BP192V12RT3US
BP192V12RT3US
    TRIPPLITE
    192V EXTERNAL BATTERY PACK FOR S
BP192V12RT3US 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 192V External Battery Pack for Select UPS Systems, 3U Rack/Tower MODEL NUMBER: BP192V12RT3US Highlights ● Connects to compatible 5kVA/6kVA Unity PF UPS systems for extended runtime ● Smart pack communicates with UPS to automatically report battery temperature, accurate runtime, etc. ● Daisy-chain connector supports additional battery packs for even longer runtime ● Mounts in 3U of space in 19 in. rack using included 4-post installation hardware ● Supports 2-post rack or tower installation with optional accessories (sold separately) Applications External smart battery pack provides extended runtime for compatible Tripp Lite Unity Power Factor UPS systems. Features ● Extend the runtime of your compatible Tripp Lite UPS system ● Daisy-chain to additional battery packs to provide even longer extended-run operation System Requirements External Battery Pack Gives Your Compatible UPS System Extended RuntimeThe BP192V12RT3US is compatible only with UPS systems that specify the use of this battery pack (see System Requirements below). Not only does this external battery pack provide extended runtime, but it can also be daisychained using its input/output connectors to additional external battery packs for even longer extended-run operation. Heavy-gauge cabling with high-current DC connectors is included for simple installation. Smart Battery Communicates with Your UPS for Optimal PerformanceThis external battery pack with included power and data cabling is automatically sensed by the UPS for highly accurate runtime reporting and ideal charge current settings. An additional data cable reports battery pack temperature to the UPS to enable temperature-compensated charging to extend battery lifespan and fast recharge. Mounts in 3U of Space in 19 in. 4-Post RacksThis smart battery pack’s multi-use form factor supports stacking or mounting in 3U of space in EIA-standard 19-inch racks using the included 4-post rackmounting brackets. The four replaceable internal battery trays can be easily removed to make the battery pack lighter for rack-mount installation. The BP192V12RT3US is also compatible with 2-9USTAND for upright tower configuration and 2POSTRMKITHD for 2-post racks (both accessories sold separately). 5kVA and 6kVA SmartOnline Unity Power Factor UPS systems only: SU5KRT3UG, SU5KRT3UHV, SU5KRT3UHW, SU5KRT3UTF, SU5KRT3UX, SU6KRT3UG, SU6KRT3UHV, SU6KRT3UHW, SU6KRT3UTF, SU6KRT3UX, SU5KRT3UGMB, SU5KRT3UHVMB, SU5KRT3UHWMB, SU5KRT3UTFMB, SU6KRT3UGMB, SU6KRT3UHVMB, SU6KRT3UHWMB, SU6KRT3UTFMB, SU6KRT3UXMB and other UPS systems that specify the use of this battery pack Package Includes 1/3 ● BP192V12RT3US 192V External Battery Pack, 3U Rack/Tower ● Smart battery communication cable ● 4-post rack-mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332238610 INPUT Input Phase Single-Phase UPS Input Cord Length (ft.) 3 UPS Input Cord Length (m) 0.9 OUTPUT Overload Protection 50A DC output fuse BATTERY Expandable Runtime Yes DC System Voltage (VDC) 192 UPS Connection Detachable cable with UPS specific DC connector (90 cm length, 8 gauge) Typical Battery Lifespan 4-6 years typical (North America) PHYSICAL Material of Construction Steel Rack Height 3U External Battery Pack Form Factor Rack/Tower Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITHD ); Tower ( 2-9USTAND ) Minimum Required Rack Depth (cm) 78.74 Minimum Required Rack Depth (inches) 31 Shipping Dimensions (hwd / in.) 11.00 x 23.00 x 33.00 Shipping Weight (kg) 88.00 Unit Dimensions (hwd / in.) 5.250 x 17.500 x 28.000 Unit Dimensions (hwd / cm) 13,3 x 44,5 x 71,1 Unit Weight (lbs.) 174.00 Unit Weight (kg) 78.93 STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Certifications CAN/CSA C22.2; CAN/CSA-C22.2 No. 107.3 (Canada); IEC/EN 62040; UL 1778 Product Compliance RoHS; CE (Europe); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 2-year limited warranty Product Warranty Period (International) 1-year limited warranty Product Warranty Period (Mexico) 1-year limited warranty Product Warranty Period (Puerto Rico) 1-year limited warranty Optional Coverage 3 year, 5 year, next day and on-site warranty coverage available © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
BP192V12RT3US 价格&库存
很抱歉,暂时无法提供与“BP192V12RT3US”相匹配的价格&库存,您可以联系我们找货
