MTB3-02M-5A-AB
MTB3-02M-5A-AB
    TRIPPLITE
    USB 3.2 Gen 2(USB 3.1 Gen 2,Superspeed+(USB 3.1)) 缆线 C 公型至 C 公型 6.56'(2.00m) 无屏蔽
MTB3-02M-5A-AB 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Highlights Important Note ● Thunderbolt 3 cable is compatible with all USB-C and Thunderbolt 3 devices ● Thunderbolt 3 Active Cable (M/M) - 40 Gbps, 5A 100W Power Delivery, 4K/60 Hz, 2M (6.56 ft.), Black Supports Thunderbolt 3 speeds up to 40 Gbps—4x faster than USB 3.1 Gen 2 ● Provides 5A (100W) power output for charging and powering large-capacity mobile devices MODEL NUMBER: MTB3-02M-5A-AB ● Reversible Thunderbolt 3 plugs connect in either direction for immediate no-fuss use ● Plug-and-play operation with no software required for easy, immediate installation This cable can only be used to stream 4K video when used with a Thunderbolt-3 enabled monitor. A USBC or DisplayPort input will not support video transmission. Applications Connects 2 Thunderbolt 3 devices, including MacBooks and Chromebooks, for charging them or transmitting 4K video at 40 Gbps speeds. ● Connect your laptop to a docking station or hub with a USB-C or Thunderbolt 3 port ● Bridge two Thunderbolt 3enabled notebooks for migrating data or setting up a peer-to-peer network ● Stream 4K video from your MacBook or Chromebook to a monitor or television with a Thunderbolt 3-enabled input ● Connect a DisplayPort monitor or laptop to an external GPU box for playing graphicsintensive 4K video games Features Active Cable Connects Thunderbolt 3 Devices, Including MacBooks and ChromebooksThis Thunderbolt 3 cable allows you to connect one Thunderbolt 3-enabled device to another, including MacBooks, Ultrabooks, Chromebooks, external hard drives and docking stations. It transmits full 4K x 2K (3840 x 2160 at 60 Hz) DisplayPort video when used with Thunderbolt 3-enabled monitors. The cable’s two-meter length makes it easy to carry in your briefcase or laptop bag for quick video connections and file transfers on the go. System Requirements Charges Devices and Transfers Data 4 Times Faster Than USB 3.1 Gen 2The MTB3-02M-5A-AB supports bidirectional Thunderbolt 3 data transfer speeds up to a sizzling 40 Gbps, which is four times as fast as USB 3.1 Gen 2, making it an ideal cable for downloading 4K video files and transmitting them to a 4K monitor or television with a Thunderbolt 3-enabled input. Transceivers in each connector regulate the transfer of data throughout the entire length of the active cable. The PD Charging 2.0 cable also provides power output up to 5 amps (100 watts), which is sufficient for fast-charging, syncing and powering most large-capacity devices. Package Includes Reversible Thunderbolt 3 Connectors Attach in Either DirectionUnlike traditional USB cables that connect in only one direction, the reversible Thunderbolt 3 male connectors plug into a Thunderbolt 3 or USB-C port in either direction for a fumble-free connection every time. Note: both ends must be connected to a Thunderbolt 3 port to achieve 40 Gbps transfer speeds. Specifications 1/3 ● ● Devices with Thunderbolt 3 or USB-C ports (40 Gbps speeds possible only through Thunderbolt 3) MTB3-02M-5A-AB Thunderbolt 3 Cable, M/M, 2 m, Black 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332242013 Technology Thunderbolt POWER Power Consumption (Watts) 1.5 USB Power Delivery (PD) Charging Support Yes USB Power Delivery (PD) Charging Specification 2.0 PHYSICAL Color Black Cable Jacket Color Black Cable Outer Diameter (OD) +/- 4.75 mm Cable Length (ft.) 6.6 Cable Length (m) 2.01 Cable Length (in.) 78.74 Cable Length (cm) 200 ENVIRONMENTAL Operating Temperature Range 32° to 122°F (0° to 50°C) Storage Temperature Range -4° to 185°F (-20° to 85°C) Relative Humidity 25% ~ 85% RH Power Provided to Connected Device(s) 5A (100W) Power Delivery CONNECTIONS Side A - Connector 1 THUNDERBOLT 3 (Type-C MALE) Side B - Connector 1 THUNDERBOLT 3 (Type-C MALE) Connector Plating Nickel FEATURES & SPECIFICATIONS Data Transfer Rate 40 Gbps High Voltage No Locking Plug No STANDARDS & COMPLIANCE Product Certifications UL Listed 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
MTB3-02M-5A-AB 价格&库存
很抱歉,暂时无法提供与“MTB3-02M-5A-AB”相匹配的价格&库存,您可以联系我们找货
MTB3-02M-5A-AB
  • 1+896.416101+116.02831
