1000 Eaton Boulevard
Cleveland, OH 44122
United States
Pop-Out Security TV Wall Mount with
Combination Lock for 45” to 70” Televisions and
Monitors, Portrait
Highlights
Accepts most popular flatscreen displays from 45 to 70 in.
up to 154 lb.
Pop-out design with kickstand
allows easy access during
installation and maintenance
Anti-theft locking hole with
combination lock deters
tampering and theft
Smoothly shifts left and right
along a lateral bracket to find
the ideal position
Displays in portrait mode for
easy reading of directions,
announcements, etc.
MODEL NUMBER: DWMSCP4570VW
System Requirements
Flat-screen television, monitor,
whiteboard or interactive display
from 45 to 70 in.
Package Includes
DWMSCP4570VW Pop-Out
4-position combination lock
Features
Mounting hardware
Pop-Out Display Mount Designed for Video Wall Installations
A pop-out feature and micro-adjustability make the DWMSCP4570VW wall mount a purpose-built solution
for video walls in home theaters, offices, conference centers, medical facilities, airports, libraries, hotels,
bars, restaurants and security stations. This portrait-oriented wall mount fits most flat-panel displays from
45 to 70 inches and up to 154 pounds (70 kilograms).
Owner’s manual
Security TV wall mount with combination lock mounts your 45–70 in. flat-panel display to the wall in
portrait mode.
Pop-Out Feature Supports Convenient Cable Access and Screen Adjustments
To unlock the pop-out mechanism, press lightly on the front of your display and release. Kickstands
provide tilt access for easy cable management and maintenance and make it easier to replace a
connected display. This is especially helpful in video wall installations, where adjacent screens may limit
access. You can also shift the display left or right along the lateral bracket, as well as adjust the height
and viewing angle. When the display is in the ideal position, insert the included plastic anti-skid blocks in
the brackets to secure it in place and prevent accidental pop-outs.
Included Combination Lock Deters Display Theft
The four-position combination lock secures the display bracket to the wall plate to deter theft, which can
be a concern in public areas with unguarded traffic. Deterring display theft also protects the mount, which
is often damaged beyond repair when a display is stolen.
Designed for Long Life in Your Video Application
The heavy-duty steel frame withstands the stress of frequent adjustments, and the black powder-coated
finish offers durability and scratch resistance. Your display hides both the mount and the included
combination lock, maintaining a professional look.
VESA-Compliant Mounting Ensures Display Compatibility
VESA (Video Electronics Standards Association) promotes uniformity in the video electronics industry by
developing standards for TVs and monitors. For hassle-free display compatibility, this mount supports the
following VESA mounting hole patterns: 200 x 200, 300 x 300, 400 x 200, 400 x 400 and 400 x 600.
Mounting hardware is included.
1/3
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332268631
Device Compatibility
Monitor/HDTV
PHYSICAL
Color
Black
Material of Construction
Steel
VESA Pattern (mm)
200x200; 200x400; 300x300; 400x400; 400x600
Motion
Full
Mounting Location
Wall
Distance from Wall (in.)
6
Distance from Wall (cm)
15
Distance from Wall (mm)
152
Minimum Screen Size (in.)
45
Minimum Screen Size (cm)
114.3
Maximum Screen Size (in.)
70
Maximum Screen Size (cm)
177.8
Maximum Weight Capacity (lbs.)
154
Maximum Weight Capacity (kg)
70
Number of Displays
1
Unit Dimensions (hwd / in.)
26.970 x 22.830 x 12.400
Unit Dimensions (hwd / cm)
65.5 X 57.9 X 31.5
Unit Weight (lbs.)
31
Unit Weight (kg)
14.06
Assembly Required
Yes
FEATURES & SPECIFICATIONS
Antimicrobial
No
Cord Management
No
Tools Necessary
Yes
Security Lock
Yes
STANDARDS & COMPLIANCE
Product Compliance
RoHS; RoHS3; REACH
2/3
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“DWMSCP4570VW”相匹配的价格&库存,您可以联系我们找货
