1000 Eaton Boulevard
Cleveland, OH 44122
United States
Safe-IT USB-C to Lightning Sync/Charge
Antibacterial Cable, Ultra Flexible, MFi Certified USB 2.0 (M/M), Light Blue, 6 ft. (1.83 m)
Highlights
Soft, flexible silicone jacket
allows easy bending and avoids
messy tangling
MFi-certified for broad
compatibility with your Apple
iPhone, iPad or iPod
Made with antibacterial material
proven effective in inhibiting E.
coli and staph
Supports USB 2.0 speeds up to
480 Mbps to ensure reliable
charges and data transfers
Light blue jacket permits fast,
easy identification in a crowded
charging station
MODEL NUMBER: M102AB-006-S-LB
Applications
Charge and sync your Apple
iPhone, iPad or iPod using the
USB-C port on your computer or
a wall charger up to 6 feet away
Transfer photos and other
important files between an
external hard drive and your
Apple device
Pair with an Apple 18W power
adapter for optimal charging
performance with an iPad Pro,
iPad Air or iPhone 8 or later
Provide extra protection against
bacteria to give cable installers
and IT personnel peace of mind
during installation
USB/Lightning cable with antibacterial properties connects your Apple iPhone, iPad or iPod to the USB-C
port on your MacBook, Windows laptop or wall/car charger.
Features
USB-C Cable Charges and Syncs Your Latest-Generation iPhone, iPad and iPod
This Safe-IT™ sync/charge cable (M/M) connects your iPhone, iPad or iPod to the USB-C port on a
computer, MacBook, Chromebook, Windows laptop, car charger or wall charger. It allows you to charge
and power your Apple device while simultaneously syncing and transferring photos, MP3s and other
important files at USB 2.0 data transfer speeds up to 480 Mbps. The cable is backward compatible with
previous USB generations, allowing you to use it with older equipment.
Innovative Soft Cable Jacket Prevents Tangles, Allows Flexible Bends
Very flexible for convenient on-the-go connections, the ultra-soft silicone-layered jacket avoids nasty
tangles in your backpack or laptop bag and feels nice to the touch. Plus, it bends easily for connecting to
devices in tight spaces or around obstacles.
Provides Extra Protection Against Certain Bacteria
The molded connectors and jacket are constructed using an antibacterial material that is effective in
inhibiting Escherichia coli (E. coli) and Staphylococcus aureus (staph). This added protection makes this
Safe-IT cable an ideal solution for medical facilities, schools, businesses, restaurants/kitchens and
anywhere else that needs extra protection against bacteria.
MFi-Certified for Broad Device Compatibility
The 20V 3A (60W) Lightning cable is MFi-certified for use with the latest generation of iPhone, iPad and
iPod devices. The C94 Lightning connector pairs with an Apple 18W power adapter for optimal charging
performance with an iPad Pro, iPad Air or iPhone. Integral strain relief gives the cable extra flexibility,
reduces stress and helps the cable move freely without cracking or breaking loose from the connector.
Light Blue Jacket Helps Avoid Misidentification That Can Cause Costly Downtime
The USB cable has a light blue jacket, which is easy to identify quickly in a crowded charging station and
helps prevent the cable from becoming accidentally disconnected.
Specifications
1/3
System Requirements
Computer, laptop or charger
with USB-C port
Most current iPhone, iPad and
iPod devices
Package Includes
M102AB-006-S-LB USB-C to
Antibacterial Cable (M/M), Light
Blue, 6 ft. (1.8 m)
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332278289
Technology
Lightning; USB 2.0 (High Speed)
Cable Type
Passive
POWER
USB Power Delivery (PD) Charging
Support
Yes
Specification
3.0
PHYSICAL
Material of Construction
JACKET: SILICONE; CONNECTOR: TPE
Cable Jacket Color
Light Blue
Cable Jacket Material
Silicone
Cable Jacket Rating
FT2
Cable Outer Diameter (OD)
4.4mm
Cable Length (ft.)
6
Cable Length (m)
1.83
Cable Length (in.)
72
Shipping Dimensions (hwd / in.)
0.91 x 4.57 x 2.36
Shipping Weight (kg)
0.09
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Packaging Type
Box
ENVIRONMENTAL
Operating Temperature Range
32° to 113°F (0° to 45°C)
Storage Temperature Range
-40° to 158°F (-40° to 70°C)
Operating Humidity Range
10% to 85% RH, Non-Condensing
Storage Humidity Range
5% to 90% RH, Non-Condensing
Power Provided to Connected
Device(s)
60W (20V/3A)
CONNECTIONS
Side A - Connector 1
USB C (MALE)
Side B - Connector 1
LIGHTNING (MALE)
Connector Plating
Nickel
Contact Plating
Gold
2/3
Cleveland, OH 44122
United States
Connector Style
Straight
FEATURES & SPECIFICATIONS
Antimicrobial
No
USB Specification
USB 2.0 (up to 480 Mbps)
Antibacterial
Yes
STANDARDS & COMPLIANCE
Product Certifications
MFi; UL 94
Product Compliance
CE (Europe); FCC (USA); REACH; RoHS; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“M102AB-006-S-LB”相匹配的价格&库存,您可以联系我们找货
