B130-101A-WP-2
B130-101A-WP-2
    TRIPPLITE
    VGA + Audio Extender Wallplate Kit Cat5/Cat6
B130-101A-WP-2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States VGA over Cat5/6 Extender Kit, Wall Plate Transmitter/Receiver for Video/Audio, Up to 1000 ft. (305 m), TAA Highlights ● Stores display’s EDID information and sends it to source ● Extends 1024 x 768 video and audio signal up to 1,000 ft. ● Extends 1920 x 1440 video and audio signal up to 500 ft. ● Built-in equalization and gain controls let you fine-tune image ● Plug and play—no software or drivers to install MODEL NUMBER: B130-101A-WP-2 System Requirements Package Includes Wall plate transmitter and receiver work in tandem to extend a VGA signal via Cat5e/6 cable to a projector, monitor or television. ● Transmitter wall plate unit ● Receiver wall plate unit ● VGA + audio “Y” splitter cable ● Screwdriver for adjusting equalization and gain ● (2) External Power Supplies with NEMA 1-15P Plug (Input: 100240V, 50/60 Hz, 0.5A; Output: 5V, 2A, 5-ft. (1.52 m) ● Wall plate screws ● Owner’s Manual Description The B130-101A-WP-2 VGA with Audio over Cat5/Cat6 Extender Kit includes transmitter and receiver wall plate units that work in tandem to extend a VGA signal to to a projector, monitor or television. The kit is ideal for digital signs in schools, churches or retail applications where the video source is located farther than conventional cables allow. Attractive wall plate units eliminate cable clutter. Because compatibility issues can occur when EDID information is not properly communicated between the source and the display, the B130-101A-WP-2 includes an EDID copy feature. This enables the transmitter to store the display’s EDID information and send it to the video source, ensuring top-shelf compatibility. The B130-101A-WP-2 can extend a 1024 x 768 (60 Hz) signal up to 1000 feet (304.8 meters) and a 1920 x 1440 (60 Hz) signal up to 500 feet (152.4 meters) when using 24 AWG solid-wire Cat5e/6 cable, such as N022-01K-GY (Cat5) and N222-01K-GY (Cat6), to connect the two units. For optimal image quality between 500 and 1000 feet, use zero-skew cable, such as P524-01K. The RJ45-type wall plate jacks accept standard Cat5e/6 Ethernet cables, so no 110 punch-down connection is required. You can also connect up to three B132-110A remote repeaters in a chain (using Cat5e/6 cable) for a total of five VGA displays (one local and four remote) and full 1024 x 768 (60 Hz) signal extension of 2000 feet (609.6 meters) Features Extended Display Identification Data (EDID) Copy FeatureTransmitter stores monitor’s EDID information and sends it to video source, ensuring optimal display compatibilityMonitor must be connected directly to transmitter’s VGA port to activate EDID copy feature Extends High-Definition VGA Video and Audio SignalsExtends a 1024 x 768 (60 Hz) signal up to 1,000 ft. and a 1920 x 1440 (60 Hz) signal up to 500 ft.Connect up to three B132-110A remote repeaters to the chain for maximum 1024 x 768 (60 Hz) signal range of 2,000 ft.Transmitter and receiver connect with one Cat5e/6 cable, such as N022-01K-GY or N222-01K-GY 24 AWG solid-wire Cat5e/6 cableNo 110 punchdown connection requiredFor optimal image quality between 500 and 1,000 ft., use zero-skew cable, such as P524-01K Easy to Set Up and UsePlug-and-play engineering—no software or drivers to download and installWall plate units eliminate cable clutterLEDs indicate at a glance when the unit is receiving powerIncluded VGA + audio “Y” splitter cable allows connection of local monitor and speakersBuilt-in equalization and gain 1/5 1000 Eaton Boulevard Cleveland, OH 44122 United States controls lets you adjust the image on the remote monitorWall-mounting screws includedSupports all operating systems, as well as HDCP TAA-CompliantCompliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332186270 Product Type Extender Kit Accessory Type Extender Technology VGA/SVGA; Stereo Audio; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920 x 1440 @ 60Hz Max 720P Range (ft) 500 Max 1080P Range (ft) 500 Max 1280 x 720 (720p) Range (ft) 500 Max 1920 x 1080 (1080p) Range (ft) 500 Max 1920 x 1200 Range (ft) 500 Transmitter Video Input VGA Transmitter - Number of Video Outputs 1 Transmitter - Local Display Output VGA Receiver/Transceiver Video Output VGA Receiver - Number of Video Outputs 1 Recommended Cabling Solid Wire Cat6 Cables (Tripp Lite's N202-Series) HDR Support No 3D Video Supported No Maximum Signal Range (ft) 1000 Maximum Signal Range (m) 305 Maximum Signal Range Details 1000 ft @ 1024 x 768 (60Hz)500 ft @ 1920 x 1440 (60Hz) AUDIO Audio Input 3.5mm Audio Output 3.5mm Audio Specification Stereo Audio 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT AC Power Adapter Plug(s) NEMA 1-15P North America AC Power Adapter Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A AC Power Adapter Output Specs (V / A) 5V / 2A AC Power Adapter Cord Length (ft.) 4.5 AC Power Adapter Cord Length (m) 1.38 Bus Powered No POWER Power Source Type AC Adapter AC Plug Type NEMA 1-15P Power Source Transmitter and Receiver (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators TX & RX: RJ45: Green (Connection), Orange (Data Transmission) PHYSICAL Color White Number of Displays 1 Form Factor/Mounting Options Wallplate Receiver Unit Dimensions (hwd / in.) 4.53 x 2.76 x 1 Receiver Unit Weight (lbs.) 0.5 Shipping Dimensions (hwd / in.) 6.46 x 10.24 x 2.17 Shipping Dimensions (hwd / cm) 16.41 x 26.01 x 5.51 Shipping Weight (lbs.) 1.61 Shipping Weight (kg) 0.73 Transmitter Unit Dimensions (hwd / in.) 4.53 x 2.76 x 1 Transmitter Unit Weight (lbs.) 0.5 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Housing Plastic 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Relative Humidity 10% to 90% RH, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 1000 Max 480P Range (ft) 1000 Max 1440 x 900 Range (ft) 500 Max 1080i Range (ft) 500 Max 1920 x 1440 Range (ft) 500 Max 480i Range (ft) 1000 Max 640 x 480 Range (ft) 1000 Max 800 x 600 Range (ft) 1000 Max 1600 x 1200 Range (ft) 500 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported No USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 HD15 (FEMALE) Side A - Connector 2 RJ45 (FEMALE) Side A - Connector 3 3.5MM (FEMALE) Side B - Connector 1 HD15 (FEMALE) Side B - Connector 2 3.5MM (FEMALE) Side B - Connector 3 RJ45 (FEMALE) Daisy-chainable / Cascadable No FEATURES & SPECIFICATIONS 10/100 Ethernet Extension Support No Built-In Equalizer Yes Driver Required No 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; TUV; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B130-101A-WP-2 价格&库存
很抱歉,暂时无法提供与“B130-101A-WP-2”相匹配的价格&库存,您可以联系我们找货
