B203-104-IND
B203-104-IND
    TRIPPLITE
    4-PORT INDUSTRIAL USB OVER CAT6
B203-104-IND 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port Industrial USB over Cat6 Extender, ESD Protection, PoC - USB 2.0, Mountable, 150 ft. (45.72 m), TAA Highlights ● Supports USB 2.0 speeds up to 480 Mbps to ensure reliable data transfers ● Power over Cable (PoC) provides power to the transmitter via Cat5/6 cable ● ESD protection to ±15 kV cuts potential static damage to your connected peripherals ● Industrial-grade metal housings withstand harsh warehouse and factory environments ● Compatible with all major operating systems, including Windows, Mac OS and Chrome MODEL NUMBER: B203-104-IND Applications ● Connect an impact printer, 1080p webcam and other USB devices using existing in-wall Cat5/6 wiring to a computer, laptop or server located in another room Industrial-grade transmitter/receiver combo connects your office laptop or PC to a webcam and other USB peripherals up to 150 ft. away. ● Eliminate excessive cable clutter with the extender kit’s PoC capability Features ● Place the computer or server in a locked cabinet or closet to protect against tampering ● Mount to a wall or DIN rail in a harsh environment, such as a factory, construction site, supply room or warehouse Industrial-Grade Extender Connects Your Computer to a USB Device up to 150-ft. (45.7 m) AwayThis plug-and-play extender kit with heavy-duty all-metal housings is ideal for connecting your office computer's USB-A port to a printer, 1080p webcam, external hard drive or other USB devices located up to 150-ft. (45.7 m) away. The B203-104-IND includes a local transmitter and a remote receiver that extends USB 2.0 signals over user-supplied Cat5/6 cabling (such as N202-Series Cat6 Ethernet cables). Protects Your Devices against Electrostatic Discharge (ESD)Machines on the shop floor can generate electrostatic discharges, wiping out data and damaging sensitive electronics. This extender kit provides ESD protection to ±15 kV, reducing potential static damage to your connected USB peripherals. The durable metal transmitter and receiver units withstand harsh physical conditions in industrial and commercial applications, such as factories, construction sites, supply rooms and warehouses. With Great Distance Comes Great FlexibilityBy extending the USB connection beyond the standard 16ft. (4.9 m) distance limitation to 150-ft. (45.7 m), the B203-104-IND provides workstation flexibility to place your computer and the USB devices where they are best suited. This extender kit supports USB 2.0 data transfer rates up to 480 Mbps and is backward compatible with USB 1.1 technology, allowing you to connect legacy devices. No network connectivity is needed. System Requirements ● Computer, laptop or server with USB-A port ● Cat5/5e/6/6a cabling ● Any major operating system, including Windows, Mac OS and Chrome Package Includes Plug-and-Play Kit Offers Flexible Power and Installation OptionsWith user-supplied USB cables, connect the transmitter to your computer and the receiver to your USB peripheral. Connect the transmitter and receiver with a user-supplied Cat5/6 cable (all cables sold separately). The extender kit requires no software to download and install. The metal chassis rest easily on any flat surface or mount to a wall or DIN rail using the included hardware. A power supply with international plug adapters as well as a RS-232 Phoenix adapter supporting a DC voltage range from 9-36V is included for connecting external power to the unit as needed. ● Transmitter ● Receiver ● (2) DIN rail mounts ● (4) M4 screws ● RS-232 Phoenix adapter ● International power supply (Input: 100–240V, 50/60 Hz, 0.35A; Output: 5V 2A) ● (4) Plug adapters (North TAA-Compliant for GSA Schedule PurchasesThe B203-104-IND is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States America, Europe, U.K., Australia) ● Specifications OVERVIEW UPC Code 037332256089 Technology USB 2.0 (High Speed) VIDEO HDR Support No POWER Power Over Cable (PoC) Support Yes Output Volt/Amp (from external power supply) 5V/2A USB Power Delivery (PD) Charging Support No USER INTERFACE, ALERTS & CONTROLS LED Indicators Transmitter: 1x Green (Connection); 1x Orange (Signal) Receiver: 1x Green (Connection); 1x Orange (Activity) PHYSICAL Color Black Material of Construction Metal Receiver Unit Dimensions (hwd / cm.) 11.501 x 6.240 x 2.700 Receiver Unit Dimensions (hwd / in.) 4.528 x 2.457 x 1.063 Receiver Unit Weight (lbs.) 1 Transmitter Unit Dimensions (hwd / cm.) 11.501 x 6.240 x 2.700 Transmitter Unit Dimensions (hwd / in.) 4.528 x 2.457 x 1.063 Transmitter Unit Weight (lbs.) 1 Unit Packaging Type Box ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) 2/3 Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Storage Temperature Range 5° to 122°F (-15° to 50°C) Operating Humidity Range 0 - 85% RH, NON-CONDENSING Storage Humidity Range 0 - 85% RH, NON-CONDENSING ESD Protection 15KV COMMUNICATIONS Signal Range (ft.) 150 Signal Range (m) 46 Transmission Distance 45m (150 ft) IR Remote Extension Support No RS-232 Serial Extension Support No USB Extension Support No CONNECTIONS Number of Ports 7 Side A - Connector 1 USB B (FEMALE) Side A - Connector 2 RJ45 (FEMALE) Side B - Connector 1 (4) USB A (FEMALE) Side B - Connector 2 RJ45 (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 2.0 (up to 480 Mbps) Recommended Category Cable Cat5e/Cat6 STANDARDS & COMPLIANCE Product Certifications NOM (Mexico) Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
B203-104-IND 价格&库存
很抱歉,暂时无法提供与“B203-104-IND”相匹配的价格&库存,您可以联系我们找货
