B127A-1A1-FDFH
B127A-1A1-FDFH
    TRIPPLITE
    DISPLAYPORT TO HDMI OVER CAT6 EX
B127A-1A1-FDFH 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DisplayPort to HDMI over Cat6 Extender Kit, Wall Plate, 4K 60 Hz, 4:4:4, PoC, HDCP 2.2, 230 ft. (70.1 m), TAA Highlights ● Supports 4K @ 60 Hz video resolutions (4:4:4) as specified in HDMI 2.0 ● Power over Cable (PoC) technology provides power to the receiver via Cat6 cable ● Transmitter’s local port shows you the 4K image being displayed at the other end ● Stretches 230 ft. signal to 400 ft. with addition of optional B127A010-H repeater ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B127A-1A1-FDFH Applications ● Extend video signals from one room to another using Cat6 cable, which can pass through conduit to meet building codes ● Gain flexibility in where the transmitter or receiver is installed, with the freedom to install it away from an AC outlet ● Improve the line of sight for digital signage in a hotel, restaurant, theater, house of worship, trade show or other location Extender kit with transmitter and receiver extends a 4K DisplayPort signal via Cat6 cable to an HDMI display up to 230 ft. away. Features Cat6 Extender Kit Ideal for Digital Signage in Schools, Restaurants and Lecture Halls This complete wall-plate-style transmitter and receiver system is recommended for video presentations in conference rooms, schools, trade shows, meeting facilities, houses of worship, retail settings, hotels and other digital signage applications where the source and display are farther apart than conventional A/V cables allow. Both the transmitter and receiver have a single-gang metal wall plate design with a metal back cover and blend perfectly into the room décor. Extends a 4K A/V Transmission up to 230 ft….or Even Farther The B127A-1A1-FDFH extends 4K signals from a DisplayPort source device to an HDMI display up to 230 feet (70.1 meters) away via user-supplied Cat6 cabling. By adding a B127A-010-H HDMI repeater (sold separately) to the application, you can extend the signal up to 400 feet (121.9 meters). System Requirements ● Source device with DisplayPort output (computer, media server, laptop) ● Display device with HDMI input (HDTV, projector, monitor) Package Includes Transmits Crystal-Clear 4K Video with Multi-Channel Audio and 4:4:4 Color The B127A-1A1-FDFH supports Ultra HD resolutions up to 3840 x 2160 (4K x 2K) at 60 Hz, as specified in HDMI 2.0, with pass-through LPCM 2.0/5.1/7.1 audio. HDCP 2.2 compliance allows you to stream 4K Amazon and Netflix content with no complications. This extender kit also supports 4:4:4 chroma subsampling for top-level PC gaming or using your HDTV as a PC monitor. Built-in equalization automatically fine-tunes the image quality at the remote display. Built-In PoC Technology Provides Power to Avoid Bulky External Power Bricks After you connect the included external power supply to either the transmitter or receiver, Power over Cable (PoC) technology powers the opposite unit over Cat6 cable. LEDs on both the transmitter and receiver will light up to indicate the system is receiving power and a signal is being transmitted. PoC lets you avoid the hassle of a bulky power brick and gives you the freedom to install the application where best needed without worrying about finding a nearby AC outlet. Local HDMI Port on Transmitter Supports 4K @ 60 Hz Resolution To monitor the video signal being extended to the receiver, connect a 4K display to the transmitter’s local HDMI port with a user-supplied HDMI cable. This port does not support multi-resolution capabilities, so the connected monitor must also support 4K/60 Hz to function properly. 1/6 ● Transmitter ● Receiver ● External power supply (Input: 100–240V, 50/60 Hz, 0.6A; Output: 24V 1A) ● (4) International plug adapters (North America, Europe, U.K. and Australia) ● Mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Plug-and-Play Operation for Quick Setup and Immediate Use The included transmitter and receiver units work right out of the box with no software required. Connect the transmitter to the source with a user-supplied DisplayPort cable (such as P580-Series). Then, connect the receiver to the display with a user-supplied HDMI cable (such as P569-XXX-CERT or P568-XXX-2A). Finally, connect the two units with user-supplied Cat6 patch cable (such as N202-Series). Mounting hardware is included for both units. TAA-Compliant for GSA Schedule Purchases The B127A-1A1-FDFH is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. Specifications OVERVIEW UPC Code 037332263957 Product Type Extender Kit Technology Cat5/5e; Cat6; DisplayPort; HDMI; POC VIDEO Video Input DISPLAYPORT (FEMALE) Video Output HDMI (FEMALE) Number of Monitors Supported 2 Video Ports (1) DISPLAYPORT (FEMALE); (1) HDMI (FEMALE) Video Ports Details HDMI 2.0; HDCP 1.4; HDCP 2.2 Resolutions Supported 3840 x 2160 (4K x 2K) @ 60 Hz (both Local HDMI port and HDMI Output) Max Supported Video Resolution 3840 x 2160 @ 60 Hz Max 1280 x 720 (720p) Range (ft) 230 Max 1920 x 1080 (1080p) Range (ft) 230 Max 1920 x 1200 Range (ft) 230 Max 2560 x 1600 Range (ft) 230 Max 3840 x 2160 (4K@30Hz) Range (ft) 230 Max 3840 x 2160 (4K@60Hz) Range (ft) 230 Transmitter Video Input DisplayPort Transmitter - Number of Video Outputs 2 Transmitter - Local Display Output HDMI Receiver/Transceiver Video Output HDMI Receiver - Number of Video Outputs 1 Signal Range (ft) 230 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Signal Range (m) 70 Range Extension using other Tripp Lite product 170 ft. or 230 ft. Recommended Cabling Solid Wire Cat6 Cables (Tripp Lite's N202-Series) Extended Mode Yes Extended Mode Details x1 HDMI Port (4K/60 Hz) Mirror Mode Yes Mirror Mode Details x1 HDMI Port (4K/60 Hz) Other Tripp Lite product used to extend range B127A-010-H or B127A-110-BH Max Supported Color Depth 36-bit Deep Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 Maximum Signal Range (ft) 230 Maximum Signal Range (m) 70 AUDIO Audio Ports HDMI (FEMALE) Audio Ports Details HDMI outputs support passthrough audio formats including LPCM2.0/5.1/7.1 Audio Input Displayport Audio Output HDMI Audio Specification Pass-through Audio format: LPCM2.0/5.1/7.1 INPUT AC Power Adapter Plug(s) AS/NZS 3112 Australia; BS 1363 UK; CEE 7/16 Schuko; NEMA 1-15P North America AC Power Adapter Input Specs (V / Hz / A) 100-240v / 50/60Hz / 0.6A AC Power Adapter Output Specs (V / A) 24V / 1A AC Power Adapter Cord Length (ft.) 4.53 AC Power Adapter Cord Length (m) 1.38 Bus Powered No POWER Power Source Type AC Adapter AC Plug Type AS/NZS 3112; BS1363; CEE 7/16 Schuko; NEMA 1-15P Power Source Transmitter or Receiver (Included) 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Power Over Cable (PoC) Support Yes Receiver Power Source AC Adapter (Included); Power Over Cable USER INTERFACE, ALERTS & CONTROLS LED Indicators Transmitter: (1) Data = Orange (Connected to video source and RJ45 port in use); Receiver: (1) Data = Green (Receiver RJ45 port connected to transmitter, flashes when data is being transmitted) PHYSICAL Color White Material of Construction Metal Included Mounting Accessories (4) Screws Number of Displays 1 Form Factor/Mounting Options Wallplate Rackmountable Yes Receiver Unit Dimensions (hwd / cm.) 11.5 x 7 x 3.382 Receiver Unit Dimensions (hwd / in.) 4.53 x 2.76 x 1.33 Receiver Unit Weight (kg) 0.65 Receiver Unit Weight (lbs.) 1 Shipping Dimensions (hwd / in.) 3.27 x 13.54 x 5.91 Shipping Dimensions (hwd / cm) 8.31 x 34.39 x 15.01 Shipping Weight (lbs.) 3.05 Shipping Weight (kg) 1.39 Transmitter Unit Dimensions (hwd / cm.) 11.5 x 7 x 3.382 Transmitter Unit Dimensions (hwd / in.) 4.53 x 2.76 x 2.02 Transmitter Unit Weight (kg) 0.65 Transmitter Unit Weight (lbs.) 1 Unit Packaging Type Box Unit Weight (lbs.) 1 Unit Weight (kg) 0.45 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 85% RH, Non Condensing COMMUNICATIONS 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Signal Range (ft.) 230 Signal Range (m) 70 Transmission Distance 230 ft. EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes Latency 0 USB Extension Support No CONNECTIONS Side A - Connector 1 DISPLAYPORT (FEMALE) Side A - Connector 2 HDMI (FEMALE) Side B - Connector 1 HDMI (FEMALE) Daisy-chainable / Cascadable No FEATURES & SPECIFICATIONS All-in-One Kit Yes Integrated/Removable Cable No MST Support No Mounting Accessory Included Yes Multi-Resolution Support Yes Built-In Equalizer Yes Displayport Specification 1.2a HDCP Specification 1.4; 2.2 Driver Required No Recommended Category Cable 24AWG Cat6 DIN Mountable No STANDARDS & COMPLIANCE External Power Supply Certifications CCC; CE; FCC; GS; TUV; UL; cUL Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA); UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
B127A-1A1-FDFH 价格&库存
很抱歉,暂时无法提供与“B127A-1A1-FDFH”相匹配的价格&库存,您可以联系我们找货
