M102AB-003-S-LB
M102AB-003-S-LB
    TRIPPLITE
    缆线组件 USB C 公插头转 i5 闪电连接器 3.00'(914.4mm)
M102AB-003-S-LB 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Safe-IT USB-C to Lightning Sync/Charge Antibacterial Cable, Ultra Flexible, MFi Certified USB 2.0 (M/M), Light Blue, 3 ft. (0.91 m) Highlights ● Soft, flexible silicone jacket allows easy bending and avoids messy tangling ● MFi-certified for broad compatibility with your Apple iPhone, iPad or iPod ● Made with antibacterial material proven effective in inhibiting E. coli and staph ● Supports USB 2.0 speeds up to 480 Mbps to ensure reliable charges and data transfers ● Light blue jacket permits fast, easy identification in a crowded charging station MODEL NUMBER: M102AB-003-S-LB Applications ● Charge and sync your Apple iPhone, iPad or iPod using the USB-C port on your computer or a wall charger up to 3 feet away ● Transfer photos and other important files between an external hard drive and your Apple device ● Pair with an Apple 18W power adapter for optimal charging performance with an iPad Pro, iPad Air or iPhone 8 or later ● Provide extra protection against bacteria to give cable installers and IT personnel peace of mind during installation USB/Lightning cable with antibacterial properties connects your Apple iPhone, iPad or iPod to the USB-C port on your MacBook, Windows laptop or wall/car charger. Features USB-C Cable Charges and Syncs Your Latest-Generation iPhone, iPad and iPod This Safe-IT™ sync/charge cable (M/M) connects your iPhone, iPad or iPod to the USB-C port on a computer, MacBook, Chromebook, Windows laptop, car charger or wall charger. It allows you to charge and power your Apple device while simultaneously syncing and transferring photos, MP3s and other important files at USB 2.0 data transfer speeds up to 480 Mbps. The cable is backward compatible with previous USB generations, allowing you to use it with older equipment. Innovative Soft Cable Jacket Prevents Tangles, Allows Flexible Bends Very flexible for convenient on-the-go connections, the ultra-soft silicone-layered jacket avoids nasty tangles in your backpack or laptop bag and feels nice to the touch. Plus, it bends easily for connecting to devices in tight spaces or around obstacles. Provides Extra Protection Against Certain Bacteria The molded connectors and jacket are constructed using an antibacterial material that is effective in inhibiting Escherichia coli (E. coli) and Staphylococcus aureus (staph). This added protection makes this Safe-IT cable an ideal solution for medical facilities, schools, businesses, restaurants/kitchens and anywhere else that needs extra protection against bacteria. MFi-Certified for Broad Device Compatibility The 20V 3A (60W) Lightning cable is MFi-certified for use with the latest generation of iPhone, iPad and iPod devices. The C94 Lightning connector pairs with an Apple 18W power adapter for optimal charging performance with an iPad Pro, iPad Air or iPhone. Integral strain relief gives the cable extra flexibility, reduces stress and helps the cable move freely without cracking or breaking loose from the connector. Light Blue Jacket Helps Avoid Misidentification That Can Cause Costly Downtime The USB cable has a light blue jacket, which is easy to identify quickly in a crowded charging station and helps prevent the cable from becoming accidentally disconnected. Specifications 1/3 System Requirements ● Computer, laptop or charger with USB-C port ● Most current iPhone, iPad and iPod devices Package Includes M102AB-003-S-LB USB-C to Lightning Sync/Charge Antibacterial Cable (M/M), Light Blue, 3 ft. (0.9 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332278272 Technology Lightning; USB 2.0 (High Speed) Cable Type Passive POWER USB Power Delivery (PD) Charging Support Yes USB Power Delivery (PD) Charging Specification 3.0 PHYSICAL Material of Construction JACKET: SILICONE; CONNECTOR: TPE Cable Jacket Color Light Blue Cable Jacket Material Silicone Cable Jacket Rating FT2 Cable Outer Diameter (OD) 4.1mm Cable Length (ft.) 3 Cable Length (m) 0.91 Cable Length (in.) 36 Shipping Dimensions (hwd / in.) 0.91 x 4.57 x 2.36 Shipping Weight (kg) 0.06 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range -40° to 158°F (-40° to 70°C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing Power Provided to Connected Device(s) 60W (20V/3A) CONNECTIONS Side A - Connector 1 USB C (MALE) Side B - Connector 1 LIGHTNING (MALE) Connector Plating Nickel Contact Plating Gold 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Connector Style Straight FEATURES & SPECIFICATIONS Antimicrobial No USB Specification USB 2.0 (up to 480 Mbps) Antibacterial Yes STANDARDS & COMPLIANCE Product Certifications MFi; UL 94 Product Compliance CE (Europe); FCC (USA); REACH; RoHS; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
M102AB-003-S-LB 价格&库存
很抱歉,暂时无法提供与“M102AB-003-S-LB”相匹配的价格&库存,您可以联系我们找货
