1000 Eaton Boulevard
Cleveland, OH 44122
United States
EnviroSense2 (E2) Water Leak Detection Sensor
Highlights
Mounts 3 mm above raised floor
to detect water or other fluid
leakage
Must be used in conjunction with
WEBCARDLX or built-in LX
Platform interface along with
E2MTHDI
Includes mounting materials for
quick and easy installation
Made from durable fire-retardant
ABS to ensure long life in your
data center
Ideal tool for protecting your IT,
data center or building
maintenance application
MODEL NUMBER: E2SLD
System Requirements
Leak detection sensor works with compatible UPS or PDU to detect leakage of water or other electrically
conductive fluid.
Compatible UPS or PDU
equipped with WEBCARDLX or
LX Platform interface and
E2MTHDI with polarity markings
Package Includes
Features
Receive an Immediate Alert in Case of Water Leak in Your Data Center or Wiring ClosetThe E2SLD
mounts near cooling units and other IT equipment in your server room to detect water leakage or leakage
of any electrically conductive fluid. It supports a Normally Open contact closure connection. When liquid
comes in contact with both sensor contacts, an alert notification is sent to you via web, SNMP, telnet or
SSH management interfaces.
Easy to Mount on a Raised FloorThe sensor is constructed from fire-retardant ABS plastic. Mount the
sensor to a wood, metal or concrete surface about three millimeters above the raised floor surface. Use
the included mounting screws, double-sided tape or a user-supplied adhesive. A screw terminal cover is
included to protect the wire terminals from damage or interference.
Required Accessories: WEBCARDLX or LX Platform and E2MTHDIThe E2SLD must be used with a
compatible UPS system or PDU equipped with the WEBCARDLX or LX Platform interface, along with an
E2MTHDI EnviroSense2 (E2) Environmental Sensor Module with polarity markings (sold separately). The
E2MTHDI supports E2SLD and one additional contact closure sensor.
TAA-Compliant for GSA Schedule PurchasesThe E2SLD is compliant with the Federal Trade
Agreements Act (TAA) for GSA Schedule purchases.
5-Year Warranty and Environmentally Responsible DesignThe E2SLD comes with a 5-year warranty.
It’s manufactured in compliance with strict RoHS specifications.
Specifications
OVERVIEW
UPC Code
037332213617
Accessory Type
Security Accessories
1/2
E2SLD EnviroSense2 (E2)
Screw terminal cover
22 AWG connection wire, 15 ft.
Double-sided adhesive tape
(2) #6 multi-surface mounting
screws
Owner’s manual
Cleveland, OH 44122
United States
PHYSICAL
Shipping Dimensions (hwd / in.)
1.26 x 4.49 x 6.06
Shipping Dimensions (hwd / cm)
3.20 x 11.40 x 15.39
Shipping Weight (lbs.)
0.22
Shipping Weight (kg)
0.10
COMMUNICATIONS
Product Compatibility
WEBCARDLX; WEBCARDLXMINI
FEATURES & SPECIFICATIONS
Sensing Capability
Water
STANDARDS & COMPLIANCE
Product Compliance
Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“E2SLD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1098.523911+137.81011
- 10+974.5221810+122.25406
- 25+929.1984125+116.56818
- 50+896.3203650+112.44362
- 100+877.99490100+110.14469
