MTB4-HUB3-01
MTB4-HUB3-01
    TRIPPLITE
    4-PORT THUNDERBOLT 4 HUB - 8K, 2
MTB4-HUB3-01 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port Thunderbolt 4 Hub - 8K, 2x 4K 60 Hz, USB 3.2 Gen 2, USB-A Port, 100W Charging, Gray MODEL NUMBER: MTB4-HUB3-01 Highlights Connects one 8K @ 30 Hz or two 4K @ 60 Hz displays for convenient multitaskingSupports Thunderbolt 4 speeds up to 40 Gbps between compatible sources/displaysSupports USB 3.2 Gen 2 speeds up to 10 Gbps and 0.9A downstream device chargingDistributes power between source device and connected devices evenly and efficientlyPlugand-play operation with no software required for easy, immediate installation Applications ● Extend your laptop’s screen, computer monitor or USB-C tablet on multiple displays to aid in multitasking and increase productivity ● Edit HDR production video or digital photos using an 8K monitor ● Charge mobile devices and connect peripherals, including RAID and hard drives, to transfer large video or CAD files ● Cascade an additional 3 devices for a connection of 6 total devices Adds 3 Thunderbolt 4 ports and one USB 3.2 Gen 2 port to your PC’s or laptop’s Thunderbolt port. Features Thunderbolt 4 Hub Turns Your Laptop or Computer into a 4-Port 8K Workstation versatile MTB4-HUB3-01 dramatically expands the potential of your desktop computer or laptop by adding four ports to its Thunderbolt 4 or Thunderbolt 3 port. It goes further than a USB-C hub, offering three Thunderbolt 4 ports that support 8K video and 40 Gbps data transfer speeds. All three ports are backward compatible with Thunderbolt 3 and USB-C monitors as well. A USB 3.2 Gen 2 port allows speeds up to 10 Gbps. Thunderbolt 4 Supports Blisteringly Fast 40 Gbps Data Transfer Speeds The Thunderbolt 4 hub supports bidirectional speeds up to 40 Gbps, which is eight times faster than USB 3.0, four times faster than Thunderbolt 1 and twice as fast as Thunderbolt 2. With dual 20 Gbps channels moving data both directions at the same time, the MTB4-HUB3-01 is perfectly suited for video playback or Zoom meetings on one monitor and video editing or document sharing on another. Because Thunderbolt 4 supports minimum PCIe (PCI Express) data rates of 32 Gbps (twice that of Thunderbolt 3), transferring large RAW video, Photoshop images or CAD files takes hardly any time at all. System Requirements ● Source computer with a Thunderbolt 4 port and Windows 10 or higher OR a Thunderbolt 3 port and macOS 11 or higher ● Source computer must support DisplayPort 1.3 or higher to achieve 8K video resolutions ● Display device(s) with Thunderbolt or USB-C port (Note: Both active and passive Thunderbolt cables will work if both the source computer and display device are Thunderbolt compatible. Only a passive cable will work with a USB-C or other non-Thunderbolt display.) Transmits Crystal-Clear 8K and 4K Video for Professional Editing and Digital Signage When connected to a Thunderbolt 4 source, the hub supports one 8K monitor (7680 x 4320 at 30 Hz) or two 4K monitors (3840 x 2160 at 60 Hz). With dual monitors, you can display the same image on both, extend your host desktop across them, or combine all screens into one large display as a video wall. The Thunderbolt 4 ports also accept Thunderbolt 3 and USB-C monitors for trade shows and video presentations. Note: Source device must support DisplayPort 1.3 to achieve 8K resolution. Cascade up to 6 Levels of Thunderbolt Devices The MTB4-HUB3-01 acts as the first level in a daisychain installation and can cascade an additional five levels vertically, with many more devices connecting horizontally. The dock supports 40 Gbps Thunderbolt 4 data transmission that is shared among the three Thunderbolt ports and all connected peripherals and displays. USB Port Connects Thumb Drives and Other USB Peripherals The USB-A hub port supports USB 3.2 Gen 2 speeds up to 10 Gbps, which is twice as fast as USB 3.2 Gen 1. It accepts high-speed USB peripherals, such as external hard drives, giving you access to essential data storage. It also supports downstream charging of mobile devices up to 900mA (0.9A) and is backward compatible with previous USB generations. 1/5 Package Includes ● MTB4-HUB3-01 4-Port Thunderbolt 4 Hub ● Thunderbolt 4 passive cable (M/M), 2.6 ft. (0.8 m) ● External power supply (Input: 100–240V, 50/60 Hz, 1.5A; Output: 20V 5A) 1000 Eaton Boulevard Cleveland, OH 44122 United States Smart Power Function Allocates Power to Connected Devices Efficiently and Safely The hub features a 20V 5A (100W) power input and can provide 60W to charge the source device, such as a Chromebook, MacBook Pro or iPad Pro. Each Thunderbolt 4 port supports up to 15W downstream charging for connected devices. The USB-A port supports 0.9A. The hub determines how much power is required by each port and allocates the power accordingly. Note: This hub does not support PD Charging. ● (4) International plug adapters (North America, U.K., Europe, Australia) ● Owner’s manual Ready to Use Right from the Package, So You Can Plug and Play Immediately The plug-and-play Thunderbolt 4 hub is specifically designed for Windows devices compatible with Thunderbolt 4 or macOS devices running Thunderbolt 3. It requires no extra software to be downloaded and installed. Simply connect the included Thunderbolt 4 cable to your computer’s Thunderbolt port. Specifications OVERVIEW UPC Code 037332263117 Product Type Thunderbolt 4 Multiport Hub Technology Thunderbolt; USB 3.x Country/Region Global Host Connector THUNDERBOLT 4 (USB-C MALE) VIDEO Video Input THUNDERBOLT 4 (USB-C FEMALE) Video Output THUNDERBOLT 4 (USB-C FEMALE) Number of Monitors Supported 2 Video Ports (3) THUNDERBOLT 4 (USB-C FEMALE) Video Ports Details Thunderbolt 4 Resolutions Supported 8K (7680 x 4320) @ 30 Hz (Single Display); 4K (3840 x 2160) @ 60 Hz (Dual Displays) Supported Resolutions 3840x2160 (4K); 7680x4320 (8K) Max Supported Video Resolution 8K (7680 x 4320) @ 30 Hz Extended Mode Yes Extended Mode Details Extend two 4K (3840 x 2160) @ 60 Hz displays Mirror Mode Yes Mirror Mode Details Mirror two 4K (3840 x 2160) @ 60 Hz displays Max Supported Color Depth 48-bit HDR Support Yes 3D Video Supported Yes Chroma Sub Sampling 4:4:4 EDID Support Yes DisplayPort Alt Mode Yes 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States DSC Support No AUDIO Audio Ports THUNDERBOLT 4 (USB-C FEMALE) Audio Ports Details Supports pass-through audio via x3 Thunderbolt 4 ports (can use up to two ports simultaneously to transmit A/V)Audio output location can be selected by going to the sound settings of the source being used. By default, the sound will come from the first monitor connected, if that monitor has no speakers, the host will output the sound. Audio Output USB-C Audio Specification Pass-through audio via Thunderbolt 4 output ports DATA Data Ports (3) THUNDERBOLT 4 (USB-C FEMALE); USB A (FEMALE) Data Ports Details USB-A - USB 3.2 Gen 2 (10 Gbps); (3) USB-C - Thunderbolt 4 (40 Gbps) INPUT AC Power Adapter Plug(s) AS/NZS 3112 Australia; BS 1363 UK; CEE 7/16 Schuko; NEMA 1-15P North America AC Power Adapter Input Specs (V / Hz / A) 100-240V / 50/60Hz / 1.5A AC Power Adapter Output Specs (V / A) 20V / 5A AC Power Adapter Cord Length (ft.) 3.94 AC Power Adapter Cord Length (m) 1.2 Maximum Input Amps 1.5 Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Bus Powered No BATTERY Battery Charging (5V/1.5A Port) No POWER Power Source Type AC Adapter with detachable power cord Power Source Unit (Included) USB Power Delivery (PD) Charging Support No CHARGING Number of Charging Ports 4 Total Charging Watts 60 Charging Method AC 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Charging Method Detail (x3) Thunderbolt 4 ports each support 15W charging, but do not support PD Charging(x1) USB-A port supports 900mA charging Charging Port Type (3) THUNDERBOLT 4 (USB-C FEMALE); (1) USB 3.1 A (FEMALE) Charging Ports Details (x3) Thunderbolt 4 Ports support maximum 15W charging to connected devices, but do not support PD Charging(x1) USB-A port supports maximum 900mA charging to connected devices Smart Charging Details Support smart charging, dynamically distribute power to PC and Hub according to the requirement of the connected devices. 1) Max 85W power supply from power adapter. 2) Max 60W for host charging. 3) Max 54.5W for Hub and connected devices Compatible Devices Chromebook; Laptop; Smartphone; Tablet PHYSICAL Color Gray Cable Jacket Color Black Cable Outer Diameter (OD) 4.5mm Cable Length (ft.) 2.62 Cable Length (m) 0.80 Cable Length (in.) 31.5 Cable Length (cm) 80 Total Number of Ports 5 Unit Dimensions (hwd / in.) 0.510 x 2.910 x 4.880 Unit Dimensions (hwd / cm) 1.3 x 7.4 x 12.4 Unit Dimensions (hwd / mm) 13 x 74 x 124 Unit Weight (lbs.) 0.3748 Unit Weight (kg) 0.17 ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range 32° to 158°F (0° to 70°C) Relative Humidity 0 to 90% RH, Non Condensing Power Provided to Connected Device(s) 1) Max 85W power supply from power adapter. 2) Max 60W for host charging. 3) Max 54.5W for Hub and connected devices CONNECTIONS Dock Connectors x3 Thunderbolt 4, x1 USB-A 3.1 Gen2 Side A - Connector 1 THUNDERBOLT 4 (USB-C FEMALE) Side B - Connector 1 USB 3.1 A (FEMALE) Side B - Connector 2 (3) THUNDERBOLT 3 (Type-C FEMALE) Input Ports x1 USB-C Thunderbolt 4 (Female) 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States FEATURES & SPECIFICATIONS USB Hub Ports Yes Number of USB Hub Ports 1 USB Specification USB 3.2 Gen 2 (Up to 10 Gbps) MST Support No Thunderbolt Specification Thunderbolt 3 (up to 40Gbps short or active cables); Thunderbolt 4 (up to 40Gbps) STANDARDS & COMPLIANCE TAA Compliant Option N External Power Supply Certifications CCC; CE; NOM; PSE; cUL Product Certifications EN 55032; ICES (Canada); NOM (Mexico) Product Compliance CE (Europe); FCC Part 15 Class B (USA); REACH; RoHS3; UKCA; WEEE WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
MTB4-HUB3-01 价格&库存
很抱歉,暂时无法提供与“MTB4-HUB3-01”相匹配的价格&库存,您可以联系我们找货
