1000 Eaton Boulevard
Cleveland, OH 44122
United States
Heavy-Duty USB-A to Lightning Sync/Charge
Cable, UHMWPE and Aramid Fibers, MFi
Certified - 1 ft. (0.31 m)
Highlights
Engineered using UHMWPE
and Aramid fiber to stand up to
frequent and rigorous use
Extra-strong cable construction
helps prevent fraying and loose
cable connectors
MFi-certified for broad
compatibility with your Apple
iPhone, iPad or iPod
Integral strain relief helps cable
move freely without stress or
cracking
Reversible Lightning plug
connects in either direction for
immediate no-fuss use
MODEL NUMBER: M100-001-GY-MAX
Applications
Charge and sync your Apple
iPhone, iPad or iPod using the
USB-A port on your computer or
a wall charger up to 1 ft. away
Transfer photos and other
important files between an
external hard drive and your
Apple device
Durable USB/Lightning cable connects your Apple iPhone, iPad or iPod to the USB-A port on your
computer, wall charger or car charger.
System Requirements
Features
Heavily Reinforced Cable Charges and Syncs Your Latest-Generation iPhone, iPad and iPodThis
heavy-duty USB sync/charge cable (M/M) connects your iPhone, iPad or iPod to the USB-A port on a
computer, car charger or wall charger. It allows you to charge and power your Apple device, while
simultaneously synching and transferring data at USB 2.0 data transfer speeds up to 480 Mbps. The cable
is backward compatible with previous USB generations, allowing you to use it with older equipment.
Computer, laptop or charger
with USB-A port
Most current iPhone, iPad and
iPod devices
Package Includes
Constructed Using UHMWPE and Bulletproof Aramid Fiber Designed to LastCharging cables used
with mobile devices are often pulled, strained and generally abused, sometimes to the point of failure. To
counter the stress of daily abuse, the super-robust M100-001-GY-MAX is constructed using UHMWPE
and Aramid fiber to reinforce the conductors inside the cable. The double-braided nylon jacket helps
maintain top performance and long life, while the enhanced UHMWPE and Aramid protection stands up to
the strain of rigorous and frequent use. Integral strain relief gives the cable extra flexibility, reduces stress,
and helps the cable move freely without cracking or breaking loose from the connector.
MFi-Certified for Broad Device CompatibilityThe 5V 2.4A (12W) Lightning cable is MFi-certified for use
with the latest generation of iPhone, iPad and iPod devices. The USB-A plug connects to any computer or
wall charger with a USB port.
Reversible Lightning Plug Connects in Either DirectionConnect the reversible 8-pin Lightning plug to
your Apple device for charging and synchronizing. The fumble-free plug connects in either direction to
ensure fast, easy connection every time. The cord’s one-foot length helps reduce cable clutter.
Specifications
OVERVIEW
UPC Code
037332240729
1/3
M100-001-GY-MAX Heavy-Duty
USB-A to Lightning Cable
(M/M), Gray, 1 ft. (0.3 m)
Cleveland, OH 44122
United States
Technology
Lightning; USB 2.0 (High Speed)
Cable Type
Passive
INPUT
Maximum Input Amps
2
POWER
USB Power Delivery (PD) Charging
Support
No
CHARGING
Total Charging Watts
12
PHYSICAL
Material of Construction
PVC, UHMWPE, Aramid
Cable Jacket Color
Dark Gray; Black
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
3.6mm
Wire Gauge (AWG)
30/24
Cable Length (ft.)
1
Cable Length (m)
0.30
Cable Length (in.)
12
Shipping Dimensions (hwd / in.)
0.91 x 4.57 x 2.36
Shipping Weight (kg)
0.02
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Packaging Type
Box
ENVIRONMENTAL
Operating Temperature Range
-4° to 140°F (-20° to 60°C)
Storage Temperature Range
-4° to 176°F (-20° to 80°C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
Power Provided to Connected
Device(s)
12W (5V/2.4A)
CONNECTIONS
Side A - Connector 1
USB A (MALE)
Side B - Connector 1
LIGHTNING (MALE)
2/3
Cleveland, OH 44122
United States
Connector Plating
Nickel
Contact Plating
Gold
Connector Style
Straight
FEATURES & SPECIFICATIONS
USB Specification
USB 2.0 (up to 480 Mbps)
Data Transfer Rate
480 Mbps
Angled Plug
No
STANDARDS & COMPLIANCE
Product Certifications
MFi
Product Compliance
RoHS; REACH; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“M100-001-GY-MAX”相匹配的价格&库存,您可以联系我们找货
