B127A-2A0-FH
B127A-2A0-FH
    TRIPPLITE
    2-PORT HDMI OVER CAT6 RECEIVER,
B127A-2A0-FH 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2-Port HDMI over Cat6 Receiver, Wall Plate - 4K 60 Hz, HDR, 4:4:4, PoC, HDCP 2.2, 230 ft. (70.1 m), TAA Highlights ● Supports 4K @ 60 Hz video resolutions (4:4:4) as specified in HDMI 2.0 ● Carries High Dynamic Range (HDR) signals for rich contrast and expanded color accuracy ● Combines with optional B127A010-H repeater to extend signal to 400 ft. ● Power over Cable (PoC) technology provides power to the receiver via Cat6 cable ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B127A-2A0-FH Applications ● Extend video signals from one room to another using Cat6 cable, which can pass through conduit to meet building codes ● Gain flexibility in where the receiver is placed, with the freedom to move and relocate it away from an AC outlet ● Improve the line of sight for digital signage in a hotel, restaurant, theater, house of worship, trade show or other location Works with a Tripp Lite B127A-Series transmitter, switch or splitter to extend 4K video 230 ft. to 2 HDMI displays via Cat6 cable. Features HDMI Dual-Output Receiver Ideal for Digital Signage in Schools and Workplaces This 4K receiver is recommended for video presentations in conference rooms, schools, trade shows, meeting facilities, houses of worship, retail settings, hotels and other digital signage applications where the source and display are farther apart than conventional A/V cables allow. Extends a 4K A/V Transmission up to 230 ft… or Even Farther The B127A-2A0-FH connects to a B127A-Series transmitter, switch or splitter to extend 4K signals from an HDMI source to two HDMI displays up to 230 feet (70.1 meters) away via user-supplied Cat6 cabling. By adding a B127A-010-H signal repeater (sold separately) to the application, you can extend the signal up to 400 feet (121.9 meters) per display. Supports Crystal-Clear 4K Video with Multi-Channel Audio, HDR and 4:4:4 Color The B127A-2A0-FH supports Ultra HD resolutions up to 3840 x 2160 (4K x 2K) at 60 Hz with 7.1-channel surround sound audio. High Dynamic Range (HDR) provides a wide range of vibrant colors with richer contrast, brighter whites and deeper blacks that pop on your 4K display. HDCP 2.2 compliance allows you to stream 4K Amazon and Netflix content with no complications. This receiver also supports 4:4:4 chroma subsampling for top-level PC gaming or using your HDTV as a PC monitor. Built-in equalization allows you to fine-tune the image quality at the remote displays. Built-In PoC Technology Provides Receiver Power to Avoid Bulky External Power Bricks Power over Cable (PoC) technology powers the B127A-2A0-FH over Cat6 cable. An LED indicates when the receiver and transmitter are connected. PoC lets you avoid the hassle of a bulky power brick and gives you the freedom to place the receiver where needed without worrying about finding a nearby AC outlet. Plug-and-Play Operation for Quick Setup and Immediate Use The single-gang metal wall-plate receiver works right out of the package with no software required and all mounting screws included. Connect the receiver to a transmitter, switch or splitter with user-supplied Cat6 cable (such as N202-Series). Connect to two 4K displays with user-supplied HDMI cables (such as P568or P569-Series). 1/5 System Requirements ● Source device with HDMI output (Blu-ray player, cable box, laptop) ● Display device(s) with HDMI input (HDTV, projector, monitor) ● B127A-Series HDMI transmitter, switch or splitter Package Includes ● B127A-2A0-FH 2-Port HDMI over Cat6 Receiver ● Mounting screws ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States TAA-Compliant for GSA Schedule Purchases The B127A-2A0-FH is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. Specifications OVERVIEW UPC Code 037332264084 Product Type Receiver Technology Cat5/5e; Cat6; HDMI; POC VIDEO Video Input HDMI (FEMALE) Video Output HDMI (FEMALE) Number of Monitors Supported 2 Video Ports HDMI (FEMALE) Video Ports Details HDMI 2.0; HDCP 2.2 Resolutions Supported 3840 x 2160 (4K x 2K) @ 60 Hz Max Supported Video Resolution 3840 x 2160 @ 60 Hz Max 1280 x 720 (720p) Range (ft) 230 Max 1920 x 1080 (1080p) Range (ft) 230 Max 1920 x 1200 Range (ft) 230 Max 2560 x 1600 Range (ft) 230 Max 3840 x 2160 (4K@30Hz) Range (ft) 230 Max 3840 x 2160 (4K@60Hz) Range (ft) 230 Receiver/Transceiver Video Output HDMI Receiver - Number of Video Outputs 2 Signal Range (ft) 230 Signal Range (m) 70 Range Extension using other Tripp Lite product 170 ft. Recommended Cabling Solid Wire Cat6 Cables (Tripp Lite's N202-Series) Extended Mode Yes Extended Mode Details x2 HDMI (4K/60 Hz) Mirror Mode Yes Mirror Mode Details x2 HDMI (4K/60 Hz) 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Other Tripp Lite product used to extend range B127A-010-H Max Supported Color Depth 36-bit Deep Color HDR Support Yes 3D Video Supported Yes Chroma Sub Sampling 4:4:4 Maximum Signal Range (ft) 230 Maximum Signal Range (m) 70 AUDIO Audio Ports (2) HDMI (FEMALE) Audio Ports Details HDMI outputs support passthrough audio formats including LPCM2.0/5.1/7.1 Audio Input HDMI Audio Output HDMI Audio Specification Supports pass-through of Audio format includes LPCM2.0/5.1/7.1 INPUT Bus Powered No POWER Power Source Transmitter or Receiver (Optional) Power Over Cable (PoC) Support Yes Receiver Power Source AC Adapter (Optional); Power Over Cable USER INTERFACE, ALERTS & CONTROLS LED Indicators (x1) Data = Orange (RJ45 port is connected to a transmitter via Cat6 cable) PHYSICAL Color White Material of Construction Metal Included Mounting Accessories Yes Number of Displays 2 Form Factor/Mounting Options Wallplate Rackmountable No Shipping Dimensions (hwd / in.) 2.17 x 8.42 x 6.46 Shipping Dimensions (hwd / cm) 5.51 x 21.39 x 16.41 Shipping Weight (lbs.) 1.23 Shipping Weight (kg) 0.56 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Dimensions (hwd / in.) 4.530 x 2.760 x 1.330 Unit Dimensions (hwd / cm) 11.5 x 7.0 x 3.4 Unit Packaging Type Box Unit Weight (lbs.) 1 Unit Weight (kg) 0.45 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 85% RH, Non Condensing COMMUNICATIONS Signal Range (ft.) 230 Signal Range (m) 70 Transmission Distance 230 ft., 400 ft. (with B127A-010-H) EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported No Latency Zero Latency USB Extension Support No CONNECTIONS Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 (2) HDMI (FEMALE) Daisy-chainable / Cascadable No FEATURES & SPECIFICATIONS All-in-One Kit No Integrated/Removable Cable No MST Support No Mounting Accessory Included No Multi-Resolution Support No Built-In Equalizer Yes HDCP Specification 1.4; 2.2 Driver Required No 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Recommended Category Cable 24AWG Cat6 DIN Mountable No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA); UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B127A-2A0-FH 价格&库存
很抱歉,暂时无法提供与“B127A-2A0-FH”相匹配的价格&库存,您可以联系我们找货
