DWMSCL4570VW
DWMSCL4570VW
    TRIPPLITE
    POP-OUT SECURITY TV WALL MOUNT W
DWMSCL4570VW 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Pop-Out Security TV Wall Mount with Combination Lock for 45” to 70” Televisions and Monitors, Landscape Highlights ● Accepts most popular flatscreen displays from 45 to 70 in. up to 154 lb. ● Pop-out design with kickstand allows easy access during installation and maintenance ● Anti-theft locking hole with combination lock deters tampering and theft ● Smoothly shifts left and right along a lateral bracket to find the ideal position ● Displays in landscape mode for easy reading of menus, schedules, etc. MODEL NUMBER: DWMSCL4570VW System Requirements Flat-screen television, monitor, whiteboard or interactive display from 45 to 70 in. Package Includes ● DWMSCL4570VW Pop-Out Security TV Wall Mount ● 4-position combination lock Features ● Mounting hardware Pop-Out Display Mount Designed for Video Wall Installations A pop-out feature and micro-adjustability make the DWMSCL4570VW wall mount a purpose-built solution for video walls in home theaters, offices, conference centers, medical facilities, airports, libraries, hotels, bars, restaurants and security stations. This landscape-oriented wall mount fits most flat-panel displays from 45 to 70 inches and up to 154 pounds (70 kilograms). ● Owner’s manual Security TV wall mount with combination lock mounts your 45–70 in. flat-panel display to the wall in landscape mode. Pop-Out Feature Supports Convenient Cable Access and Screen Adjustments To unlock the pop-out mechanism, press lightly on the front of your display and release. Kickstands provide tilt access for easy cable management and maintenance and make it easier to replace a connected display. This is especially helpful in video wall installations, where adjacent screens may limit access. You can also shift the display left or right along the lateral bracket, as well as adjust the height and viewing angle. When the display is in the ideal position, insert the included plastic anti-skid blocks in the brackets to secure it in place and prevent accidental pop-outs. Included Combination Lock Deters Display Theft The four-position combination lock secures the display bracket to the wall plate to deter theft, which can be a concern in public areas with unguarded traffic. Deterring display theft also protects the mount, which is often damaged beyond repair when a display is stolen. Designed for Long Life in Your Video Application The heavy-duty steel frame withstands the stress of frequent adjustments, and the black powder-coated finish offers durability and scratch resistance. Your display hides both the mount and the included combination lock, maintaining a professional look. VESA-Compliant Mounting Ensures Display Compatibility VESA (Video Electronics Standards Association) promotes uniformity in the video electronics industry by developing standards for TVs and monitors. For hassle-free display compatibility, this mount supports the following VESA mounting hole patterns: 200 x 200, 300 x 300, 400 x 200, 400 x 400 and 600 x 400. Mounting hardware is included. 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332268624 PHYSICAL Color Black Material of Construction Steel VESA Pattern (mm) 200x200; 300x300; 400x200; 400x400; 600x400 Motion Full Mounting Location Wall Distance from Wall (in.) 5.6 Distance from Wall (cm) 14 Distance from Wall (mm) 142 Minimum Screen Size (in.) 45 Minimum Screen Size (cm) 114.3 Maximum Screen Size (in.) 70 Maximum Screen Size (cm) 177.8 Maximum Weight Capacity (lbs.) 154 Maximum Weight Capacity (kg) 70 Number of Displays 1 Unit Dimensions (hwd / in.) 19.020 x 36.770 x 12.050 Unit Dimensions (hwd / cm) 48.31 x 93.40 x 30.61 Unit Weight (lbs.) 33 Unit Weight (kg) 14.97 Assembly Required Yes FEATURES & SPECIFICATIONS Antimicrobial No Cord Management No Tools Necessary Yes Security Lock Yes STANDARDS & COMPLIANCE Product Compliance RoHS; RoHS3; REACH WARRANTY & SUPPORT 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) 5-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
DWMSCL4570VW 价格&库存
很抱歉,暂时无法提供与“DWMSCL4570VW”相匹配的价格&库存,您可以联系我们找货
