BP240V65L-NIB
BP240V65L-NIB
    TRIPPLITE
    120VDC EXTERNAL BATTERY CABINET
BP240V65L-NIB 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States ±120VDC External Battery Cabinet for Select 10100K S3M-Series 3-Phase UPS - Requires 40x 65Ah Batteries (Not Included) Highlights ● Ideal for IT applications requiring high capacity, high availability and longer runtime ● Supports daisy-chaining to additional battery packs of same model for even more runtime ● Steel cabinet with locking door for easy access to user-installed VRLA (AGM) batteries ● Fuses and output breaker protect against potentially hazardous overcurrent ● Industrial design matches UPS cabinets for a clean, professional appearance MODEL NUMBER: BP240V65L-NIB Applications ● Extend the runtime of your compatible Tripp Lite UPS system to maintain operation during all power conditions ● Daisy-chain to additional battery cabinets to provide even longer extended-run operation for backing up essential equipment ● Customize your application with the internal batteries of your choice External battery pack provides extended backup runtime for select Tripp Lite 10-100K S3M-Series 3phase UPS systems. Features ±120VDC Battery Cabinet Gives Your Compatible 3-Phase UPS Extended Runtime This external battery pack connects to a compatible SmartOnline® S3M-Series 3-phase UPS system to provide long-lasting battery backup for data centers, telecommunications, networks, industrial facilities, security, emergency systems and other mission-critical applications that require high capacity, high availability and extended runtime. In addition to battery backup and extended runtime, the BP240V65LNIB can also be daisy-chained to other external battery cabinets for even longer extended-run operation. Rugged Steel Construction Designed to Last in Demanding IT Applications The cabinet is made from heavy-gauge steel with a baked powder-coated finish that helps prevent chipping and corrosion. The hinged front door provides easy access to the user-installed internal batteries. The door locks securely to help prevent damage, tampering or theft. Fuses and output breaker protect against potentially hazardous overcurrent. Ships Ready for Immediate Battery Installation All required internal battery cabling is included. External battery cables feed into the cabinet through conduit knockouts built into the bottom panel. Specifications 1/2 System Requirements 3-phase 208V UPS models S3M10K-NIB, S3M15K-NIB, S3M20K-NIB, S3M25K, S3M30K, S3M50K, S3M60K, S3M80K, S3M100K or other UPS specifying compatibility Package Includes ● BP240V65L-NIB External Battery Cabinet for Select 10100K S3M-Series 3-Phase UPS ● (2) External battery cables, 3 m ● (16) Internal battery cables ● (28) Copper jumper bars ● (16) Battery insulators ● (4) Cabinet bottom side metal skirts ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332257758 INPUT Input Phase 3-Phase BATTERY Expandable Runtime Yes DC System Voltage (VDC) +/- 120VDC UPS Connection Hardwire (contractor supplies wiring - see Owner's Manual for gauge recommendations and complete installation instructions) PHYSICAL Material of Construction Steel Rack Height 0U External Battery Pack Form Factor Tower Installation Form Factors Supported with Included Accessories Tower Shipping Dimensions (hwd / in.) 70.90 x 36.20 x 49.10 Shipping Weight (kg) 353.30 Unit Dimensions (hwd / in.) 63.000 x 31.500 x 43.400 Unit Dimensions (hwd / cm) 160 x 80 x 110.24 Unit Weight (lbs.) 624.4 Unit Weight (kg) 283.22 STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
BP240V65L-NIB 价格&库存
很抱歉,暂时无法提供与“BP240V65L-NIB”相匹配的价格&库存,您可以联系我们找货
