CLAMPINTL
CLAMPINTL
    TRIPPLITE
    CLAMP-ON POWER STRIP HOLDER, WHI
CLAMPINTL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Clamp-On Power Strip Holder, White, International MODEL NUMBER: CLAMPINTL Highlights ● Adjustable desk clamp fits most tables and other flat surfaces 10–50 mm thick ● Adds AC accessibility at arm’s length to avoid connecting power cords under your desk ● Accommodates most surge protectors and power strips 50–70 mm wide ● EVA foam pads on the clamp protect your desktop from scuffs and scratches ● Heavy-duty ABS construction strong and durable enough for day-to-day use Applications ● Mount a power strip to the edge of a workbench for easy access to outlets ● Install a power strip at a trade show booth or other temporary location without drilling holes ● Mount a power strip to a desktop without damaging its surface ● Add conveniently placed power outlets to your home office to facilitate working from home Clamps to your desktop or workstation to provide easy access to AC and USB power where you most need it. Features Power Strip Clamp Mounts Securely on Your Desktop without DrillingThis clamp-on holder for power strips and surge protectors is easy to install without the hassle of drilling into walls or workbenches. Keep AC outlets and USB ports within easy reach of your desk, table or workspace by attaching the CLAMPINTL to any flat surface 10 to 50 millimeters (0.4 to 2 inches) thick. No tools are needed. Just slide the clamps onto the surface’s edge, tighten the adjustment knobs by hand, and snap your surge or power strip into the mounting clip. Package Includes ● No More Crawling Under Desks to Plug Devices into Hard-to-Reach OutletsAdd AC and USB power where you most need it. The CLAMPINTL lets you install a power strip or surge protector within an arm’s reach of your chair. The heavy-duty plastic clamp accepts most strips 50 to 70 millimeters (2 to 2.75 inches) in width. Soft EVA foam pads on the clamp protect your desk from scuffs and scratches. Retrofit Existing Installations to Improve Access to Outlets Add AC outlets and USB ports somewhere new or change the mounting of an existing power or surge strip to improve access to power. A cable management clip in the rear keeps power cords neat and tidy. Specifications OVERVIEW UPC Code 037332255631 Accessory Type Mounting Accessories Accessory Class Power Strip Accessories INPUT Input Cord Length (ft.) 0 1/3 CLAMPINTL Clamp-On Power Strip Holder, White 1000 Eaton Boulevard Cleveland, OH 44122 United States Right-Angle Plug No Input Cord Length (m) 0.00 Integrated Cord Clip No OUTPUT Output Receptacles Universal outlets Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) No SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 0 Automatic Shut-Off No DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Material of Construction ABS Power Cord Color Gray Housing Color Gray Mounting Holes or Slots No Receptacle Color Gray Shipping Dimensions (hwd / in.) 4.13 x 2.80 x 6.70 Shipping Dimensions (hwd / cm) 10.49 x 7.11 x 17.02 Shipping Weight (lbs.) 1.20 Shipping Weight (kg) 0.54 Unit Dimensions (hwd / in.) 3.900 x 2.400 x 6.400 Unit Dimensions (hwd / cm) 9.9 X 7.1 X 4.8 Unit Weight (lbs.) 0.81 Unit Weight (kg) 0.37 FEATURES & SPECIFICATIONS Rotatable Outlets No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Antimicrobial No STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
CLAMPINTL 价格&库存
很抱歉,暂时无法提供与“CLAMPINTL”相匹配的价格&库存,您可以联系我们找货
