1000 Eaton Boulevard
Cleveland, OH 44122
United States
Fixed TV Wall Mount for 26” to 70” Displays
Highlights
Accepts most popular flat- and
curved-screen displays from 26
to 70 in. up to 165 lb.
Automatic spring locks with
quick-release cords ensures
quick and easy display removal
Adjustable horizontal mounting
rails help compensate for offcenter wall studs
Open architecture and built-in
level enable easy cable access
and accurate leveling
Conforms to current VESA
standards to ensure
compatibility with your display
MODEL NUMBER: DWF2670X
System Requirements
Mounts a flat- or curved-screen television or monitor on the wall in your classroom, conference room,
restaurant, lobby or home theater.
Features
Mounts Your TV or Monitor on the Wall for a Perfect Viewing Angle
Recommended for home theaters, classrooms, conference rooms, hotels, bars, restaurants or anywhere
else you may want to show off a television or monitor, this low-profile TV wall mount is hidden out of sight
behind the display for a sleek, professional appearance. It fits most flat- and curved-panel displays from
26 to 70 inches and up to 165 pounds (75 kilograms).
Durable All-Metal Construction Provides Convenient Cable Access
The fixed TV wall mount is constructed from heavy-duty steel with a powder-coated black finish that
resists scratches. Its open frame design with smooth edges enables easy access to cables. Horizontal
mounting rails adjust to compensate for off-center wall studs. A built-in bubble level helps ensure your
display is evenly mounted. Removing and replacing the display is fast and simple using the automatic
spring locks with quick-release cords.
VESA-Compliant Mounting Ensures Display Compatibility
VESA (Video Electronics Standards Association) promotes uniformity in the video electronics industry by
developing standards for TVs and monitors. For hassle-free display compatibility, this mount supports the
following VESA mounting hole patterns: 50 x 50, 75 x 75, 100 x 100, 100 x 150, 100 x 200, 150 x 100, 150
x 150, 200 x 100, 200 x 200, 200 x 400, 300 x 200, 300 x 300, 350 x 350, 400 x 200, 400 x 300 and 400 x
400. Mounting hardware is included.
Specifications
OVERVIEW
UPC Code
037332266095
Device Compatibility
Monitor/HDTV
PHYSICAL
Color
Black
1/3
Supports VESA mounting hole
patterns 50 x 50, 75 x 75, 100 x
100, 150 x 150, 200 x 100, 200 x
300 and 400 x 400
Package Includes
DWF2670X Fixed TV Wall
Mount
Mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
Material of Construction
Steel
VESA Pattern (mm)
50x50; 75x75; 100x100; 100x150; 100x200; 200x100; 200x200; 200x400; 300x200; 300x300; 350x350; 400x200;
400x300; 400x400
Motion
Fixed
Mounting Location
Wall
Degrees of Motion
Fixed
Distance from Wall (in.)
1.1
Distance from Wall (cm)
3
Distance from Wall (mm)
28
Minimum Screen Size (in.)
26
Minimum Screen Size (cm)
66.04
Maximum Screen Size (in.)
70
Maximum Screen Size (cm)
177.8
Maximum Weight Capacity (lbs.)
165
Maximum Weight Capacity (kg)
75
Number of Displays
1
Unit Dimensions (hwd / in.)
16.500 x 17.240 x 1.100
Unit Dimensions (hwd / cm)
42.0 x 43.79 x 2.79
Unit Weight (lbs.)
2.3
Unit Weight (kg)
1.04
Assembly Required
Yes
FEATURES & SPECIFICATIONS
Antimicrobial
No
Cord Management
No
Tools Necessary
Yes
Security Lock
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; RoHS3; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
2/3
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“DWF2670X”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+261.584371+32.44942
- 10+232.4802510+28.83907
- 25+221.8160825+27.51618
- 50+214.0749650+26.55590
- 100+206.60103100+25.62877
- 250+197.37783250+24.48463
