N002-012-BL
N002-012-BL
    TRIPPLITE
    模块化电缆 插头至插头 8p8c(RJ45,以太网) 12.00'(3.66m) 无屏蔽
N002-012-BL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat5e 350 MHz Molded (UTP) Ethernet Cable (RJ45 M/M), PoE - Blue, 12 ft. (3.66 m) MODEL NUMBER: N002-012-BL Highlights ● Premium cabling for Cat5/5e applications ● Rated for 350 MHz/1 Gbps communications ● 26 AWG 4-pair solid UTP with PVC jacket ● Molded boots with integral strain relief for durability ● Color-coded blue for easy ID in crowded rack or panel Package Includes ● Color-coded Cat5e cable connects high-speed network components like computers, servers, printers, copiers, routers, Blu-ray™ players and switches, in a home or office Cat5/5e application. Ideal for highdensity data centers. Features An Ideal Solution for High-Speed Cat5/5e Networking ● Connects high-speed network components, such as computers, servers, printers, copiers, routers, Bluray players and switches ● Designed for 1000Base-T, 10/100Base-T, 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token Ring Type 3 applications ● Provides high-speed connections up to 350 MHz/1 Gbps ● Flawless signal delivery with minimal near-end crosstalk levels ● Color-coded blue for easy identification in crowded rack or panel Premium Construction Ensures Excellent Performance ● Manufactured from 26 AWG 4-pair solid UTP ● Molded RJ45 connectors and gold-plated contacts for maximum conductivity and minimum data loss ● Integral strain relief protects cable and connectors from stress and cracking ● Durable corrosion-resistant PVC jacket ● Meets most current industry standards, including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (Cat5e draft 11) Specifications OVERVIEW UPC Code 037332204264 Technology Cat5/5e 1/3 N002-012-BL Cat5e 350 MHz Molded UTP Patch Cable (RJ45 M/M), Blue, 12 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States POWER Power Over Cable (PoC) Support No PHYSICAL Cable Jacket Color Blue Cable Jacket Material PVC Cable Jacket Rating CM Cable Shielding UTP Cable Outer Diameter (OD) 5.0 mm Number of Conductors 4 Pair Conductor Material Solid Copper Conductor Gauge 26 AWG Wire Gauge (OD - mm²) 26 Cable Length (ft.) 12 Cable Length (m) 3.66 Cable Length (in.) 144 Cable Length (cm) 365.8 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.27 Shipping Weight (kg) 0.12 ENVIRONMENTAL Operating Temperature Range 14° to 104°F (-10° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 100 MHz Maximum Bandwidth as Tested 350 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3ab; 802.3at CONNECTIONS Side A - Connector 1 RJ45 (MALE) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Contact Plating Gold PoE Type Type 2 PoE+ (30W, IEEE 802.3at) Connector Type Molded Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS Antibacterial No IP68 Rated No Snagless Connector No IP20 Rated No STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3ab 1000Base-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N002-012-BL 价格&库存
很抱歉,暂时无法提供与“N002-012-BL”相匹配的价格&库存,您可以联系我们找货
