M102AB-01M-WH
M102AB-01M-WH
    TRIPPLITE
    缆线组件 USB C 公插头转 i5 闪电连接器 3.28'(1.00m)
M102AB-01M-WH 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Safe-IT USB-C to Lightning Sync/Charge Antibacterial Cable (M/M), MFi Certified, White, 1 m (3.3 ft.) Highlights ● MFi-certified for broad compatibility with your Apple iPhone, iPad or iPod ● Made with antibacterial material proven effective in inhibiting the growth of E. coli and staph ● Supports USB 2.0 speeds up to 480 Mbps to ensure reliable data transfers ● C94 Lightning connector compatible with Apple 18W USB-C power adapter ● Reversible plugs connect in either direction for immediate no-fuss use MODEL NUMBER: M102AB-01M-WH Applications ● Charge and sync your Apple iPhone, iPad or iPod using the USB-C port on your computer or a wall charger up to 1 meter away ● Transfer photos and other important files between an external hard drive and your Apple device ● Pair with an Apple 18W power adapter for optimal charging performance with an iPad Pro, iPad Air or iPhone 8 or later ● Provide extra protection against bacteria to give cable installers and IT personnel peace of mind during installation USB/Lightning cable with antibacterial properties connects your Apple iPhone, iPad or iPod to the USB-C port on your MacBook, Windows laptop or wall/car charger. Features USB-C Cable Charges and Syncs Your Latest-Generation iPhone, iPad and iPod This Safe-IT™ sync/charge cable (M/M) connects your iPhone, iPad or iPod to the USB-C port on a computer, MacBook, Chromebook, Windows laptop, car charger or wall charger. It allows you to charge and power your Apple device, while simultaneously syncing and transferring photos, MP3s and other important files at USB 2.0 data transfer speeds up to 480 Mbps. The cable is backward compatible with previous USB generations, allowing you to use it with older equipment. Antibacterial Properties Provide Extra Protection The molded connectors and PVC jacket are constructed using an antibacterial material that is effective in inhibiting the growth of Escherichia coli (E. coli) and Staphylococcus aureus (staph). This added protection makes this cable an ideal solution for medical facilities, schools, businesses, restaurants/kitchens and anywhere else that needs extra protection against bacteria. MFi-Certified for Broad Device Compatibility The 20V 3A (60W) Lightning cable is MFi-certified for use with the latest generation of iPhone, iPad and iPod devices. Integral strain relief gives the cable extra flexibility, reduces stress and helps the cable move freely without cracking or breaking loose from the connector. Reversible C94 Lightning and USB Type-C Plugs Connect in Either Direction Connect the C94 Lightning plug to your Apple device for charging and synchronizing, and connect the USB-C plug to a USB-C port on a computer or charger. The reversible plugs connect in either direction to ensure you get it on the first try. While the cable is compatible with all USB-C ports, the C94 Lightning connector is designed for optimal charging performance with Apple’s 18W USB-C power adapter. Specifications OVERVIEW 1/3 System Requirements ● Computer, laptop or charger with USB-C port ● Most current iPhone, iPad and iPod devices Package Includes M102AB-01M-WH USB-C to Lightning Sync/Charge Antibacterial Cable (M/M), White, 1 m (3.3 ft.) 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332261076 Technology Lightning; USB 2.0 (High Speed) Cable Type Passive PHYSICAL Material of Construction PVC Cable Jacket Color White Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 3.7MM Cable Length (ft.) 3.3 Cable Length (m) 1.01 Cable Length (in.) 39.4 Shipping Dimensions (hwd / in.) 0.91 x 4.57 x 2.36 Shipping Weight (kg) 0.06 ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range -40° to 158°F (-40° to 70°C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing Power Provided to Connected Device(s) 60W (20V/3A) CONNECTIONS Side A - Connector 1 USB C (MALE) Side B - Connector 1 LIGHTNING (MALE) Connector Plating Nickel Contact Plating Gold Connector Style Straight FEATURES & SPECIFICATIONS Antimicrobial No USB Specification USB 2.0 (up to 480 Mbps) Antibacterial Yes STANDARDS & COMPLIANCE Product Certifications MFi 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
M102AB-01M-WH 价格&库存
很抱歉,暂时无法提供与“M102AB-01M-WH”相匹配的价格&库存,您可以联系我们找货
M102AB-01M-WH
  • 1+204.541951+25.62473
  • 10+173.8712410+21.78234
  • 25+162.9787725+20.41775
  • 50+155.2027950+19.44359
  • 100+147.79907100+18.51606
  • 250+138.55471250+17.35794
  • 500+131.95051500+16.53058
库存:3
