1000 Eaton Boulevard
Cleveland, OH 44122
United States
Mobile Quad-Screen Video Wall – For Four 45" to
55" TVs and Monitors, Heavy Duty
MODEL NUMBER: DMCVW4555X4
Highlights
Accommodates most flat-panel
displays from 45 to 55 in.
Display height adjusts up to 67.7
in. (top displays)
Combination locks secure
brackets to help deter theft of
displays
Large swivel casters roll
smoothly over carpet
Supports up to 132 lbs (59.9
kgs) per display
Applications
Quad-screen mobile cart supports mounting of four flat-panel televisions or monitors to create a portable
video wall.
Features
Create a Mobile Video Wall with Four Flat-Panel DisplaysThe DMCVW4555X4 provides a convenient
way to create a quad-screen video wall for a presentation or temporary digital signage and bring it to
audiences in classrooms, lecture halls, offices, auditoriums, conference rooms and other locations where
video resources are shared. Made primarily of steel and aluminum, this rolling video wall accommodates
most flat-panel televisions or monitors from 45 to 55 inches that weigh up to 132 lbs (59.9 kgs)
Effectively Share a Quad-Screen Video WallFour sturdy swivel casters provide smooth rolling through
doorways and over thresholds, making it possible to share quad screens within a facility instead of
purchasing multiple setups. When not in use, the cart can be rolled into a secure area for storage. Two of
the casters lock to keep the cart in position while at rest. Cable management openings in the main
columns allow you to route power and audio/video cords, reducing clutter for a clean, professional look.
Easily Mount 45" to 55" Displays and Deter TheftFor hassle-free display compatibility, this rolling video
wall supports the following VESA mounting hole patterns: 200 x 200, 200 x 300, 200 x 400, 300 x 200,
300 x 300, 300 x 400, 400 x 200, 400 x 300, 400 x 400, 500 x 200, 500 x 300, 500 x 400, 600 x 300 and
600 x 400. Fine adjustments can be made to the position of the displays using a hex key (included). The
height of both mounting plates is adjustable, and the top displays can be raised up to 67.7 inches above
the floor. Three-position combination locks (included) secure the brackets to deter theft of the displays.
Specifications
OVERVIEW
UPC Code
037332239426
Device Compatibility
Monitor/HDTV; Projector
PHYSICAL
1/2
View video in a multipurpose
area where a permanent
installation is not practical
Move a video wall into a
meeting room for a presentation
Advertise a special event
without permanently mounting
screens
Roll a temporary digital signage
installation into an auditorium
Easily move a video wall to a
secure area for storage between
events
Package Includes
All DMCVW4555X4 components
(assembly required)
Assembly fasteners
Display mounting fasteners
(4) Three-position combination
locks
Hex keys
Wrench
Owner’s manual
Cleveland, OH 44122
United States
Color
Black; Silver
Material of Construction
steel
VESA Pattern (mm)
200x200; 200x300; 200x400; 300x200; 300x300; 300x400; 400x200; 400x300; 400x400; 500x200; 500x300;
500x400; 600x300; 600x400
Motion
Fixed
Mounting Location
Floor
Maximum Weight Capacity (lbs.)
528
Maximum Weight Capacity (kg)
240
Number of Displays
4
Shipping Dimensions (hwd / in.)
9.25 x 18.90 x 79.50
Shipping Dimensions (hwd / cm)
23.50 x 48.01 x 201.93
Shipping Weight (lbs.)
150.50
Shipping Weight (kg)
68.27
Unit Dimensions (hwd / in.)
67.700 x 75.800 x 41.330
Unit Dimensions (hwd / cm)
171.96 x 83.57 x 70.10
Unit Weight (lbs.)
69.4
Unit Weight (kg)
31.48
FEATURES & SPECIFICATIONS
Cord Management
Yes
Tools Necessary
Yes
Security Lock
No
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“DMCVW4555X4”相匹配的价格&库存,您可以联系我们找货
