1000 Eaton Boulevard
Cleveland, OH 44122
United States
External 192V Tower Battery Pack for select
Tripp Lite UPS Systems (BP192V1407C-1PH)
MODEL NUMBER: BP192V1407C-1PH
Description
Tripp Lite's BP192V1407C-1PH External Battery Pack with built-in 7A charger offers extended battery
runtime when used in conjunction with compatible Tripp Lite UPS systems. Includes heavy gauge cabling
to connect to host UPS. Multiple BP192V1407C-1PH batteries can be daisy-chained for longer runtime
configurations with appropriate contractor-supplied battery pack interconnection cabling (see manual).
Internal battery charger is powered via hardwire connection to 120V 30A electrical service.
COMPATIBLE UPS SYSTEMS: SU5000RT4U, SU6000RT4U, SU8000RT4U and other Tripp Lite UPS
systems specifying the use of this battery pack.
Features
Offers extended-run UPS operation when used in conjunction with compatible Tripp Lite UPS systems
10 year design life
Multiple battery packs can be daisy-chained through each other to the UPS for even longer extended
run operation
Cabling to connect one BP192V1407C-1PH is included - cabling for additional battery packs is
contractor supplied
Includes built-in 7A charger powered via hardwire 120VAC 30A input connection
Specifications
OVERVIEW
UPC Code
037332146717
BATTERY
Expandable Runtime
Yes
1/2
Highlights
Extends runtime of compatible
Tripp Lite UPS Systems using
192VDC configuration
Includes UPS connection
cabling
10 year design life
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
Cleveland, OH 44122
United States
Expandable Runtime Description
Multiple battery packs can be daisy-chained to the UPS for extended runtime. Configuration specific cabling for
multi-battery pack configurations is contractor provided.
DC System Voltage (VDC)
192
UPS Connection
Included cabling enables connection between unique UPS connector and hardwire DC terminals in battery pack.
Cabling to connect multiple external battery packs is contractor provided.
PHYSICAL
Material of Construction
Steel
External Battery Pack Form Factor
Tower
Shipping Dimensions (hwd / in.)
0.00 x 0.00 x 0.00
Shipping Dimensions (hwd / cm)
0.00 x 0.00 x 0.00
Shipping Weight (lbs.)
2075.00
Shipping Weight (kg)
941.20
Unit Dimensions (hwd / in.)
60.000 x 32.000 x 30.000
Unit Dimensions (hwd / cm)
152.4 x 82.3 x 73.2
Unit Weight (lbs.)
2070
Unit Weight (kg)
938.94
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“BP192V1407C-1PH”相匹配的价格&库存,您可以联系我们找货
