1000 Eaton Boulevard
Cleveland, OH 44122
United States
4-Port HDMI over Cat6 Splitter/Extender, 4K 60
Hz, HDR, PoC, Multi-Resolution Support, 125 ft.,
TAA
Highlights
Works in tandem with B127P100-H or B127P-100-H-SR
remote receivers
Supports UHD resolutions up to
4K @ 60 Hz (4:4:4) for crystalclear video
Power over Cable (PoC)
technology provides power to
the receiver via Cat6 cable
Supports High Dynamic Range
(HDR) for richer contrast and
expanded color accuracy
Supports multi-resolution output
to allow for combination of
different display types
MODEL NUMBER: B127P-004-H
Applications
Transmitter/splitter extends a 4K HDMI audio/video signal via Cat6 cable to 4 projectors, monitors or
HDTVs up to 125 ft. away.
Connect a media server, Blu-ray
player, cable/satellite box, Roku,
gaming system or other home
theater component to four largescreen 4K televisions or
projectors
Upgrade the video quality of
your trade show presentation or
digital signage installation in a
commercial or educational
setting to 4K x 2K
Set up digital signage with a
single video signal being
transmitted to 4 monitors, each
displaying its maximum
resolution
Mount a security camera in an
out-of-the-way spot without the
burden of placing it near an AC
outlet
Features
Splitter Ideal for Digital Signage or Displaying Video in Schools or Trade Show BoothsThis four-port
transmitter/splitter is recommended for video presentations in conference rooms, schools, trade shows,
meeting facilities, houses of worship, retail settings and other digital signage applications where the
source and display are farther apart than conventional A/V cables allow. The B127P-004-H extends 4K (at
60 Hz) video and stereo audio signals from an HDMI source device to four HDMI displays up to 125 feet
(38.1 meters) away via user-supplied Cat6 cabling. It can also extend a 4K HDMI signal (at 30 Hz) up to
150 feet (45.7 meters) and a 1080p HDMI signal (at 60 Hz) up to 200 feet (61 meters) using B127P-100-H
receiver.
Transmits Crystal-Clear 4K HDMI Video with Multi-Channel Audio and 4:4:4 ColorThe B127P-004-H
supports Ultra HD video resolutions up to 4K x 2K (3840 x 2160) at 60 Hz with full, rich uncompressed
DTS-HD, Dolby TrueHD and 7.1-channel digital audio. This transmitter is capable of carrying HDR
signals, which provides a wide range of vibrant colors with richer contrast, brighter whites and deeper
blacks. It supports 4:4:4 chroma subsampling for top-level PC gaming or using your HDTV as a PC
monitor. HDCP 2.2 compliance allows you to stream iTunes and Netflix content with no complications.
Multi-Resolution Support Allows Mixing and Matching of Displays of Different ResolutionsSay you
have a brand new 4K (at 60 Hz) HDTV in the living room, but want to also connect your Blu-ray player or
satellite box to the older 1080p TV in the bedroom. The B127P-004-H is backward compatible with 4K (at
30 Hz) and 1080p (at 60 Hz) resolutions via automatic switching. This splitter allows each connected
television to display video at its maximum resolution. Most other splitters default all displays to the lowest
common resolution (meaning you would only get a 1080p image on that new 4K TV).
Built-In PoC Technology Provides Power to Avoid Bulky External Power BricksBuilt-in Power over
Cable (PoC) technology powers the connected B127P-100-H or B127P-100-H-SR receiver over Cat6
cable. Green and orange LEDs will light up to indicate the unit is receiving power and a signal is being
received. PoC lets you avoid the hassle of a bulky power brick and gives you the freedom to transfer
power to the remote receivers and place them away from an AC outlet.
Plug-and-Play Operation for Quick Setup and Immediate UseThe included transmitter works right out
of the box with no software required. Mounting hardware is included for installing the unit on a wall, pole or
1/5
System Requirements
Source device with HDMI output
(Blu-ray player, cable box,
laptop)
B127P-100-H or B127P-100-HSR remote receivers
Package Includes
Transmitter unit
External power supply with 4.5
ft. cord (Input: 100-240V, 50/60
Hz, 1.5A; Output: 24V 2A)
(4) International plug adapters
(North America, Europe, U.K.
and Australia)
Mounting hardware
Owner's manual
Cleveland, OH 44122
United States
19-inch rack. Connect the transmitter to the source with a user-supplied HDMI cable (such as P568- or
P569-Series). Then, connect the transmitter to B127P-100-H or B127P-100-H-SR remote receivers using
Cat6 patch cable (such as N202-Series cable).
Daisy-Chain Multiple Transmitters to Add More DisplaysAn HDMI output is included for connecting up
to three additional B127P-004-H transmitters, each of which splits the original HDMI signal into four. You
can also connect an optional display to monitor the image connected to the receivers up to 125 feet away.
TAA-Compliant for GSA Schedule PurchasesThe B127P-004-H is compliant with the Federal Trade
Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and
other federal procurement contracts.
Specifications
OVERVIEW
UPC Code
037332239198
Product Type
Splitter; Extender Kit
Technology
HDMI; Cat5/5e; Cat6; POC
Host Connector
HDMI (FEMALE)
VIDEO
Video Input
HDMI (FEMALE)
Video Output
HDMI (FEMALE)
Max Supported Video Resolution
3840 x 2160 (4K) @ 60Hz
Max. Distance (Between any 2
Units)
6 ft. (2m)
Max Number of Ports (Entire Chain)
12
Max 1280 x 720 (720p) Range (ft)
200
Max 1920 x 1080 (1080p) Range (ft)
200
Max 1920 x 1200 Range (ft)
150
Max 2560 x 1600 Range (ft)
150
Max 3840 x 2160 (4K@30Hz)
Range (ft)
150
Max 3840 x 2160 (4K@60Hz)
Range (ft)
125
Transmitter Video Input
HDMI
Transmitter - Number of Video
Outputs
4
Transmitter - Local Display Output
HDMI
Recommended Cabling
N202-Series Cat6 Solid Wire Cables
Max Supported Color Depth
24-bit True Color
HDR Support
Yes
2/5
Cleveland, OH 44122
United States
3D Video Supported
Yes
Chroma Sub Sampling
4:4:4
Maximum Signal Range (ft)
125
Maximum Signal Range (m)
38
AUDIO
Audio Input
HDMI
Audio Specification
7.1 Channel Surround Sound, DTS-HD and Dolby TrueHD
INPUT
AC Power Adapter Plug(s)
AS/NZS 3112 Australia; BS 1363 UK; CEE 7/16 Schuko; NEMA 1-15P North America
AC Power Adapter Input Specs (V /
Hz / A)
100-240V / 50/60Hz / 1.5A
AC Power Adapter Output Specs (V
/ A)
24V / 2A
AC Power Adapter Cord Length (ft.)
4.5
AC Power Adapter Cord Length (m)
1.37
Bus Powered
No
POWER
Power Source Type
AC Adapter
AC Plug Type
NEMA 1-15P; BS1363; CEE 7/16 Schuko; AS/NZS 3112
Power Source
Transmitter end only (Included)
Power Over Cable (PoC) Support
Yes
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
x6 ORANGE (OUTPUT, LOCAL, INPUT), GREEN (POWER), x4 GREEN (RJ45 CONNECTION) x4 ORANGE (RJ45
DATA)
PHYSICAL
Color
Black
Material of Construction
Metal
Cable Length (ft.)
Cable Length (m)
0.00
Included Mounting Accessories
Wallmount
Number of Displays
1
Form Factor/Mounting Options
Box; Wall-mount
Rackmountable
Yes
Unit Dimensions (hwd / in.)
1.170 x 9.250 x 3.940
3/5
Cleveland, OH 44122
United States
Unit Packaging Type
Box
Unit Weight (lbs.)
1.43
Unit Weight (kg)
0.65
Housing
Metal
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0% to 85% RH, Non-Condensing
COMMUNICATIONS
Signal Range (ft.)
125
Signal Range (m)
38
EDID Compatible
Yes
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
Yes
USB Extension Support
No
CONNECTIONS
Number of Ports
4
Side A - Connector 1
HDMI (FEMALE)
Side B - Connector 1
(4) RJ45 (FEMALE)
Side B - Connector 2
HDMI (FEMALE)
Input x Output
1x4
Daisy-chainable / Cascadable
Yes
Details
Up to 4 Units
PORT EXPANSION
Daisy-chainable or Cascadable
Daisy chainable
FEATURES & SPECIFICATIONS
10/100 Ethernet Extension Support
No
MST Support
No
Yes
Built-In Equalizer
Yes
4/5
Cleveland, OH 44122
United States
HDCP Specification
2.2
Driver Required
No
Recommended Category Cable
STANDARDS & COMPLIANCE
External Power Supply Certifications
CCC; CE; FCC; GS; TUV; UL; cUL
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“B127P-004-H”相匹配的价格&库存,您可以联系我们找货
