DMFC3265M
DMFC3265M
    TRIPPLITE
    FLOOR-TO-CEILING MOUNT FOR 32" T
DMFC3265M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Floor-to-Ceiling Mount for 32" to 65" TVs and Monitors - Height Adjustable, Shelf for A/V Source Highlights ● Accommodates flat-panel displays from 32 to 65 in. and up to 55 lbs (24.9 kgs) ● Support pole adjusts for ceilings up to 12-ft. (3.66 m) high ● Pressure clamp at the floor holds mount in place ● Shelf supports a laptop, Blu-ray player or other component up to 11 lbs (4.9 kgs) ● Option for mounting to a permanent floor anchor MODEL NUMBER: DMFC3265M Applications ● Show video in a multipurpose area not equipped with A/V equipment ● Create temporary digital signage in a retail environment ● Mount an extra screen in a lobby for a special event ● Move a screen to a different corner as seating arrangements change in a living room or conference room ● Add a screen to a classroom without drilling holes for a wallmount display An adjustable-height support pole provides flexible screen placement in rooms with up to 12-foot ceilings. Includes A/V source shelf. Features Floor-to-Ceiling Mount Works in Almost Any Room with a Ceiling up to 12-ft. (3.66 m) HighThe DMFC3265M mount offers flexible screen placement in rooms where installing a display mount on a wall is not possible or desirable. Made of steel with a black powder-coated finish, the support pole has telescoping adjustment to mount in rooms with solid ceilings from 6.8-ft. (2.07 m) to 12-ft. (3.66 m) high. A pressure clamp at the base secures the pole. As long as you have access to power, you can mount the support pole anywhere in the room. Pole diameter is approximately 1.7 inches; the top telescoping section is slightly narrower. Easily Mount a 32" to 65" Display and Adjust the Viewing AngleMount the display bracket to the support pole at the best height for your application. Designed for flat-panel displays from 32 to 65 inches, the DMFC3265M supports the following VESA mounting hole patterns: 100 x 100, 100 x 200, 200 x 200, 200 x 300, 200 x 400, 300 x 200, 300 x 300, 300 x 400, 400 x 200, 400 x 300, 400 x 400, 500 x 200, 500 x 300, 500 x 400, 600 x 300 and 600 x 400. Maximum supported weight is 55 lbs (24.9 kgs). The mount offers -3° to +3° screen level adjustment and ±180° swivel to improve the viewing angle for the audience. Store Your Video Source on the Convenient Height-Adjustable ShelfThe shelf mounts to the support pole at a height of your choosing. It provides a convenient place for your laptop, DVD or Blu-ray player or other video source. The shelf is 11 x 7.8 inches and supports up to 11 lbs (4.9 kgs). Cable guides route cords along the pole to reduce clutter. Keep the Mount Portable or Choose Permanent InstallationPerfect for temporary digital signage, the DMFC3265M does not require permanent mounting. When needs change, it can be moved without damaging the ceiling or floor. You also have the option of securing the pole to a permanently mounted floor anchor (included). Specifications OVERVIEW 1/2 Package Includes ● All DMFC3265M components (some assembly required) ● Assembly fasteners ● Display mounting fasteners ● Hex keys ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332239396 Device Compatibility Monitor/HDTV PHYSICAL Color Black Material of Construction Steel VESA Pattern (mm) 100x100; 100x200; 200x200; 200x300; 200x400; 300x200; 300x300; 300x400; 400x200; 400x300; 400x400; 500x200; 500x300; 500x400; 600x300; 600x400 Mounting Location Floor Maximum Weight Capacity (lbs.) 88 Maximum Weight Capacity (kg) 40 Number of Displays 1 Shipping Dimensions (hwd / in.) 5.10 x 9.10 x 84.60 Shipping Dimensions (hwd / cm) 12.95 x 23.11 x 214.88 Shipping Weight (lbs.) 21.40 Shipping Weight (kg) 9.71 Unit Dimensions (hwd / in.) 149.600 x 28.300 x 7.870 Unit Dimensions (hwd / cm) 379.98 x 71.8 x 19.99 Unit Weight (lbs.) 16.7 Unit Weight (kg) 7.57 FEATURES & SPECIFICATIONS Cord Management No Tools Necessary Yes Security Lock No WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
DMFC3265M 价格&库存
很抱歉,暂时无法提供与“DMFC3265M”相匹配的价格&库存,您可以联系我们找货
