BP240V09
BP240V09
    TRIPPLITE
    120VDC EXTERNAL BATTERY CABINET
BP240V09 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States ±120VDC External Battery Cabinet for 10-20K S3M-Series 3-Phase UPS - 80x 9Ah VRLA (AGM) Batteries Highlights ● Ideal for IT applications requiring high capacity, high availability and longer runtime ● Supports daisy-chaining to additional battery packs of same model for even more runtimes ● Steel cabinet with locking front door for easy access to recyclable VRLA (AGM) batteries ● Fuses and output breaker protect against potentially hazardous overcurrent ● Pre-installed rolling casters allow easy adjustment at installation location MODEL NUMBER: BP240V09 Applications ● Extend the runtime of your compatible Tripp Lite UPS system to maintain operation during all power condition ● Up to two battery packs can be connected in parallel when using with S3M10-20K-NIB, No Internal Battery UPS models for extended runtime External battery pack provides extended backup runtime for Tripp Lite 10-20K S3M-Series 3-phase UPS systems. Features ±120VDC External Batteries Give Your Compatible 3-Phase UPS Extended Runtime This external battery pack connects to a compatible SmartOnline® S3M-Series 3-phase UPS system to provide long-lasting battery backup for data centers, telecommunications, networks, industrial facilities, security, emergency systems and other mission-critical applications that require high capacity, high availability and extended runtime. The BP240V09 can only be connected in parallel with one other BP240V09 cabinet when using with an S3M10-20K-NIB (UPS without internal batteries) models for longer extended-run operation. Rugged Steel Construction Designed to Last in Demanding IT Applications The cabinet is made from heavy-gauge steel with a baked powder-coated finish that helps prevent chipping and corrosion. The hinged front door provides easy access to the recyclable internal batteries. The door locks securely to help prevent damage, tampering or theft. Fuses and output breaker protect against potentially hazardous overcurrent. Ships Ready for Immediate Deployment Pre-installed rolling casters allow easy adjustment at the installation location. Adjustable levelers support secure long-term deployment on a stable surface. Includes heavy-gauge cabling with high-current DC connectors for simple installation. Specifications OVERVIEW UPC Code 037332253040 INPUT 1/2 System Requirements 3-phase 208V UPS models S3M10K1B, S3M10K2B, S3M10K3B, S3M10K-NIB, S3M15K2B, S3M15K3B, S3M15KNIB, S3M20K3B, S3M20K-NIB or other UPS specifying compatibility Package Includes ● BP240V09 External Battery Cabinet for S3M10K/15K/20K 3Phase UPS ● (2) Battery cables, 1.3 m ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Input Phase 3-Phase BATTERY Expandable Runtime Yes Expandable Runtime Description Up to two battery packs can be connected in parallel when using with S3M10-20K-NIB, No Internal Battery UPS models for extended runtime DC System Voltage (VDC) +/- 120VDC UPS Connection Hardwire (contractor supplies wiring - see Owner's Manual for gauge recommendations and complete installation instructions) PHYSICAL Material of Construction Steel Rack Height 0U External Battery Pack Form Factor Tower Installation Form Factors Supported with Included Accessories Tower Shipping Dimensions (hwd / in.) 37.40 x 14.20 x 39.40 Shipping Weight (kg) 279.23 Unit Dimensions (hwd / in.) 34.200 x 9.800 x 35.400 Unit Dimensions (hwd / cm) 88.87 x 24.89 x 89.92 Unit Weight (lbs.) 534 Unit Weight (kg) 242.22 STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
BP240V09 价格&库存
很抱歉,暂时无法提供与“BP240V09”相匹配的价格&库存,您可以联系我们找货
