B160-100-CSI
B160-100-CSI
    TRIPPLITE
    Receiver Extender Cat5/Cat6
B160-100-CSI 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Component Video + Audio over IP Extender/Receiver, Cat5e/6, Serial and IR Control, 1080i, 328 ft. (100 m), TAA MODEL NUMBER: B160-100-CSI Highlights ● Compatible with B160-Series A/V over IP transmitters ● Display video from any source, analog or digital ● Supports video resolutions up to 1080i ● Scales up to multi-in, multi-out installation with network switch ● Plug and play—no software or drivers required Package Includes Receives IP-based audio + video signal transmitted point-to-point from a source 328 ft. away via Cat5e/6 cable or through a dedicated Ethernet network switch. Description The B160-100-CSI RGB Component Video + Audio over IP Extender Receiver works with a B160-Series transmitter (sold separately) to extend and distribute component video + stereo audio, RS-232 serial and IR (infrared) remote signals from the source to the display located up to 328 feet (100 meters) away, which is more than 200 feet (61 meters) farther than a traditional Cat5e/6 solution. By adding a chain of low-cost unmanaged network switches, such as the NG5 (sold separately), you can continue extending the distance between source and display up to 328 feet per switch. Create a multi-in, multi-out installation with up to 64 transmitters and 255 receivers* by connecting dedicated managed Ethernet network switches** with Internet Group Management Protocol (IGMP), such as the NSS-G16D2 (sold separately). With a compatible B160-Series transmitter, this receiver works with any analog or digital source, including HDMI, VGA and DisplayPort, allowing you to mix and match technologies and use existing source devices. An IGMP-enabled switch will let you manage all connections for centralized control over which sources show on which displays. The B160-100-CSI supports video resolutions up to 1080i. It extends IR control signals that control a source, such as a Blu-ray player, from a remote display, as well as RS-232 signals at serial baud rates up to 57600 Bps. It mounts to a wall, rack or pole using the included hardware. *Unmanaged switch installations are limited to two transmitter units. Number of receivers is limited to number of ports remaining on unmanaged switch. **B160-Series designed for use with dedicated network switch. Connecting to a switch used with other networking equipment will result in degraded or non-functional performance. Features RGB Component Video + Stereo Audio, Serial and IR Control Signals over Cat5/6 Cabling ● Receives IP-based audio + video transmitted point-to-point from a source 328 ft. away ● Add low-cost network switches between transmitter and receiver to continue extending distance up to 328 ft. per switch Create a Multi-In, Multi-Out Installation Using B160-Series Transmitters and Receivers ● Connect up to 64 transmitters and 255 receivers through multiple dedicated managed network switches ● IGMP-enabled switches allow centralized control over which sources show on which displays 1/5 ● Receiver unit ● External power supply (Input: 100–240V, 50/60 Hz, 0.5A; Output: 5V 2A) ● Plug adapters for U.S., U.K., Europe and Australia ● IR-In cable ● 3.5 mm to DB9 adapter cable (M/M) ● Mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Displays video from any analog or digital source, so you can mix and match technologies and use existing sources and monitors Enhanced Technical Features ● Supports video resolutions up to 1080i ● Uses H.264 video compression standard ● Transmits on 20–60 kHz IR frequency ● Extends IR control signals that control a source from a remote display ● Supports RS-232 serial baud rates up to 57600 Bps Plug-and-Play Functionality ● No software or drivers required ● Hardware included for mounting on wall, rack or pole ● Compatible with all B160-Series A/V over IP transmitters TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332196767 Product Type Receiver Technology Component; IR; A/V over IP; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920 x 1080 (1080i @ 60Hz) Max 1280 x 720 (720p) Range (ft) 328 Receiver/Transceiver Video Output Component (RCA) Receiver - Number of Video Outputs 1 Range Extension using other Tripp Lite product 328 ft. Recommended Cabling N202-Series Cat6 Patch Cable Other Tripp Lite product used to extend range network switch HDR Support No 3D Video Supported Yes Maximum Signal Range (ft) 328 Maximum Signal Range (m) 100 AUDIO 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Audio Output RCA (x2) Stereo Audio Specification Stereo Audio INPUT AC Power Adapter Plug(s) AS/NZS 3112 Australia; BS 1363 UK; CEE 7/16 Schuko; NEMA 1-15P North America AC Power Adapter Input Specs (V / Hz / A) 100-240V / 50/60Hz / 1.0A AC Power Adapter Output Specs (V / A) 5V / 2A AC Power Adapter Cord Length (ft.) 4.5 AC Power Adapter Cord Length (m) 1.4 Bus Powered No POWER Power Source Type AC Adapter AC Plug Type NEMA 1-15P; CEE 7/16 Schuko; BS1363; AS/NZS 3112 Power Source Unit (Included) Power Over Cable (PoC) Support No DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 5.3 USER INTERFACE, ALERTS & CONTROLS LED Indicators RJ45 Output (Green / Power, Orange / Signal), Channel Signal (Red), Power (Green) PHYSICAL Color Black Material of Construction Steel Included Mounting Accessories Wallmount Number of Displays 1 Optional Mounting Accessory Notes Can DIN Mount using Tripp Lite Bracket  B110-DIN-02  Form Factor/Mounting Options Box; Wall-mount Rackmountable Yes Shipping Dimensions (hwd / in.) 2.17 x 10.24 x 6.46 Shipping Weight (lbs.) 1.59 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Unit Weight (lbs.) 0.2 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Weight (kg) 0.09 Housing Metal ENVIRONMENTAL Operating Temperature Range 14° to 167°F (10° to 75°C) Storage Temperature Range -4° to 176°F (-20° to 80°C) Relative Humidity 0% to 85%, Non-Condensing BTUs 18.1 BTU/Hr COMMUNICATIONS Signal Range (ft.) 328 Signal Range (m) 100 EDID Compatible No IR Remote Extension Support Yes RS-232 Serial Extension Support Yes Consumer Electronics Control (CEC) Supported No Latency 2-3 seconds USB Extension Support No CONNECTIONS Number of Ports 8 Side A - Connector 1 (5) RCA (FEMALE) Side B - Connector 1 RJ45 (FEMALE) Daisy-chainable / Cascadable No FEATURES & SPECIFICATIONS 10/100 Ethernet Extension Support No Built-In Equalizer No Driver Required No Recommended Category Cable N202-Series Cat6 Patch Cable STANDARDS & COMPLIANCE External Power Supply Certifications BSMI; CB; CE; FCC; GS; PSE; RCM; UL; cUL Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B160-100-CSI
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一款6引脚的光耦器件,用于隔离信号传输。
3. 引脚分配:1脚为输出低电平,2脚为输出高电平,3脚为输入,4脚为接地,5脚为Vcc,6脚为发光二极管。
4. 参数特性:工作电压为5V,输入电流为10mA,输出电流为50mA。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,常用于数字信号的隔离。
6. 应用信息:广泛应用于工业控制、医疗设备、通信设备等领域。
7. 封装信息:采用DIP6封装形式。
B160-100-CSI 价格&库存
很抱歉,暂时无法提供与“B160-100-CSI”相匹配的价格&库存,您可以联系我们找货
