1000 Eaton Boulevard
Cleveland, OH 44122
United States
Thunderbolt 3 Passive Cable (M/M) - 20 Gbps, 5A
100W Power Delivery, 4K/60 Hz, 1.5 m (5 ft.),
Black
Highlights
Thunderbolt 3 cable is
compatible with all USB-C and
Thunderbolt 3 devices
Supports Thunderbolt 3 speeds
up to 20 Gbps—2x faster than
USB 3.1 Gen 2
Provides 5A (100W) power
output for charging and
powering large-capacity mobile
devices
Reversible Thunderbolt 3 plugs
connect in either direction for
immediate no-fuss use
Plug-and-play operation with no
software required for easy,
immediate installation
MODEL NUMBER: MTB3-01M5-5A-B
Applications
Connect your laptop to a
docking station or hub with a
USB-C or Thunderbolt 3 port
Bridge two Thunderbolt 3enabled notebooks for migrating
data or setting up a peer-to-peer
network
Stream 4K video from your
MacBook or Chromebook to a
monitor or television with a
DisplayPort input
Connect a DisplayPort monitor
or laptop to an external GPU
box for playing graphicsintensive 4K video games
Connects 2 Thunderbolt 3 devices, including MacBooks and Chromebooks, for charging them or
transmitting 4K video at 20 Gbps speeds.
Features
Passive Cable Connects Thunderbolt 3 Devices, Including MacBooks and ChromebooksThis
Thunderbolt 3 cable allows you to connect one Thunderbolt 3-enabled device to another, including
MacBooks, Ultrabooks, Chromebooks, external hard drives and docking stations. It transmits full 4K x 2K
(3840 x 2160 at 60 Hz) DisplayPort video and works with existing DisplayPort monitors. The cable’s 1.5meter length makes it easy to carry in your briefcase or laptop bag for quick video connections and file
transfers on the go.
Charges Devices and Transfers Data 2 Times Faster Than USB 3.1 Gen 2The MTB3-01M5-5A-B
supports bidirectional Thunderbolt 3 data transfer speeds up to a whopping 20 Gbps, which is twice as
fast as USB 3.1 Gen 2. The PD Charging cable also provides power output up to 5 amps (100 watts),
which is sufficient for fast-charging, syncing and powering most large-capacity devices.
Reversible Thunderbolt 3 Connectors Attach in Either DirectionUnlike traditional USB cables that
connect in only one direction, the reversible Thunderbolt 3 male connectors plug into a Thunderbolt 3 or
USB-C port in either direction for a fumble-free connection every time. Note: both ends must be connected
to a Thunderbolt 3 port to achieve 20 Gbps transfer speeds.
Specifications
OVERVIEW
UPC Code
037332242020
Technology
DisplayPort; Thunderbolt
VIDEO
1/3
System Requirements
Devices with Thunderbolt 3 or
USB-C ports (20 Gbps speeds
possible only through
Thunderbolt 3)
Package Includes
MTB3-01M5-5A-B Thunderbolt
3 Cable, M/M, 1.5 m, Black
Cleveland, OH 44122
United States
Max Supported Video Resolution
3840 x 2160 (4K x 2K) @ 60 Hz
POWER
Power Consumption (Watts)
0.02
USB Power Delivery (PD) Charging
Support
Yes
Specification
2.0
Power Consumption Detail
Under 20mW
PHYSICAL
Color
Black
Cable Jacket Color
Black
Cable Outer Diameter (OD)
+/- 4.8 mm
Cable Length (ft.)
5
Cable Length (m)
1.52
Cable Length (in.)
59.1
Cable Length (cm)
150
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
ENVIRONMENTAL
Operating Temperature Range
32° to 122°F (0° to 50°C)
Storage Temperature Range
-4° to 185°F (-20° to 85°C)
Relative Humidity
25% ~ 85% RH
Power Provided to Connected
Device(s)
5A (100W) Power Delivery
CONNECTIONS
Side A - Connector 1
THUNDERBOLT 3 (Type-C MALE)
Side B - Connector 1
Connector Plating
Nickel
FEATURES & SPECIFICATIONS
Data Transfer Rate
20 Gbps
High Voltage
No
Locking Plug
No
Displayport Specification
1.2
STANDARDS & COMPLIANCE
2/3
Cleveland, OH 44122
United States
Product Certifications
UL Listed
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“MTB3-01M5-5A-B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+651.571391+81.62794
- 10+553.8695410+69.38799
- 25+519.2102125+65.04592
- 50+494.4527050+61.94433
- 100+486.67048100+60.96939
