CT120
CT120
    TRIPPLITE
    3 线电路测试器 测试3线电路和接地连通性
CT120 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Instant-Read AC Outlet Circuit Tester with Diagnostic LEDs MODEL NUMBER: CT120 Highlights ● Simple to use plug-in tester ● Instantly displays several common wiring fault Package Includes NEMA 5-15PCT120 circuit tester Operating instructions Description This instant-read CT120 circuit tester detects wiring stability in standard 120V AC wall sockets. Simply plug the circuit tester into a receptacle and view the lighted three-lamp status display for verification of correct wiring, open ground, open neutral, open hot, hot-ground reversal and hot-neutral reversal fault conditions. Sticker on the tester offers lighting combinations for each wiring condition. Ultra-portable design and easy-to-read lighted display makes the CT120 an excellent addition to any laptop carrying case, tool belt or workbench. Low-cost design saves the expense of hiring an electrician to determine wiring stability. Features Offers instant-read notification of correct wiring status of any 120VAC wall socket with a standard NEMA515R receptacle (not for use with Ground Fault Interrupt -GFI outlets). Diagnoses several common wiring faults, including open ground, open neutral, hot-ground reversal and hot-neutral reversal fault conditions (detects most common wiring problems, but not all fault conditions) Lighted, easy to read 3 lamp status display allows non-technical users to quickly determine the presence of wiring problems and schedule electrical repairs without damage to sensitive electronic devices Ultra-portable design makes the CT120 and ideal addition to any laptop carrying case, tool belt or workbench Prevents equipment damage and unsafe wiring by easily identifying common electrical fault conditions so that they can be repaired by a qualified electrician Low cost design saves the expense of hiring a professional electrician to determine wiring stability Specifications OVERVIEW UPC Code 037332116345 Accessory Type Circuit Tester Accessory Class Power Inverter Accessories 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Nominal Input Voltage(s) Supported 120V AC Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P USER INTERFACE, ALERTS & CONTROLS Diagnostic LED Details 3 indicator lights (2 yellow / 1 red) PHYSICAL Housing Color Black Shipping Dimensions (hwd / in.) 4.80 x 1.80 x 4.00 Shipping Dimensions (hwd / cm) 12.19 x 4.57 x 10.16 Shipping Weight (lbs.) 0.20 Shipping Weight (kg) 0.09 Unit Dimensions (hwd / in.) 3.000 x 1.500 x 0.500 Unit Dimensions (hwd / cm) 7.62 x 3.81 x 1.27 Unit Weight (lbs.) 0.08 Unit Weight (kg) 0.04 STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
CT120 价格&库存
很抱歉,暂时无法提供与“CT120”相匹配的价格&库存,您可以联系我们找货
