DCPU2
DCPU2
    TRIPPLITE
    MOBILE CPU CADDY FOR COMPUTER TO
DCPU2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Mobile CPU Caddy for Computer Towers - Width Adjustable, Locking Casters, Black MODEL NUMBER: DCPU2 Highlights ● Rolls under your desk to leave valuable tabletop and floor space clear ● Adjusts to fit wide range of CPUs from 4.7 to 8.2 in. wide (11.9 to 20.9 cm) ● Durable metal construction with powder-coated finish blends into any décor ● Open frame design allows easy access to rear cabling and ports for quick adjustments ● 4 swivel casters (2 locking) allow smooth, easy movement across the floor Applications ● Rolling caddy secures your CPU under a desk, freeing up tabletop space and providing easy access to front and rear ports and cables. Incorporate a PC or UPS system into your workspace without taking up valuable desk, table or floor space Package Includes ● DCPU2 Mobile CPU Caddy Features ● (4) Locking casters Rolling CPU Stand Designed to Save Valuable Space in Your Computer WorkstationWhy keep your desktop computer on your desktop, where it not only takes up valuable space, but is also pushed against the wall, making it difficult to access rear USB ports and cable connections? The adjustable DCPU2 lets you securely place your tower CPU beneath your desktop, saving space and keeping important ports and switches within easy reach. Made from durable steel, the caddy features a scratch-resistant black powdercoated finish that blends with your décor and stands up to frequent handling. ● Installation hardware ● Owner’s manual Ideal for Safely Holding Your Desktop Computer at Home, School and the OfficeThis CPU caddy includes four metal casters that roll smoothly in every direction, wherever you need it. Store your PC under your desk within easy reach, and merely roll it toward you to easily attach cables and reach ports located in the rear of the unit. Two of the wheels lock securely to keep your computer firmly in place, yet easily accessible. Storing your computer below your desk, but off the floor, helps keep it safe from dust and dirt. Adjusts to Accommodate Most Tower CPUsThe adjustable metal frame is open at the top and fits most computer cases ranging from 4.7 to 8.2 inches (11.9 to 20.9 centimeters) wide. In addition to PC cases, the frame also supports UPS systems, gaming towers and other essential workspace peripherals up to 22 pounds (10 kilograms). A locking knob holds the unit firmly in place. Vented sides allow maximum airflow and help prevent your computer from overheating. Specifications OVERVIEW UPC Code 037332248886 Device Compatibility Monitor/HDTV PHYSICAL 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States Color Black Material of Construction Steel Motion Fixed Maximum Weight Capacity (lbs.) 22 Maximum Weight Capacity (kg) 10 Shipping Dimensions (hwd / in.) 10.50 x 5.40 x 6.10 Shipping Weight (kg) 1.72 Unit Dimensions (hwd / in.) 5.030 x 8.200 x 10.300 Unit Dimensions (hwd / cm) 12.8 x 20.9 x 10.3 Unit Weight (lbs.) 3.1 Unit Weight (kg) 1.41 Assembly Required Yes FEATURES & SPECIFICATIONS Antimicrobial No Cord Management No Tools Necessary Yes Security Lock No STANDARDS & COMPLIANCE Product Compliance RoHS; RoHS3; CE (Europe); REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
DCPU2 价格&库存
很抱歉,暂时无法提供与“DCPU2”相匹配的价格&库存,您可以联系我们找货
