MTB3-DOCK-03
MTB3-DOCK-03
    TRIPPLITE
    THUNDERBOLT 3 DOCK, DUAL DISPLAY
MTB3-DOCK-03 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Highlights Important Note ● This Thunderbolt 3 docking station must be connected to a Thunderbolt 3-enabled laptop or computer using a Thunderbolt 3 cable to achieve maximum data transfer and video transmission specifications. It is important that the host PC allows for administrator access when connecting the dock for the first time in order to allow the automatic driver installation to take place. If this is not an option please see the product's web page on https://tripplite.eaton.com to download the drivers manually. Connects 2 displays at the same time for multitasking and increasing productivity via a Thunderbolt 3-enabled host ● Transmits 8K video (7680 x 4320) @ 30 Hz to a single display for professional users ● Can operate with Thunderbolt 3 or USB-C Multi-Function DisplayPort (MFDP) host ● Supports Thunderbolt 3 speeds up to 40 Gbps between compatible devices ● USB 3.2 Gen 2 data ports allow connection of flash drives and other peripherals Thunderbolt 3 Dock w USB-C Compatibility, Dual Display - 8K DisplayPort, USB 3.2 Gen 2 10G, USB-A/C Hub, Memory Card, GbE, 60W Charging MODEL NUMBER: MTB3-DOCK-03 Applications Turns your MacBook Pro or Windows laptop into a 10-port workstation capable of transmitting 8K video. ● Extend or mirror your MacBook Pro or Windows laptop on multiple displays to aid in multitasking and increase productivity ● Edit HDR production video or digital photos using an 8K monitor ● Transfer files from one Thunderbolt 3 device to another at 40 Gbps ● Access a wired Gigabit Ethernet network in a location with no or spotty Wi-Fi ● Connect a microphone/headset to record a podcast or speakers to listen to music Features Thunderbolt 3 Dock Turns Your MacBook Pro into a 10-Port 8K WorkstationThis Thunderbolt 3 docking station dramatically expands the potential of your MacBook Pro or Windows laptop by adding 10 ports to its Thunderbolt 3 or USB-C MFDP port. Not only does the MTB3-DOCK-03 allow you to transmit 8K video to one display or 4K video to two displays, you can also add USB peripherals, record a podcast, connect to a Gigabit Ethernet network, charge your laptop and more, all at the same time. Supports DisplayPort Alternate Mode for Transmitting Audio/Video SignalsBy connecting the included Thunderbolt 3 cable to a source device that supports DisplayPort Alt Mode, you can output 4K video and digital audio to a compatible monitor, television or projector without installing special software drivers. Thunderbolt 3 Supports Blisteringly Fast 40 Gbps Data Transfer SpeedsThe included Thunderbolt 3 cable supports bidirectional speeds up to 40 Gbps, which is eight times faster than USB 3.0, four times faster than Thunderbolt 1 and twice as fast as Thunderbolt 2. With dual 20 Gbps channels moving data both directions at the same time, the MTB3-DOCK-03 is perfectly suited for 4K video streaming and editing on two monitors, as well as transferring large RAW video or CAD files. When connected to a host computer’s USB-C MFDP port, the cable supports 26.2 Gbps speeds (USB 3.2 Gen 2 10 Gbps + DisplayPort 1.4 8.1G x2 Lane) DisplayPort Multi-Stream Transport (MST) Allows Connection of Multiple DisplaysBy connecting the included Thunderbolt 3 cable to a Thunderbolt source that supports DisplayPort MST Mode, you may connect two displays simultaneously (DP & USB-C) at resolutions of 8K (30 Hz) plus 4K (30 Hz) or both displays at 4K (60 Hz). This allows you to display the same image on both monitors, extend your host 1/7 System Requirements ● Source device with Thunderbolt 3 port that supports DisplayPort MST Mode or USB-C port that supports Multi-Function DisplayPort ● Display device with Thunderbolt 3 or DisplayPort input Package Includes ● MTB3-DOCK-03 Thunderbolt 3 Dock, Dual Display ● Thunderbolt 3 cable (M/M), 1.6 ft. ● External power supply (Input: 100–240V, 50/60 Hz, 3.0A; Output: 20V 6A) ● C13 to NEMA 5-15P Adapter, 4 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States desktop across both with different windows open on each, or combine both into one large display as a video wall. Up to three total displays can be utilized if the dock is connected to a compatible laptop (DP + USB-C + Laptop screen). Transmits Crystal-Clear 8K and 4K Video for Professional Editing and Digital SignageBoth the DisplayPort and Thunderbolt 3 video ports can achieve individual resolutions up to 8K (7680 x 4320) at 30 Hz, when used with a Thunderbolt 3-enabled source computer and Thunderbolt 3 cable. When used with an MFDP-enabled source computer, the DisplayPort connector’s maximum resolution is 4K (3840 x 2160) at 60 Hz, and the Thunderbolt port is reduced to USB 2.0 data transfer functionality only. The Thunderbolt 3 port also allows daisy-chaining up to six devices, including RAID memory and other storage devices. USB Ports Connects Keyboards, Thumb Drives and Other USB PeripheralsTwo USB-A hub ports and one USB-C port accept USB peripherals, such as flash drives, mice, keyboards, external hard drives and printers. All three support lightning-fast USB 3.2 Gen 2 data transfer rates up to 10 Gbps and are backward compatible with previous USB generations. The USB-C port supports USB charging up to 5V 1.5A. One USB-A port supports charging speeds up to 5V 1.5A. The other supports charging up to 5V 900mA. Accesses a Wired Gigabit Ethernet NetworkThe RJ45 port offers access to a Gigabit Ethernet network when no Wi-Fi is available or when a wired connection offers faster speeds. Connect using a UTP cable (sold separately), and enjoy true 10/100/1000 Mbps Ethernet speeds for fast data transfers. Connects Stereo Audio Equipment for Recording and PlaybackThis Thunderbolt 3 docking station contains one 3.5 mm mini stereo jack, convenient for connecting speakers, headphones or a microphone to your workstation. You can listen to music or record the latest episode of your podcast. Allows External Memory AccessThe SD 4.0 memory card slots support Micro SD and SD cards for transferring data to and from your connected computer or laptop. Both slots may be used at the same time. Included Thunderbolt 3 Cable Attaches in Either DirectionUnlike traditional USB cables that connect in only one direction, the reversible Thunderbolt 3 male connector plugs into its port in either direction for an instant connection every time. Ready to Use Right from the Package, So You Can Plug and Play ImmediatelyThe plug-and-play Thunderbolt 3 dock is specifically designed for use with the MacBook Pro or Windows laptop equipped with a Thunderbolt 3 port. Drivers are automatically downloaded and installed during the initial dock connection with the host computer (Note: the host must have administrative access for the drivers to install automatically. If this is not possible the drivers can be downloaded manually via the product's web page at tripplite.eaton.com). Simply plug the included power adapter into a standard AC outlet, and connect the included Thunderbolt 3 cable to your computer’s Thunderbolt 3 or USB-C MFDP port. Specifications OVERVIEW UPC Code 037332250322 Product Type Docking Station Technology Cat6; DisplayPort; Thunderbolt; USB 3.x Country/Region North America Host Connector THUNDERBOLT 3 (Type-C MALE) VIDEO 2/7 ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Video Input THUNDERBOLT 3 (Type-C FEMALE) Video Output DISPLAYPORT (FEMALE); THUNDERBOLT 3 (Type-C FEMALE) Number of Monitors Supported 2 Video Ports THUNDERBOLT 3 (Type-C FEMALE); DISPLAYPORT (FEMALE) Video Ports Details DisplayPort 1.4; Thunderbolt 3 Resolutions Supported Thunderbolt 3 Host (with DisplayPort 1.4 Alt Mode):Thunderbolt 3: 8K 30Hz (7680 x 4320); DisplayPort: 8K 30Hz (7680 x 4320) (Individually)Thunderbolt 3: 8K 30Hz (7680 x 4320) + DisplayPort: 4K 30Hz (3840 x 2160) (Dual Output)USB-C MFDP Host (with DisplayPort 1.4 Alt Mode):Thunderbolt 3: No Video (USB 2.0 Data only); DisplayPort: 4K 60Hz (3840 x 2160) (Single Output Only)USB-C MFDP Host (with DisplayPort 1.2 Alt Mode):Thunderbolt 3: No Video (USB 2.0 Data only); DisplayPort: 4K 30Hz (3840 x 2160) (Single Output Only) Max Supported Video Resolution 7680 x 4320 (8K) @ 30 Hz (Thunderbolt 3); 3840 x 2160 (4K x 2K) @ 60 Hz (MFDP) Extended Mode Yes Extended Mode Details For Thunderbolt 3 Source:1x DP (8K 30Hz) + 1x ThunderBolt 3 (4K 30Hz) via USB-C to C or USB-C to DP or USB-C to HDMI cable or adapterFor USB-C MFDP Source:1x DP (4K 60Hz) Note: If USB-C host supports DP 1.2 Alt Mode instead of DP 1.4 Alt Mode, the maximum resolution is 4K/30 Hz Mirror Mode Yes Mirror Mode Details For Thunderbolt 3 Source:1x DP (8K 30Hz) + 1x ThunderBolt 3 (4K 30Hz) via USB-C to C or USB-C to DP or USB-C to HDMI cable or adapterFor USB-C MFDP Source:1x DP (4K 60Hz) Note: If USB-C host supports DP 1.2 Alt Mode instead of DP 1.4 Alt Mode, the maximum resolution is 4K/30 Hz Max Supported Color Depth 48-bit Deep Color HDR Support Yes 3D Video Supported Yes Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Unidirectional DisplayPort Alt Mode Yes AUDIO Audio Ports 3.5MM (FEMALE) Audio Ports Details 3.5mm Combo Stereo Audio / Microphone JackSupports 8/16/22.05/24/32/44.1/48/96/176.4/192/384 KHzSupports 16/24/32-Bit Sample RateSupports Auto-Detection and Auto-Switch between OMTP and CTIAIn order to extract sound the user must change the output sound manually in the sound setting of the source being used DATA Data Ports (2) THUNDERBOLT 3 (Type-C FEMALE); (2) USB A (FEMALE); (1) USB C (FEMALE) Data Ports Details (2) USB-A - USB 3.2 Gen 2 (10 Gbps); (2) USB-C - ThunderBolt 3 (40 Gbps); (1) USB-C - USB 3.2 Gen 2 (10 Gbps) NETWORK Network Ports RJ45 (FEMALE) STORAGE Card Slots SD (FEMALE); MICRO SD (FEMALE) 3/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Card Slots Details Supports Secure Digital v.40 (SD 4.0) UHS-I (Ultra High Speed): SDR12 (12.5Mbyte/second)/SDR25 (25Mbyte/second)/SDR50 (50Mbyte/second)/SDR104 (104Mbyte/second)Supports UHS-II: Full Duplex Mode and Half Duplex Mode (Up to 312MB/s data rate)Both card readers can be used at the same time INPUT AC Power Adapter Plug(s) NEMA 5-15P North America AC Power Adapter Input Specs (V / Hz / A) 100-240V / 50/60Hz / 3A AC Power Adapter Output Specs (V / A) 20V / 6A AC Power Adapter Cord Length (ft.) 4 AC Power Adapter Cord Length (m) 1.2 Maximum Input Amps 3.0 Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Bus Powered No BATTERY Battery Charging (5V/1.5A Port) Yes POWER Power Source Type AC Adapter with detachable power cord AC Adapter Input: 100–240V, 50/60 Hz, 3.0A; Output: 20V, 6A DC Barrel Plug OD: 4.5 x 0.6 x 10.5mm, Positive Pin, Negative Sleeve USB Power Delivery (PD) Charging Support Yes USB Power Delivery (PD) Charging Specification 60W USER INTERFACE, ALERTS & CONTROLS LED Indicators Green (Power), Orange (Transmitting Data) CHARGING Number of Charging Ports 5 Total Charging Watts 60 Charging Port Type (2) THUNDERBOLT 3 (Type-C FEMALE); (2) USB A (FEMALE); (1) USB C (FEMALE) Charging Ports Details (2) Thunderbolt 3 ports: (1) Charges the host device with up to 60 Watts (5V/9V/15V/20V 3A); (1) Supports Thunderbolt 3 daisy chaining up to 6 levels with source capability of 15W (5V/3A)(2) USB 3.2 Gen 2 Type-A ports. (1) USB-A port supports USB charging up to 5V 1.5A. (1) USB-A port up to 4.5W (5V/0.9A).(1) USB 3.2 Gen 2 TypeC port which supports USB charging up to 7.5W (5V/1.5A). Charging Ports / Amps (1) 0.9A; (2) 1.5A; (2) 3A Compatible Devices Chromebook; Laptop; Portable Speaker; Smartphone; Tablet 4/7 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color Black; Gray Material of Construction PC, ABS, Aluminum Cable Jacket Color Black Cable Jacket Material PVC Cable Outer Diameter (OD) 4.4mm Cable Length (ft.) 1.64 Cable Length (m) 0.50 Cable Length (in.) 19.69 Cable Length (cm) 50 Total Number of Ports 10 Shipping Dimensions (hwd / in.) 2.44 x 9.72 x 6.85 Shipping Weight (kg) 0.38 Unit Dimensions (hwd / in.) 0.670 x 3.150 x 5.790 Unit Dimensions (hwd / cm) 1.7 x 8.0 x 14.8 Unit Dimensions (hwd / mm) 17.5 x 80 x 148 Unit Packaging Type Box Unit Weight (lbs.) 0.5952 Unit Weight (kg) 0.27 ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range 32° to 158°F (0° to 70°C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5 to 90% RH, Non-condensing Power Provided to Connected Device(s) USB-A 5V/1.5A (7.5W); USB-C 20V/3A (60W) to Host Computer COMMUNICATIONS Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet); 1 Gbps (Gigabit) CONNECTIONS Number of Ports 10 Ports 1 Ports Detail Connect to a Gigabit Ethernet network with user-supplied Cat6 cabling Dock Connectors DISPLAYPORT, 2X THUNDERBOLT 3, USB-C CHARGING, RJ45 LAN, MICRO SD, SD, 3.5MM, 2X USB-A, USBC 5/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Side A - Connector 1 (2) THUNDERBOLT 3 (Type-C FEMALE) Side A - Connector 2 DISPLAYPORT (FEMALE) Side A - Connector 3 RJ45 (FEMALE) Side A - Connector 4 THUNDERBOLT 3 (Type-C MALE) Side A - Connector 5 USB A (FEMALE) Side B - Connector 2 MICRO SD (FEMALE); SD (FEMALE) Side B - Connector 3 3.5MM (FEMALE) Side B - Connector 4 (2) USB A (FEMALE); USB C (FEMALE) Connector Plating Nickel PORT EXPANSION Daisy-chainable or Cascadable Supports Thunderbolt 3 daisy chain up to 6 levels with up to 15 Watts (5V/3A) FEATURES & SPECIFICATIONS USB Hub Ports Yes Number of USB Hub Ports 3 USB Specification USB 3.2 Gen 2 (Up to 10 Gbps) Data Transfer Rate 40 Gbps MST Support Yes Ethernet Support Yes UASP Support No Auto MDIX Support No Full Duplex Support Yes Suspend Mode Support No Remote Wakeup Support No SD Card Specification SD; Micro SD Thunderbolt Specification Thunderbolt 3 (up to 40Gbps short or active cables) Displayport Specification 1.4 HDCP Specification 1.4; 2.2 Driver Required Yes Recommended Category Cable Cat5/Cat5e/Cat6 Cables STANDARDS & COMPLIANCE TAA Compliant Option N External Power Supply Certifications CCC; CE; GS; PSE; TUV; UL; cUL Product Certifications NOM (Mexico) 6/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance FCC (USA); WEEE WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 7/7
MTB3-DOCK-03 价格&库存
很抱歉,暂时无法提供与“MTB3-DOCK-03”相匹配的价格&库存,您可以联系我们找货
