1000 Eaton Boulevard
Cleveland, OH 44122
United States
Clamp-On Power Strip Holder, White
Highlights
Adjustable desk clamp fits most
tabletops and other flat surfaces
0.4–2 in. thick
Adds AC accessibility at arm’s
length to avoid connecting
power cords under your desk
Accommodates most surge
protectors and power strips
1.6–2.4 in. wide
EVA foam pads on the clamp
protect your desktop from scuffs
and scratches
Heavy-duty ABS construction
strong and durable enough for
day-to-day use
MODEL NUMBER: CLAMPUSW
Applications
Clamps to your desktop or workstation to provide easy access to AC and USB power where you most
need it.
Features
Power Strip Clamp Mounts Securely on Your Desktop without DrillingThis clamp-on holder for power
strips and surge protectors is easy to install without the hassle of drilling into walls or workbenches. Keep
AC outlets and USB ports within easy reach of your desk, table or workspace by attaching the
CLAMPUSW to any flat surface 0.4 to 2 inches thick. No tools are needed. Just slide the clamps onto the
surface’s edge, tighten the adjustment knobs by hand, and snap your surge or power strip into the
mounting clip.
Mount a power strip to the edge
of a workbench for easy access
to outlets
Install a power strip at a trade
show booth or other temporary
location without drilling holes
Mount a power strip to a
desktop without damaging its
surface
Add conveniently placed power
outlets to your home office to
facilitate working from home
Package Includes
No More Crawling Under Desks to Plug Devices into Hard-to-Reach OutletsAdd AC and USB power
where you most need it. The CLAMPUSW lets you install a power strip or surge protector within an arm’s
reach of your chair. The heavy-duty plastic clamp accepts most strips 1.6 to 2.4 inches in width. Soft EVA
foam pads on the clamp protect your desk from scuffs and scratches.
Retrofit Existing Installations to Improve Access to Outlets Add AC outlets and USB ports
somewhere new or change the mounting of an existing power or surge strip to improve access to power.
A cable management clip in the rear keeps power cords neat and tidy.
Specifications
OVERVIEW
UPC Code
037332255617
Accessory Type
Mounting Accessories
Accessory Class
Power Strip Accessories
INPUT
Input Cord Length (ft.)
Right-Angle Plug
No
1/3
CLAMPUSW Clamp-On Power
Strip Holder, White
Cleveland, OH 44122
United States
Input Cord Length (m)
0.00
Integrated Cord Clip
No
OUTPUT
Output Receptacles
Universal outlets
Right-Angle Outlets
No
USER INTERFACE, ALERTS & CONTROLS
Diagnostic LED(s)
No
SURGE / NOISE SUPPRESSION
AC Suppression Joule Rating
Automatic Shut-Off
No
DATALINE SURGE SUPPRESSION
Cable (Coax) Protection
No
Network (Ethernet) Protection
No
Telephone/DSL Protection
No
PHYSICAL
Material of Construction
ABS
Power Cord Color
Gray
Housing Color
Gray
Mounting Holes or Slots
No
Receptacle Color
Gray
Shipping Dimensions (hwd / in.)
4.13 x 2.80 x 6.30
Shipping Dimensions (hwd / cm)
10.49 x 7.11 x 16.00
Shipping Weight (lbs.)
1.10
Shipping Weight (kg)
0.50
Unit Dimensions (hwd / in.)
3.900 x 2.800 x 1.900
Unit Dimensions (hwd / cm)
9.9 X 7.1 X 4.8
Unit Weight (lbs.)
0.81
Unit Weight (kg)
0.37
FEATURES & SPECIFICATIONS
Rotatable Outlets
No
Antimicrobial
No
2/3
Cleveland, OH 44122
United States
STANDARDS & COMPLIANCE
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“CLAMPUSW”相匹配的价格&库存,您可以联系我们找货
