BP240V65
BP240V65
    TRIPPLITE
    120VDC EXTERNAL BATTERY CABINET
BP240V65 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States ±120VDC External Battery Cabinet for Select 1050K S3M-Series 3-Phase UPS - 20x 65Ah VRLA (AGM) Batteries Highlights ● Ideal for IT applications requiring high capacity, high availability and longer runtime ● Supports daisy-chaining to additional battery packs of same model for even more runtime ● Steel cabinet with locking front door for easy access to recyclable VRLA (AGM) batteries ● Fuses and output breaker protect against potentially hazardous overcurrent ● Industrial design matches UPS cabinets for a clean, professional appearance MODEL NUMBER: BP240V65 Applications ● Extend the runtime of your compatible Tripp Lite UPS system to maintain operation during all power conditions ● Daisy-chain to additional battery cabinets to provide even longer extended-run operation for backing up essential equipment External battery pack provides extended backup runtime for select Tripp Lite 10-50K S3M-Series 3-phase UPS systems. Features System Requirements ±120VDC External Batteries Give Your Compatible 3-Phase UPS Extended Runtime This external battery pack connects to a compatible SmartOnline® S3M-Series 3-phase UPS system to provide long-lasting battery backup for data centers, telecommunications, networks, industrial facilities, security, emergency systems and other mission-critical applications that require high capacity, high availability and extended runtime. In addition to battery backup and extended runtime, the BP240V65 can also be daisy-chained to other external battery cabinets for even longer extended-run operation. Rugged Steel Construction Designed to Last in Demanding IT Applications The cabinet is made from heavy-gauge steel with a baked powder-coated finish that helps prevent chipping and corrosion. The hinged front door provides easy access to the recyclable internal batteries. The door locks securely to help prevent damage, tampering or theft. Fuses and output breaker protect against potentially hazardous overcurrent. Ships Ready for Immediate Deployment Includes heavy-gauge cabling with high-current DC connectors for simple installation with 10-20K UPS models. Also includes input/output terminal blocks for hardwire installation with larger UPS models. Battery cables feed into the cabinet through conduit knockouts built into the bottom panel. Specifications OVERVIEW UPC Code 037332257741 INPUT Input Phase 3-Phase 1/2 3-phase 208V UPS models S3M10K-NIB, S3M15K-NIB, S3M20K-NIB, S3M25K, S3M30K, S3M50K or other UPS specifying compatibility Package Includes ● BP240V65 External Battery Cabinet for Select 10-50K S3MSeries 3-Phase UPS ● (2) Battery cables, 3 m ● (4) Cabinet bottom side metal skirts ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States BATTERY Expandable Runtime Yes DC System Voltage (VDC) +/- 120VDC UPS Connection Hardwire (contractor supplies wiring - see Owner's Manual for gauge recommendations and complete installation instructions) PHYSICAL Material of Construction Steel Rack Height 0U External Battery Pack Form Factor Tower Installation Form Factors Supported with Included Accessories Tower Shipping Dimensions (hwd / in.) 54.90 x 36.20 x 41.20 Shipping Weight (kg) 668.55 Unit Dimensions (hwd / in.) 47.200 x 31.500 x 35.400 Unit Dimensions (hwd / cm) 119.89 x 80.01 x 89.92 Unit Weight (lbs.) 1341.6 Unit Weight (kg) 608.54 STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
BP240V65 价格&库存
很抱歉,暂时无法提供与“BP240V65”相匹配的价格&库存,您可以联系我们找货
