1000 Eaton Boulevard
Cleveland, OH 44122
United States
1-Port HDMI over Cat6 Receiver, Wall Plate - 4K
60 Hz, HDR, 4:4:4, PoC, HDCP 2.2, 230 ft. (70.1
m), TAA
Highlights
Supports 4K @ 60 Hz video
resolutions (4:4:4) as specified
in HDMI 2.0
Carries High Dynamic Range
(HDR) signals for rich contrast
and expanded color accuracy
Combines with optional B127A010-H repeater to extend signal
to 400 ft.
Power over Cable (PoC)
technology provides power to
the receiver via Cat6 cable
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
MODEL NUMBER: B127A-1A0-FH
Applications
Extend video signals from one
room to another using Cat6
cable, which can pass through
conduit to meet building codes
Gain flexibility in where the
receiver is placed, with the
freedom to move and relocate it
away from an AC outlet
Improve the line of sight for
digital signage in a hotel,
restaurant, theater, house of
worship, trade show or other
location
Works with a Tripp Lite B127A-Series transmitter, switch or splitter to extend 4K video 230 ft. to an HDMI
display via Cat6 cable.
Features
HDMI Extender Receiver Ideal for Digital Signage in Schools and Workplaces
This 4K receiver is recommended for video presentations in conference rooms, schools, trade shows,
meeting facilities, houses of worship, retail settings, hotels and other digital signage applications where
the source and display are farther apart than conventional A/V cables allow.
Extends a 4K A/V Transmission up to 230 ft….or Even Farther
The B127A-1A0-FH connects to a B127A-Series transmitter, switch or splitter to extend 4K signals from
an HDMI source to an HDMI display up to 230 feet (70.1 meters) away via user-supplied Cat6 cabling. By
adding a B127A-010-H signal repeater (sold separately) to the application, you can extend the signal up to
400 feet (121.9 meters).
Supports Crystal-Clear 4K Video with Multi-Channel Audio, HDR and 4:4:4 Color
The B127A-1A0-FH supports Ultra HD resolutions up to 3840 x 2160 (4K x 2K) at 60 Hz with 7.1-channel
surround sound audio. High Dynamic Range (HDR) provides a wide range of vibrant colors with richer
contrast, brighter whites and deeper blacks that pop on your 4K display. HDCP 2.2 compliance allows you
to stream 4K Amazon and Netflix content with no complications. This receiver also supports 4:4:4 chroma
subsampling for top-level PC gaming or using your HDTV as a PC monitor. Built-in equalization allows
you to fine-tune the image quality at the remote display.
Built-In PoC Technology Provides Receiver Power to Avoid Bulky External Power Bricks
Power over Cable (PoC) technology powers the B127A-1A0-FH over Cat6 cable. An LED indicates when
the receiver and transmitter are connected. PoC lets you avoid the hassle of a bulky power brick and
gives you the freedom to place the receiver where needed without worrying about finding a nearby AC
outlet.
Plug-and-Play Operation for Quick Setup and Immediate Use
The single-gang metal wall-plate receiver works right out of the package with no software required and all
mounting screws included. Connect the receiver to a transmitter, switch or splitter with user-supplied Cat6
cable (such as N202-Series). Connect to a 4K display with a user-supplied HDMI cable (such as P568- or
P569-Series).
1/5
System Requirements
Source device with HDMI output
(Blu-ray player, cable box,
laptop)
Display device with HDMI input
(HDTV, projector, monitor)
B127A-Series HDMI transmitter,
switch or splitter
Package Includes
B127A-1A0-FH 1-Port HDMI
over Cat6 Receiver
Mounting screws
Owner’s manual
Cleveland, OH 44122
United States
TAA-Compliant for GSA Schedule Purchases
The B127A-1A0-FH is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for
GSA (General Services Administration) Schedule and other federal procurement contracts.
Specifications
OVERVIEW
UPC Code
037332264145
Product Type
Receiver
Technology
Cat5/5e; Cat6; HDMI; POC
Host Connector
HDMI (FEMALE)
VIDEO
Video Input
HDMI (FEMALE)
Video Output
HDMI (FEMALE)
Number of Monitors Supported
1
Video Ports
HDMI (FEMALE)
Video Ports Details
HDMI 2.0; HDCP 2.2
Resolutions Supported
3840 x 2160 (4K x 2K) @ 60 Hz
Supported Resolutions
1280x720 (720p); 1920x1080 (1080p); 3840x2160 (4K)
Max Supported Video Resolution
3840 x 2160 @ 60 Hz
Max 1280 x 720 (720p) Range (ft)
230
Max 1920 x 1080 (1080p) Range (ft)
230
Max 1920 x 1200 Range (ft)
230
Max 2560 x 1600 Range (ft)
230
Max 3840 x 2160 (4K@30Hz)
Range (ft)
230
Max 3840 x 2160 (4K@60Hz)
Range (ft)
230
Receiver/Transceiver Video Output
HDMI
Receiver - Number of Video Outputs
1
Signal Range (ft)
230
Signal Range (m)
70
Range Extension using other Tripp
Lite product
170 ft.
Recommended Cabling
Solid Wire Cat6 Cables (Tripp Lite's N202-Series)
Extended Mode
Yes
Extended Mode Details
x1 HDMI (4K/60 Hz)
2/5
Cleveland, OH 44122
United States
Mirror Mode
Yes
Mirror Mode Details
x1 HDMI (4K/60 Hz)
Other Tripp Lite product used to
extend range
B127A-010-H
Max Supported Color Depth
36-bit Deep Color
HDR Support
Yes
3D Video Supported
Yes
Chroma Sub Sampling
4:4:4
Maximum Signal Range (ft)
230
Maximum Signal Range (m)
70
AUDIO
Audio Ports
HDMI (FEMALE)
Audio Ports Details
HDMI outputs support passthrough audio formats including LPCM2.0/5.1/7.1
Audio Input
HDMI
Audio Output
HDMI
Audio Specification
Supports pass-through of Audio format includes LPCM2.0/5.1/7.1
INPUT
Bus Powered
No
POWER
Power Source
Transmitter end only (Optional)
Power Over Cable (PoC) Support
Yes
Receiver Power Source
AC Adapter (Optional); Power Over Cable
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
(1) Data = Green (Connected to a transmitter/splitter/switch)
PHYSICAL
Color
White
Material of Construction
Metal
Included Mounting Accessories
Yes
Number of Displays
1
Form Factor/Mounting Options
Wallplate
Rackmountable
No
Shipping Dimensions (hwd / in.)
2.17 x 8.43 x 6.46
3/5
Cleveland, OH 44122
United States
Shipping Dimensions (hwd / cm)
5.51 x 21.41 x 16.41
Shipping Weight (lbs.)
1.23
Shipping Weight (kg)
0.56
Unit Dimensions (hwd / in.)
4.528 x 2.756 x 1.331
Unit Dimensions (hwd / cm)
11.5 x 7 x 3.38
Unit Packaging Type
Box
Unit Weight (lbs.)
1
Unit Weight (kg)
0.45
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 85% RH, Non Condensing
COMMUNICATIONS
Signal Range (ft.)
230
Signal Range (m)
70
Transmission Distance
230 ft., 400 ft. (with B127A-010-H)
EDID Compatible
Yes
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
No
Latency
USB Extension Support
No
CONNECTIONS
Side A - Connector 1
RJ45 (FEMALE)
Side B - Connector 1
HDMI (FEMALE)
Daisy-chainable / Cascadable
No
FEATURES & SPECIFICATIONS
All-in-One Kit
No
Integrated/Removable Cable
No
MST Support
No
Mounting Accessory Included
Yes
Multi-Resolution Support
No
4/5
Cleveland, OH 44122
United States
Built-In Equalizer
Yes
HDCP Specification
1.4; 2.2
Driver Required
No
Recommended Category Cable
24AWG Cat6
DIN Mountable
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA); UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“B127A-1A0-FH”相匹配的价格&库存,您可以联系我们找货
