无法提供与“B127A-002-BH”相匹配的价格&库存,您可以联系我们找货
